#31
#32
#33
On Sat, 20 Mar 2004 02:27:33 GMT, Buzzer wrote:
Of course everyone knew the plane was going to be replaced by something newer and faster.G Any decade now... -Jeff B. yeff at erols dot com |
#34
On Sat, 20 Mar 2004 01:40:36 GMT, Tank Fixer
wrote: In article , on 17 Mar 2004 22:02:39 GMT, BUFDRVR attempted to say ..... Face it - a non-stealthy combat aircraft is obsolete. I think you may be over stating that point a bit Walt. There's still years and years of play for non-stealth (and in the case of the BUFF, anti-stealth) aircraft. In fact, the addition of the F/A-22 ensures that. You might be on to something there. A radar signature so massive that radar operators disregard it because they know nothing that huge could fly..... And just think if a B-52 could generate large numbers of those massive radar signatures it would completely blank out the radar operators scope! Or instead of one massive flying barn coming at you it would look like hundreds of flying barns were headed your way from all directions.... |
#35
![]() "Buzzer" wrote in message ... On Fri, 19 Mar 2004 09:36:48 -0500, "Kevin Brooks" wrote: Baugher seems to indicate the C's continued in operational service until as late as 1966 with the 99th BW out of Westover in MA (http://home.att.net/~jbaugher2/b52_8.html ). IAPR (Spring 2003 issue) indicates that "some" C models ended up receiving the TA radar, but it is unclear as to when the last C gave up its SIOP mission. Baugher indicates that the development and fielding of the TA radar was apparently problematic, but goes into no detail on that subject. Baugher indicates the E's had the improved Doppler radar for use in low level navigation, but not the terrain avoidance radar. It appears that different sources are (again) providing somewhat different pictures of what was included, with IAPR, in its Summer 2003 issue, including a list of low level nav aids that were included in the original production (and apparently were so unreliable the system had to be completely rebuilt, a task that took until 1964 to complete) which does not include the TA radar. But IAPR also says the E was the first model that was intended from the start to be a low level operator, so the TA may have been included and the sources just failed to mention it. Baugher had/has some problems with dates and such on B-52D ECM so there might be some problems with other systems. I think the page has been changed and the material deleted, but it went along something like a piece of ECM equipment on the D wasn't installed until 1967 when in fact I had worked on that piece of equipment in 1963 and it had been there long before I was there. Trying to keep track of just ECM mods on B-52s from the 60s onward would probably take a book a foot thick. As far as my post to Walt it is the old ECM - defence game. Something I never figured out how an EWO could get credit for getting the plane through the defences and the defense/interceptors could get credit for shooting the plane down, Walt mentioned the Forbes RB47Es. I worked on something of the equivalent EB-57s at Forbes, previously Holloman Det 1 4677th DSES, in the mid 70s. The main interceptor jammer was basically "dumbed down" for training. A toggle switch on the front of the transmitter safety wired in what you might say was the safe for training mode. I go back to the B-52H and here comes a new, fancy interceptor jammer called the ALQ-117. It has an EWO controlled switch for training and war. The EWOs complain that the training mode for our interceptors is worse than the system it replaced. Almost like it had been deliberately "dumbed down" for training purposes. As far as using the interceptor IR mode to track a B-52? About all I can say about that is first you have to know what part of the sky that big old plane is in. Might not be easy "IF" ECM gets to use everything they have available. The ten or so years I spent in SAC everything was never used. One time I thought it was a go, but when the planes got to the staging base for the excercise they went out and changed one thing back to training. Oh, well... OK. I'll definitely defer to your first-hand knowledge regarding this subject, and thanks for the explanation. I guess in summary, what I am left with are still a couple of unanswered questions (and which may not get answered-- I'd imagine that given a B-52 fleet the size of the one that existed in the mid-sixties (up to 600 plus), there was likely some variation across the board as to who operated how and with what specific models and what specific modifications, so there may very well not be any single answers): a) Did all of the C's that remained active in a SIOP role until retired in 1970 have the TA system; b) Were all B-52 penetrations throughout the sixties to be at low altitude in the SIOP role, and when exactly did that become "law" (ignoring the oft-reported 1959 date, because we know that at least one B-52 crewmember has indicated that he did not transition to the low altitude approach until "the early sixties"), or was it a gradual process that was effected across the fleet and if so when was it effective for the last implementers; and c) How did Hound Dog affect the penetration plan (presuming that most Hound Dogs would have been launched from higher altitude, as a low altitude launch ate rather significantly into the max rang capability), or were the Dogs supposed to be launched pre-penetration, followed by descent to a lower altitude for penetration to deliver the free-fall weapons carried internally? ISTR there used to be another B-52 type pilot (predating Buffdrvr's experience) who has contributed here rather recently who might be able to shed some light on some of those areas. Brooks |
#36
![]() "Buzzer" wrote in message ... On Fri, 19 Mar 2004 09:15:45 -0500, "Kevin Brooks" wrote: In 1961 there were some 571 B-52's in service ( http://www.nrdc.org/nuclear/nudb/datab7.asp ), and by the following year that had climbed to some 673; I doubt that any major program such as the addition of a TA radar was completed in a period of less than three or four years at best for a force of that size (just based upon the '61 size); doing it in two years would have required a modification rate of nearly one aircraft per day, sevven days a week, fifty-two weeks a year. IF E forward came out with TA then the D is the only one that needed the mod, and maybe the C... Most sources seem to indicate the C's, or some of them, did get them. As to E. I don't know--neither source I checked (Baugher and IAPR) specifically indicated they were in the aircrraft as they were delivered. Both of those sources are hardly infallible (as you pointed out with Baugher earlier, and I noted in IAPR that they mistakenly indicated that the Hound Dog brought the first thermonuclear warhead to the B-52 warload, when in fact they had already been carrying freefall TN devices). But I find Baugher's indication that there were some development/integration problems with the TA radar at least believable (that would have been sort of cutting edge stuff during that period), so whether or not the E's had them on delivery is a valid question. There was also an airframe modification program initiated to strengthen the structure so that it could absorb the increasedfatigue loads of low altitude work--I have not seen any indication of when that effort was completed, either, or whether it ever addressed either the C or E models. Some of our D models at Glasgow 64 or so had the stress gauges on them for the study of the structure mod. Only reason I knew about them at the time was they were obvious on the inside skin in the tail section when we loaded chaff. I think the B-52 that crashed in 65 during low level had them because the Boeing engineers were "reading the tapes" from a recorder on the aircraft in our maintenance office. I always figured the recorder was the one that monitored the stress gauges and other aircraft data. Not positive but the structure mod was probably during Big Belly. Or not done at all on the Vietnam birds since they would only be flying high? I believe your last sentence is the correct one, from what I have been reading. I am not sure that either the C's or D's ever got those mods; I think the E's and F's already had them "factory installed", so to speak. In a maintenance debriefing once there was a discussion about the 2000 hr design life of the B-52D and our planes were at something like 1500/1600 hrs. I'm about 19 years old and a flunky two striper thinking what a waste of money designing an aircraft for only 2000 hrs. Click and the clock hits 2000 and off to the junkyard. And then along comes Vietnam... I wish the Army had designed their trucks that way...in 1993, when I gave up company command, we still had some of the old "multi-fuel" series five ton trucks in hand, and they were still wheezing along five or six years later when the Army announced they were no longer going to carry the repair parts lines for them. They were not as old as the Buff's, but they were beat all to hell. How many commercial operators plan to use the same trucks for twenty-five years or so? Brooks |
#37
Buzzer wrote:
Amazing. That was just a dream back in the 70s. SAC was just starting to break away from the blast them with watts jamming and starting to go with a little smarter stuff when SAC captured me again in the 70s. ALQ-117, ALQ-122, ALQ-155 with empty slots in the receiver for "further expansion, and then just before I retired in 1982 the ALQ-153. Of course everyone knew the plane was going to be replaced by something newer and faster.G What will the Air Force do when they run out of heavy bombers? Switch to FB-22s? http://globalsecurity.org/military/s...raft/fb-22.htm -HJC |
#38
On Fri, 19 Mar 2004 22:22:19 -0800, Henry J Cobb wrote:
Buzzer wrote: Amazing. That was just a dream back in the 70s. SAC was just starting to break away from the blast them with watts jamming and starting to go with a little smarter stuff when SAC captured me again in the 70s. ALQ-117, ALQ-122, ALQ-155 with empty slots in the receiver for "further expansion, and then just before I retired in 1982 the ALQ-153. Of course everyone knew the plane was going to be replaced by something newer and faster.G What will the Air Force do when they run out of heavy bombers? Maybe when the last B-52 is flown to the boneyard the nations of the world will live in peace and harmony? Switch to FB-22s? http://globalsecurity.org/military/s...raft/fb-22.htm -HJC |
#39
Buzzer wrote:
On Fri, 19 Mar 2004 22:22:19 -0800, Henry J Cobb wrote: What will the Air Force do when they run out of heavy bombers? Maybe when the last B-52 is flown to the boneyard the nations of the world will live in peace and harmony? I thought Peace was their Profession? Will we ever see another big manned bomber in the Air Force? If so will it be another big flying wing or will they go supercruise or hypersonic? -HJC |
#40
A radar signature so massive that radar operators disregard it because they know nothing that huge could fly..... I like to call it "anti-stealth"...I think I should patent that.... BUFDRVR "Stay on the bomb run boys, I'm gonna get those bomb doors open if it harelips everyone on Bear Creek" |
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 40 | October 3rd 08 03:13 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 1st 04 02:31 PM |
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 0 | September 2nd 04 05:15 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | May 1st 04 07:29 PM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
