Extended full-power in small pistons
Old January 3rd 09, 07:22 AM posted to rec.aviation.piloting,rec.aviation.student
Morgans[_2_]
Default Extended full-power in small pistons
wrote My favorite?
When he said he saw no difference between my vidoes posted on You Tube
and MSFX.
Yep. that's "special," no doubt.
One of the insights into his mind came when someone posted links to his
blog, and he wrote on and on about going places, to pick up his imaginary
passengers, to fly to imaginary destination, and then having to wait around
the airport until his passengers came back to leave.
He "really" thinks simming is just as good as going places, and better,
because it is less expensive, and safe. Reality, to him, is just a passing
introduction, but he has never become friends. Wow.
Old January 2nd 09, 11:42 PM posted to rec.aviation.piloting,rec.aviation.student
Paul kgyy
As a few of the people who actually understand this stuff have pointed
out, continuous operation at full power does increase wear and tear.
It has little to do with EGT, because EGTs are generally quite low
under full power. A more serious issue is CHT.
A very common practice with the TCM IO520 is to leave the throttle at
full throughout the climb. This produces a good rich (cooling)
mixture and gets you up to cooler air quickly. Most pilots do reduce
RPM slightly to increase engine longevity and provide better cooling
(higher airspeeds also help here at the expense of rate of climb). A
lot of the turbo guys run 80-90% power at altitudes in the teens.
Mixture is used in cruise (and in climb) as a tool to manage CHT and
fuel consumption.
Old January 6th 09, 10:49 PM posted to rec.aviation.piloting,rec.aviation.student
Bertie the Bunyip[_28_]
Mxsmanic wrote in
The POH for a number of small piston aircraft warn that high power and
prop settings should not be used for extended periods. What counts as
an extended period, and what happens to the engine if these
recommended (or mandatory) limits are exceeded?
You;'re an idiot
Bertie
Full Stalls Power Off w3n-a Soaring 5 December 4th 08 10:29 PM
Full Stalls Power On w3n-a Piloting 0 December 4th 08 02:30 PM
Can hydraulic lifters cause inadequate full power? [email protected] Owning 13 October 23rd 08 07:40 PM
Radio protocol regarding full stops on full stop only nights Ben Hallert Piloting 33 February 9th 05 07:52 PM
4--O-470 pistons,used jerry Wass Aviation Marketplace 0 August 17th 04 05:07 PM
