Silent Super Efficient Propeller!
Old September 6th 08, 10:26 PM posted to rec.aviation.piloting,alt.usenet.kooks
Bertie the Bunyip[_25_]
Default Silent Super Efficient Propeller!
"Lonnie" @_#~#@.^net wrote in :
Power/mercy snip -
Bertie
What a load of bull****.
Nope.
Efficiency is directly related to mission profile. That's not a spin,
is
frigging verbal lomcevak.
If I didn't know better, I would suspect Anthony was forging your
post.
Of course you would. Since you're an idiot, you couldn't understand any
of it. Since you're an idiot, you can't differenatiate between someone
who has a pretty good idea of what he's talking about and a not-even-
wannabe.
it's just who you are.
Be proud, k00k.
Bertie
  #32
Old September 6th 08, 10:27 PM posted to rec.aviation.piloting,alt.usenet.kooks
They do actually, and they can be very efficient indeed.
http://www.youtube.com/watch?v=Nxz1UF67EQI
There's also been the Dyke Delta, and the facetmobile, of course.
Bertie
Why would the Buttlipps be promoting the flying HEEL?
Professional courtesy?
Kindred spirit?
Name association?
Nope, thoght you must be quite familiar with their properties from being
stepped on.
Bertie
  #33
Old September 6th 08, 10:30 PM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
a wrote in
On Sep 6, 11:15*am, Leviterande Leviterande.
Actually in teh begining of the * last century many designers started
building circular aircraft, and all teh reports indicated that the
flying *saucer had advantages as :
easy and slow to fly
almost impossible to stall
highly crash proof
cheap easy to manufacter
if you dont think that is efficieny then I dont know what it is
i read also in leonard G cramps books that during early wing tunnel
tests
the standard wing were *""retricted to be tested with * very limited
AOA"" unlike the circular wings taht have been tested in extreme
angles of attack without stall!!
well, it is been a little offtopic but lets take a look at this
propeller I found and it is patented 2008
it is easy to *contruct too
what do you think?
http://www.freepatentsonline.com/739...linkgrinder.co
m/P
atents/Divided_blade_r_7396208.html
'Lonnie[_3_ Wrote:
;659369']"Bertie the Bunyip" wrote in message
Bertie
Kindred spirit?
Name association?
Leviterande
"Efficiency" in the sense I am using it is in the conventional
engineering terms -- power out divided by power in.
to do what? Travel a distance? Make a top speed? Rate of climb?
That's the point I was making. I was alos using the smae yardstick, just
not for one particualr mission, and high aspect ratio wings do not
deliver in every case.
Bertie
  #34
Old September 7th 08, 08:23 AM posted to rec.aviation.piloting
a wrote in
On Sep 6, 5:24*pm, Bertie the Bunyip wrote:
a wrote
innews:3bdcc9b5-67cc-4c34-a7a2-41e2a744b82d@z
72g2000hsb.googlegroups.com:
On Sep 6, 5:41*am, Bertie the Bunyip wrote:
a wrote
innews:14d9aabc-33a9-4fdf-9ca5-78e407249a02@7
9g2000hsk.googlegroups.com:
On Sep 6, 3:51*am, Bertie the Bunyip wrote:
a wrote in
news:e5fb9dcd-6bd8-42e3-9a50-f6370d188424
@x35g2000hsb.googlegroups.com:
On Sep 5, 6:46*pm, Leviterande Leviterande.
Now woludnt a shorter prop with a bigger chord(and q-tips)
move more a
ir
and thus creating equal thrust as a longer propeller with
thinner chor
d?
when I tried the patented fan it was pretty quiet *however.
How did you try the patented fan?
AS for longer chords? Probably not. Think of the *most
efficien
t
wing
s
for airplanes -- the ones that provide the best lift/drag.
They are long and slender. The same principles hold for
props. You can be sure if wide chords were better they'd be
showing up on experimental aircraft, and they are not.
course.
Bertie
I don't think you'd find these as 'efficient' as conventionally
shaped aircraft, else we'd be seeing competition gliders shaped
this way. Those airplane shapes would have very light wing
loading of course, but huge wetted areas -- think drag.
Yeah, I understand al of that, but the word efficient is one that
is often bandied as some sort of standard, but is just as
misunderstood.
While I know you mean aerodynamic efficiency in it's purest form,
the mission is the yardstick by which you must measure the success
of an airplane. Gliders are good at what they do, but they're as
much a compromise as any other type of airplane. Low aspect ration
machines have a few enormous advantages, not the least of which is
a huge speed range and relatively low drag at low alpha. Span
loading is more relevant than area loading in many ways and
application, depending on what you're trying to get the wing to do
at any given momen, and a low span loading, as in a glider, has to
be paid for with *drag just like any other aerodynamic benifit.
Simply put, the longer the span, the more air you're moving
around. Now, for some applications, this is more efficient, since
by agitating a greater volume air in a less agressive fashion than
a little air, you may, and may is the operative word here, create
less drag in your flight situation.
. As for using that concept for prop blade shape, , where
efficiency is defined in the conventional engineering sense as
power out divided by power in, long and thin blades seem to win
over short and fat.
Depends on the application and what you're asking the blade to do.
Length brings its own problem here again, but in spades, since tip
speeds, particulalry at high cruise speeds, becomes a problem.
There simply are no pat answers in aerodynamics. "Monoplanes are
more efficient than biplanes" for instnace, is an oft touted
example. Simply not true in every aspect. It depends on what
you're asking the airplane to do. Of course, particualrexamples
may be plucked from the air to prove almost any POV here. You
could look at two types of aircraft and compare their performance
with a single yardstick, such as fuel burn, but that doesn't make
one more efficient than another as whole. just on fuel burn. If
the fuel efficient one can't get out of the 800 foot strip it's
parked in and the other one can, then the one that can is the more
efficient machine for it's mission. That's not to say some
airplanes aren't just plain inefficient, but it is a bit
ridiculous to say that just because there's a popular mission and
most airplanes tend to gel in that corner of design that those
types of aircraft are ultimatley the most efficient things in the
sky.
Bertie
The mission that seems best served by short span broad chord
propellers seems to be in the marinas -- long and thin are not
popular there. Even that may be changing, you may have seen a
satellite view of an Ohio class submarine with its screw exposed
recently (the navy goofed, those things are usually shrouded when
they would be otherwise exposed) *and it looked like something that
belonged on an airplane.
Well, my main drive has short span long chord blades. So do most high
bypass fan jets...
Bertie
early on I mentioned relatively low speed GA airplanes, and for sure
recognize the difference fan jets provide. I'm sure you recognize that
the high bypass stuff you drive is a different animal, and really not
unlike the ducted fan with lots of hardware overhead I also
mentioned.
Get thy tongue from thy cheek! Your digression was from Anthony's
manual.
Not really. In fact I wondered if you might be an anthony sock for a
bit!
I just have a bee in my bonnet about emprical statements!
You're not wrong about high aspect ration wings, but you're not
completely right either. You're not going to win a soaring competition
with an airplane with a 1-1 aspect ratio doesn't mean youcan't make it
do something quite respectable.
That Arup had some remarkable performance figures. They were far from
just being a curiosity in the thirties when they were built. They got a
lot of attention in the aviation press and the performance was
remarkable. I have some of them somewhere but just going from memory the
small engined ones, I think it had a 75 HP LeBlond on it, had a speed
range of something like 30-120 MPH. They have some serious drag issues
at low speeds, of course, but this can be turned to advantage, giving a
steep approach so desirable in stol ops.
This is the reason the Navy were interested in the Flying Flapjack
airplanes in the mid 40s. Potentially good carrier airplanes with a very
high cruise speed.
Bertie
  #35
Old September 7th 08, 11:09 AM posted to rec.aviation.piloting
a[_3_]
a wrote in
move more a
ir
thinner chor
d?
efficien
t
wing
s
course.
Bertie
misunderstood.
over short and fat.
sky.
Bertie
bypass fan jets...
Bertie
mentioned.
manual.
bit!
high cruise speed.
Bertie
If you associate me with Mx your judgment is seriously impaired. Keep
an eye on that, and if the manifestations continue seek some
professional help before it's too late.
I seriously doubt the form factors those airplanes suggest for props
would lead to any improvement in propeller efficiency, using the
classical (energy out over energy in) definition. If they did,
hanging one on a C152, C172, or a P140 would improve things like rate
of climb or service ceiling or fuel economy (my Mooney gets about 18
mpg) by about the the same percentage as increased efficiency. There
would be a nice market for such an improvement. My prediction is we'll
continue to see only narrow chord blades in front of us for the next
15 years.
  #36
Old September 7th 08, 02:15 PM
Leviterande Leviterande is offline
Junior Member
First recorded activity by AviationBanter: Sep 2008
Wink
Hi everybody, I just really wish I could view your intersting replies without the very very long "quotes" that come automaticly.. so could you please just delete the unnessesary quotos ?
any way.. the efficiency right now for me is the developed "static thrust" per horsepower" helicopter are good at but their complicated cyclcic and collective mechanincs and the very huge rotors takes down the efficiency( my opinion only) so what i am simply looking for is a simple propeller that is shafted to a motor (with or without gears) that is not too large for its thrust..
q-tips propellers are coming closer to that and that is why the fan I made with side portions was quite compared to other conventional rc propellers
did you check this?:
http://www.linkgrinder.com/Patents/D...r_7396208.html
it is new and simple propeller claimed to produce 200 pounds of static thrust at a 85cm diamter with a 30hp!
as i said I would appreciate if we could talk about efficieny of propellers
thanx
Kalle
  #37
Old September 7th 08, 03:55 PM posted to rec.aviation.piloting
a[_3_]
On Sep 7, 9:15*am, Leviterande Leviterande.
Hi everybody, I just *really wish I could view your intersting replies
you please *just *delete the *unnessesary quotos ?
thrust" per horsepower" *helicopter are good at but their complicated
the efficiency( my opinion only) *so what i am simply looking for is a
propellers *
did you check this?:http://www.linkgrinder.com/Patents/D...r_7396208.html
it is new and simple *propeller claimed to produce *200 pounds of
as i said I would appreciate if we could *talk about *efficieny of
propellers
thanx
Kalle
Thrust has nothing to do with efficiency. If the engine weighed 200
pounds it develops 200 pounds of thrust downward just sitting there.
Horsepower measures work, in common units that would be about moving
33000 pounds a foot every minute (I may be wrong about that number).
You told us the work going in -- that's 30 hp. What is the work coming
out?
Maybe you should define your problem or issue differently. It now
seems to be you're trying to do something with an RC model. What
exactly is your objective? Tell us that, and you'll have a better
chance at getting a useful answer.
My understanding is that RC models have power to burn -- way more than
scale -- but my knowledge of that world is very limited.
Y
  #38
Old September 7th 08, 05:43 PM posted to rec.aviation.piloting
Lonnie[_3_]
Bertie
Bull****, you are just trolling and trying to drift the thread. Get lost
lamer.
  #39
Old September 7th 08, 05:44 PM posted to rec.aviation.piloting
Lonnie[_3_]
You are truly a wonder.
Bertie
Maybe to you, buy you seem to wonder about a lot of things.
  #40
Old September 7th 08, 05:45 PM posted to rec.aviation.piloting
Lonnie[_3_]
wannabe.
Be proud, k00k.
Bertie
Nonsense Kaptain Klueless, I know exactly that you are nothing but a wanna
be troll.
The birth of a quieter, greener plane: 35% more fuel-efficient; Cambridge-MIT Institute's 'Silent' Aircraft Initiative Larry Dighera Piloting 24 November 9th 06 11:05 PM
The "Whirl": More Efficient Rotary Craft? sanman Home Built 5 September 10th 04 04:11 PM
The "Whirl": More Efficient Rotary Craft? sanman Rotorcraft 5 September 10th 04 04:11 PM
Fuel efficient freight planes Jonas Heisenberg General Aviation 6 November 17th 03 02:24 AM
How efficient are our tailplanes? Kevin Neave Soaring 12 October 24th 03 06:22 PM
