Heathrow crash
Old September 5th 08, 01:01 AM posted to rec.aviation.piloting
Andy Hawkins
Default Heathrow crash
Hi,
See the report into the Heathrow crash has concluded it was 'probably' fuel
line icing? Seems a bit vague to me, slightly worrying a definite cause
couldn't be found.
Interested in what the big iron drivers on here thought?
Cheers
Andy
Old September 5th 08, 02:19 AM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
Andy Hawkins wrote in
Hi,
fuel line icing? Seems a bit vague to me, slightly worrying a definite
cause couldn't be found.
Well, the evidence would have melted away.
I've heard a lot of talk about this accident. this isn't the only 777
that has had thrust issues on approach after a long flight, but it's the
only one who had both wind down at the same time.
I've heard today that the report came out but I can't find it on the
net. I'd be able to comment more fully if I had it to read.
It isn't exactly fuel icing, but what's called waxing. The fuel gets
very gooey near it's freezing point and doesn't flow so good when it
gets into this state. A typical freezing point for fuel is around -39C
and we have a temp gauge to tell us what the temp is in at least one of
the wing tanks.
Long flights in temps of as low as -70C can get the fuel that cold.
Actually, the total temp including skin friction would be about 25
degrees higher than that.
The main lines of defence, mechanically, at least, are that the
hydraulic system radiators are in the fuel tanks. This keeps the
hydraulics form cooking and also warms up the fuel a bit, and the engine
oil is cooled by fuel through a heat exchanger.
Older airplanes, like the older 737s and 727s, had fuel heat. This used
bleed air for short periods of time, usually 30 seconds, and heated up
the fuel in a big way. It had a failing in that if it got stuck on you
had to shut down the engine. That happened to me twice in 727s, but it's
no big deal and the shutdown is precautionary.
For some reason they don't install the bleed air fuel heat on modern
airplanes. I have no idea why, but it would definitely have saved that
BA airplane. I wouldn't be surprised to find they're considering putting
it back in.
The BA flight was polar and very long, so the temps would have been very
low. The crew would have certainly been monitoring the temps. they have
**** all else to do on a long flight like that anyway, and if the temps
were getting low, they would have probably requested a lower altitude,
and/or increased the cruise speed to increase the TAT (total air temp)
Bertie
Old September 5th 08, 02:50 AM posted to rec.aviation.piloting
Lonnie[_3_]
Power snip-
You can almost say more and explain less than your brother Dudley.
But I'm sure you will keep trying.
Old September 5th 08, 02:55 AM posted to rec.aviation.piloting,alt.usenet.kooks
Bertie the Bunyip[_25_]
"Lonnie" @_#~#@.^net wrote in :
Power snip-
Well, obviously al above your head, but then making a paper airplane also
falls into that category.
Yep.
Forever and ever and ever and ever and ever and ever and ever and ever and
ever.
Bertie
Old September 5th 08, 11:51 AM posted to rec.aviation.piloting
Andy Hawkins
Hi,
Good point!
It's still just another interim report I understand.
http://www.aaib.dft.gov.uk/cms_resou...m%20Report.pdf
[snip interesting stuff]
Thanks for that, always interesting to read about possible causes of things
like this and whether any lessons can be learned. As you say, odd that
there's no way of 'warming' the fuel should it become necessary.
Cheers
Andy
Old September 5th 08, 12:05 PM posted to rec.aviation.piloting
Hi,
Good point!
things like this and whether any lessons can be learned. As you say,
odd that there's no way of 'warming' the fuel should it become
necessary.
Yeah, I found mainstream news reports on it after I posted that. They
seem to be insisting it wasn't waxing, but actual ice in the fuel, which
would be a very rare event. i have had it happen to me using Avgas. When
100LL came out first it had a habit of keeping water in suspension. I
nearly came to grief, in fact, as did many others. that problem was
solved with 100LL AFAIK, though. When I heard about the accident first I
thought it might have been duff fuel they got in China, bu tI see no
finger pointing in that direction. in some parts of the world the fuel
is still pretty crude, being fairly wide cut. The engines sem to digest
it with no problem, but fire hazards while fueling are greatly increased
by them and I've often wondered if there are other risks. i have no idea
what they refueled with in China or how carefully the fuel's quality is
looked after.
Bertie
Old September 5th 08, 12:27 PM posted to rec.aviation.piloting
Andy Hawkins
Hi,
looked after.
As you say, sounds odd. Hopefully the final report will shed a bit more
light on things.
Thanks for the info.
Andy
Old September 5th 08, 02:02 PM posted to rec.aviation.piloting
Lonnie[_3_]
"Andy Hawkins" wrote in message
Hi,
looked after.
light on things.
Andy
You should be cross posting this **** to Andy, your hero is.
Old September 5th 08, 01:45 PM posted to rec.aviation.piloting
Stefan
looked after.
Blah blah blah
Old September 5th 08, 01:47 PM posted to rec.aviation.piloting,alt.usenet.kooks,alt.disasters.aviation
Stefan wrote in
which would be a very rare event. i have had it happen to me using
Avgas. When 100LL came out first it had a habit of keeping water in
suspension. I nearly came to grief, in fact, as did many others. that
problem was solved with 100LL AFAIK, though. When I heard about the
accident first I thought it might have been duff fuel they got in
China, bu tI see no finger pointing in that direction. in some parts
of the world the fuel is still pretty crude, being fairly wide cut.
The engines sem to digest it with no problem, but fire hazards while
fueling are greatly increased by them and I've often wondered if
there are other risks. i have no idea what they refueled with in
China or how carefully the fuel's quality is looked after.
Blah blah blah
Oh do tell, fjukktard.
Bertie
BA 777 crash at Heathrow Blueskies Piloting 123 March 18th 08 09:44 PM
Ice accumulation blamed for Heathrow Boeing 777 crash landing? Grumps Piloting 7 January 27th 08 11:55 PM
[Fwd: Concord at Heathrow?] Markus Baur Aviation Photos 3 December 27th 07 12:55 AM
