Beginner, Parachutes?
Old November 27th 08, 06:58 AM posted to rec.aviation.soaring
Surfer!
Default Beginner, Parachutes?
In message
Frank Whiteley writes
On Nov 26, 1:41*pm, Surfer! wrote:
In message
, Andy
writes
On Nov 26, 6:54*am, Andreas Maurer wrote:
one at 400 ft (non-connected elavator during winch launch).
Wow, that's impressive! *Was the glider in an uncontrolled climb when
the bale out was initiated or had the cable broken?
I heard a story about a guy with an ASW19 who realised the elevator
wasn't connected when winch launching, and what I think I heard was that
he waited until it reached the top of the climb and jumped,
successfully. *The other part of the story was that he had rigged the
glider and correctly connected the tailplane and someone else took it
off for some reason and refitted it without connecting it, and that the
miscreant went on to be an AAIB investigator..
Dunno how much of this (if any) is true though!
Surfer!
Email to: ramwater at uk2 dot net
An RAF member did this in an ASW-20 and landed safey off airport in a
field using trim and flaps.
How could trim make any difference if the elevator was disconnected?
Surfer!
  #32
Old November 27th 08, 08:32 AM posted to rec.aviation.soaring
Ian
On 27 Nov, 06:58, Surfer! wrote:
In message
It works - in theory - if you have a trim tab. I presume that the
ASW-20 does not, though.
Ian
  #33
Old November 27th 08, 03:11 PM posted to rec.aviation.soaring
Andreas Maurer
On Wed, 26 Nov 2008 10:14:17 -0800 (PST), Andy
Wow, that's impressive! Was the glider in an uncontrolled climb when
I can only quote the reply to your posting:
--- snip ---
that
successfully.
--- snip ---
You only need to replace the term "guy" with "girl".
Bye
Andreas
  #34
Old November 27th 08, 03:12 PM posted to rec.aviation.soaring
Andreas Maurer
He used a combination of flaps and airbrakes to trim the 20.
Bye
Andreas
  #35
Old November 27th 08, 05:06 PM posted to rec.aviation.soaring
Surfer!
In message
, Ian
writes
In message
It doesn't sound like the sort of theory I want to try in practise.
Thankfully my glider's elevator is self-connecting.
Surfer!
  #36
Old November 27th 08, 05:07 PM posted to rec.aviation.soaring
Surfer!
In message , Andreas Maurer
writes
Now I can sort of see how that could happen. But I wouldn't like to try
it out!
Surfer!
  #37
Old November 27th 08, 05:54 PM posted to rec.aviation.soaring
Martin Gregorie[_4_]
In message
It works - in theory - if you have a trim tab. I presume that the ASW-20
does not, though.
That's right. An ASW-20 doesn't have trim tabs. However, the flaps do act
as a form of trim, because by changing the effective wing incidence
relative to fuselage datum you're changing the decalage, and hence the
trim.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
  #38
Old November 27th 08, 09:37 PM posted to rec.aviation.soaring
Frank Whiteley
On Nov 27, 10:54*am, Martin Gregorie
In message
does not, though.
trim.
martin@ * | Martin Gregorie
org * * * |
you're right, it was flaps and airbrakes
He got one of those awards for saving an aircraft.
He also didn't presume to try turning but took a field off airport.
Frank
  #39
Old November 27th 08, 09:47 PM posted to rec.aviation.soaring
John Smith
I've read one such incident report, dunno whether it was the same
incident. Point is, most gliders climb just fine on the winch on their
own. Maybe not perfectly, but fine. The pilot waited until the whinch
launch had finished and then bailed out from more or less horizontal
flight. Bottom line is: yes, you can bail out successfully from winch
launch height.
Beginner 4CH Electric RC Helicopter - Easy to fly NYPT Man Home Built 0 October 16th 05 08:31 AM
Beginner 4CH Electric RC Helicopter NYPT Man Rotorcraft 0 October 9th 05 06:43 PM
Another beginner Q Ramapriya Piloting 9 December 31st 04 05:19 PM
suggestion for beginner sunbearpcs Owning 5 January 21st 04 04:35 PM
ASW 24 WL for beginner ? Harry Soaring 37 July 26th 03 02:02 PM
