Mode S transponder display to ATC?
Old September 7th 08, 11:23 AM posted to rec.aviation.ifr
Michael Huber[_2_]
Default Mode S transponder display to ATC?
Mxsmanic wrote:
In that case, since pilots and ATC are also generally aware that people on
the ground are listening in, spotters and others listening to the
communications aren't breaking the law, either.
That case has been made, but has not stood up in court. If you are really
that interested, you could dig out the court records.
So is it legal for United to have a channel on the aircraft that allows
passengers to listen to ATC? *Why, or why not?
It is not legal in Germany, and, in fact, UA turns that channel off here.
  #32
Old September 7th 08, 12:23 PM posted to rec.aviation.ifr
Mxsmanic
Michael Huber writes:
I wasn't asking about Germany, I was asking about the UK. Does United turn
the channel off there?
  #33
Old September 7th 08, 06:40 PM posted to rec.aviation.ifr
Tobias Schnell
On Sun, 07 Sep 2008 12:23:14 +0200, Michael Huber
This is contrary to my experience on several UA flights (FRA-IAD).
Tobias
  #34
Old September 7th 08, 07:04 PM posted to rec.aviation.ifr
Mike[_22_]
"Thomas Borchert" wrote in message
Sam,
Not in the U.S.
Source? A source that shows a Garmin GTX330 does not transmit flight ID
data in the US would suffice.
If a tree falls in the woods, but nobody is there to hear it, does it make a
sound?
  #35
Old September 7th 08, 08:28 PM posted to rec.aviation.ifr
Everett M. Greene[_2_]
Peter wrote:
You would however get into trouble if you recorded ATC and then openly
published the recording, e.g. on a website. I don't know why there is
this sensitivity because UK ATC are generally highly professional;
Maybe a parallel to Germany might help. In Germany, tapping into any
communication not intended by the sender to be heard/read/whatever by
oneself is illegal (regardless of whether there are measures taken to
prevent this) under privacy laws. There are some exceptions, but that's the
general rule. ATC communication is only intended for a limited circle of
recipients. Plane spotters are not the intended recipients, thus, they may
not listen.
It has nothing to do with perceived professionality of the ATC people, and
everything with protecting the privacy of ATC and pilots.
The law in the U.S. is/was that it's illegal to intercept
/and reveal/ the content of a transmission. The courts
have repeatedly ruled that intercepting (listening to) a
transmission is not illegal.
It would seem that the German position is rather extreme
in that the people on a given aviation frequency have no
expectation of privacy (and, for the most part, couldn't
care less). Taken to an extreme, it would seem that the
German equivalent of the FAA can't record ATC transmissions
and use them for quality control, training, or violation
proceedings since uninvolved third parties will have been
recorded.
  #36
Old September 7th 08, 09:49 PM posted to rec.aviation.ifr
Mxsmanic
Everett M. Greene writes:
recorded.
In Germany, everything is forbidden, except that which is permitted.
  #37
Old September 7th 08, 09:53 PM posted to rec.aviation.ifr
Viperdoc[_3_]
Anthony, since you don't fly, your comments are again irrelevant. You do not
need a transponder, two way radio, or even a seat belt. You should go back
to the breast feeding forums.
  #38
Old September 8th 08, 01:54 AM posted to rec.aviation.ifr
Sam Spade
Thomas Borchert wrote:
Sam,
Not in the U.S.
I suspect it transmits some form of the Mode S message, but no one is
listening in the U.S.
My friend's Falcon 900 transmits all the Mode S stuff presently required
by the most stringent requirements in your part of the world.
Eventually, it can transmit heading, IAS, and other types of snitch
data. I don't believe the OEM turns on that stuff in his Falcon 900
until the storm troopers order it turned on.
  #39
Old September 8th 08, 01:55 AM posted to rec.aviation.ifr
Sam Spade
Sam,
Not in the U.S.
make a sound?
Good way to put it.
Plus, in the high end gear, the Mode S message data can be implemented
in stages.
  #40
Sam Spade
Are you going to turn it off in MSFS?
Garrecht Mode S transponder - USA? Eric Greenwell Soaring 3 August 20th 07 09:05 PM
New transponder mode S vs. mode C Tom N. Soaring 39 November 7th 06 07:40 AM
KT76C Mode C transponder - what is it worth? Mike Rapoport General Aviation 1 November 21st 04 05:56 AM
KT76C Mode C transponder - what is it worth? G.R. Patterson III Owning 0 November 21st 04 05:56 AM
WTB: Mode C Transponder Chris Batcheller Aviation Marketplace 0 February 21st 04 01:31 PM
