#31
Here's a reference to complement the DG video and also a discussion of
changes in certification requirements w.r.t. flutter. An interesting read. http://www.dg-flugzeugbau.de/dg1000-flattern-e.html Some of the wording is a bit ambiguous, but the way I read it there are two conclusions that are relevant to this discussion: 1) Holding on to the stick tends to damp out one mode of wing flutter (and perhaps other controls too). It is a mode that is exacerbated by the fact that when the wing flexes up an unbalanced aileron will tend to deflect downward and vice versa. 2) Adding water ballast can decrease the flutter speed. If I read it right the DG-300 had it's Vne reduced due to the test depicted in the video. 9B |
#32
On Jan 5, 4:44*pm, wrote:
Here's a reference to complement the DG video and also a discussion of changes in certification requirements w.r.t. flutter. An interesting read. http://www.dg-flugzeugbau.de/dg1000-flattern-e.html Some of the wording is a bit ambiguous, but the way I read it there are two conclusions that are relevant to this discussion: 1) Holding on to the stick tends to damp out one mode of wing flutter (and perhaps other controls too). It is a mode that is exacerbated by the fact that when the wing flexes up an unbalanced aileron will tend to deflect downward and vice versa. 2) Adding water ballast can decrease the flutter speed. If I read it right the DG-300 had it's Vne reduced due to the test depicted in the video. 9B I'm reaching way back here but I remember flight test aircraft equipped with dampers in the control system, similar to small shock absorbers. The dampers would stiffen up if a control surface started to flutter. The idea was to let the test pilot note the airspeed at onset of flutter without letting it become destructive. The controls felt like they were in molasses but the aircraft was still flyable for the purposes of the test. That might still be a workable strategy for those pushing the envelope. |
#33
On Jan 5, 6:44*pm, wrote:
Here's a reference to complement the DG video and also a discussion of changes in certification requirements w.r.t. flutter. An interesting read. http://www.dg-flugzeugbau.de/dg1000-flattern-e.html Some of the wording is a bit ambiguous, but the way I read it there are two conclusions that are relevant to this discussion: 1) Holding on to the stick tends to damp out one mode of wing flutter (and perhaps other controls too). It is a mode that is exacerbated by the fact that when the wing flexes up an unbalanced aileron will tend to deflect downward and vice versa. 2) Adding water ballast can decrease the flutter speed. If I read it right the DG-300 had it's Vne reduced due to the test depicted in the video. 9B |
#34
On Jan 6, 10:49*am, bildan wrote:
On Jan 5, 4:44*pm, wrote: Here's a reference to complement the DG video and also a discussion of changes in certification requirements w.r.t. flutter. An interesting read. http://www.dg-flugzeugbau.de/dg1000-flattern-e.html Some of the wording is a bit ambiguous, but the way I read it there are two conclusions that are relevant to this discussion: 1) Holding on to the stick tends to damp out one mode of wing flutter (and perhaps other controls too). It is a mode that is exacerbated by the fact that when the wing flexes up an unbalanced aileron will tend to deflect downward and vice versa. 2) Adding water ballast can decrease the flutter speed. If I read it right the DG-300 had it's Vne reduced due to the test depicted in the video. 9B I'm reaching way back here but I remember flight test aircraft equipped with dampers in the control system, similar to small shock absorbers. *The dampers would stiffen up if a control surface started to flutter. *The idea was to let the test pilot note the airspeed at onset of flutter without letting it become destructive. *The controls felt like they were in molasses but the aircraft was still flyable for the purposes of the test. That might still be a workable strategy for those pushing the envelope.- Hide quoted text - - Show quoted text - Another question about high altitude gliding - My understanding is that the potential energy available to the sailplane is height times weight. The potential energy would not vary with altitude. The drag, however, would be less because of the thin air. Therefore would the sailplane travel farther for a given amount of potential energy used?? I have very limited time in the cockpit of jets, but it appeared to me that the fuel flow was much less at altitude while the true airspeed stayed high. More miles for a given amount of energy. Also any comments on the post reporting different indicated air speeds (at different altitudes) (in the flight manual) to achieve best L to D in a jet. I would haved guessed that the best L to D would always occur at the same indicated air speed. On a dual wave flight at 25,000 feet I was warned about the danger of high true air speed at altitude. We were cruising at a about 60 knots IAS. I calculated that was a TAS of about 90 knots. I ask the instructor if he thought our sink rate was what you would expect for a Grob going 90 knots? He said no. 6W |
#35
#36
On Jan 7, 6:36*pm, " wrote:
My understanding is that the potential energy available to the sailplane is height times weight. *The potential energy would not vary with altitude. * Now you have lost me! You'll need to define how height and altitude are independent. Andy |
#37
#39
On Jan 8, 4:06*pm, Eric Greenwell wrote:
wrote: The drag, however, would be less because of the thin air. Under what conditions? At the same *True* airspeed, yes - the drag is less; at the same *Indicated* airspeed, no - the drag is the same. *Therefore would the sailplane travel farther for a given amount of potential energy used?? No, not at the same *Indicated* airspeed. Caveat: there are some small effects from Reynolds number changes, but we can ignore them in the 20,000' and under range (maybe even a lot higher, but I feel safe saying 20K). *I have very limited time in the cockpit of jets, but it appeared to me that the fuel flow was much less at altitude while the true airspeed stayed high. *More miles for a given amount of energy. Too many other variables, like engine efficiency, and was the comparison at the same *IAS*? Let's stay away from airplane comparisons. We have all the information we need to discuss gliders without going there. Also any comments on the post reporting different indicated air speeds (at different altitudes) (in the flight manual) to achieve best L to D in a jet. *I would haved guessed that the best L to D would always occur at the same indicated air speed. Again, too many potential factors, so we should probably stick with real gliders instead far bigger aircraft with engines hanging down that have propellers in them. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * Updated! "Transponders in Sailplanes"http://tinyurl.com/y739x4 * * * New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" atwww.motorglider.org If I am flying at 25,000 feet and want to fly at maximum L to D, would I fly at the same indicated air speed as I would at 2000 feet? Would glide ratio be the same, regardless of altitude? Bill Snead |
#40
If I am flying at 25,000 feet and want to fly at maximum L to D, would I fly at the same indicated air speed as I would at 2000 feet? Would glide ratio be the same, regardless of altitude? Bill Snead Practically speaking, yes. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * Updated! "Transponders in Sailplanes" http://tinyurl.com/y739x4 * New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
| Thread Tools | |
| Display Modes | |
| Question: Standard rate turns, constant rate turns, and airspeed | Robert Barker | Piloting | 5 | April 15th 07 05:47 PM |
| My weird sink drain | AES | Piloting | 11 | April 13th 06 11:17 AM |
| will the CBS forgeries sink Kerry? | Cub Driver | Military Aviation | 3 | September 14th 04 01:12 AM |
| Rounding a turnpoint in sink | CV | Soaring | 13 | July 22nd 04 06:27 PM |
