#31
![]() "Gezellig" wrote in message ... In the past few years, one (supposedly) successful flight training school dumped their Cessna fleet for Diamonds. http://www.eaa-fly.com/Training/Training.html I believe they do not have any aircraft that with standard, "steam" instrumentation. Regardless, the conversation turns quickly to "Is this a good way to go about training for your PPL?" Since most rentals, especially lower priced ones, are Cessna 15x/17x, the transition (backwards so to speak to glass) would appear to be an issue. My expectation is that the majority of newbies to flying look forward to curbing not inflating costs and that they will need to be Cessna (std gauging) prepared not glass panel prepared. Comments appreciated. My best guess is that the new designs will haul about the same payload as a Cessna 152 at about the same speed as a Cessna 172 for a lower cost per mile than either of the other two. That will probably work out for both hobbs time and tach time in the very near future--assuming that it is not already the case. That does not mean that I am in the least bit pleased. Based upon my belief that the LSA standard will form the basis of the next new training fleet, and I remain disgusted by those standards! I believe that the weight limit should have been at least 750Kg instead of 600Kg, the maximum cruising speed should have been at least 130Kts instead of 120Kts, and that the standards should have amended as needed to include the maximum number of type certificates already owned by US manufacturers for w seat aircraft. Peter Comment as requested |
#32
![]() "Gezellig" wrote in message ... On Mon, 26 Jan 2009 18:47:59 -0800, BT wrote: It would be very difficult to get "Renters Insurance" to cover the full hull value and lose of use of the aircraft. "Lose of use" as in "loss of income"? Loss of income.. yes |
#33
#34
On Wed, 28 Jan 2009 16:45:22 -0800, BT wrote:
"Gezellig" wrote in message ... On Mon, 26 Jan 2009 18:47:59 -0800, BT wrote: It would be very difficult to get "Renters Insurance" to cover the full hull value and lose of use of the aircraft. "Lose of use" as in "loss of income"? Loss of income.. yes BT, how is that proven to the adjustor? Past records? |
#35
On Wed, 28 Jan 2009 16:53:23 -0500, Peter Dohm wrote:
Based upon my belief that the LSA standard will form the basis of the next new training fleet, and I remain disgusted by those standards! I believe that the weight limit should have been at least 750Kg instead of 600Kg, the maximum cruising speed should have been at least 130Kts instead of 120Kts, and that the standards should have amended as needed to include the maximum number of type certificates already owned by US manufacturers for w seat aircraft. Peter Comment as requested Peter, why those numbers? I agree but would appreciate your additional comments. |
#36
![]() "Gezellig" wrote in message ... "Lose of use" as in "loss of income"? Loss of income.. yes BT, how is that proven to the adjustor? Past records? It does not have to be proven to any adjuster. All they need to do is be willing to sue the renter pilot. Then the renter has to choose between paying up, or handing the same (or more) money to a lawyer to defend against the claim. Vaughn |
#37
![]() "Gezellig" wrote in message ... On Wed, 28 Jan 2009 16:53:23 -0500, Peter Dohm wrote: Based upon my belief that the LSA standard will form the basis of the next new training fleet, and I remain disgusted by those standards! I believe that the weight limit should have been at least 750Kg instead of 600Kg, the maximum cruising speed should have been at least 130Kts instead of 120Kts, and that the standards should have amended as needed to include the maximum number of type certificates already owned by US manufacturers for w seat aircraft. Peter Comment as requested Peter, why those numbers? I agree but would appreciate your additional comments. Actually, part of it is because I goofed. I should have said 800Kg for the weight--because I wanted my weight to include the common existing basic trainers, such as the 152 and Tomahawk which actually weigh about 760Kg. The other big problem with the weight is that it still seems to press the limits of the available materials, so that many of the LSA aircraft are forced to use a lot of carbon fiber in an effort to give a practical usefull load--and even then it is not enough because so many of the pilots who have a problem medical certification are overweight. Therefore, I strongly suspect that a large proportion of LSA aircraft are simply operated over gross. I also have two problems with the speed range allowed. First, I fail to see any good reason that an entry level aircraft should not deliver a practical speed for travel. The second is safety--the slower an aircraft lands and takes off, the less crosswind it can usually tolerate. In addition to my personal belief in nationalism, it would have been so much simpler to just create the Light Sport Pilot classification to cover 2 seat aircraft that are neither complex nor high performance. That would have allowed the development of a far more capable class of LSA--and one free from the poor initial accident record tat we have experienced. Peter |
#38
![]() "Peter Dohm" wrote in message ... Therefore, I strongly suspect that a large proportion of LSA aircraft are simply operated over gross. I suspect (and this could lead to a dangerous safety culture) that many LSA's really have two gross weights. One gross weight that satisfies the Light Sport regulation, and a "whisper" gross weight at which they really are operated. The actual engineering of the plane may (or may not) actually support that "whisper" figure. Of course if you guess wrong and die, it is on you. Just look at the useful load of the Cessna 162 with a full fuel payload of 346 #. That means that if you have full tanks and a 200# student you have 146 pounds left over for the instructor and the flight bags etc.. I call that a 1 passenger airplane! Vaughn |
#39
![]() "vaughn" wrote in message ... "Peter Dohm" wrote in message ... Therefore, I strongly suspect that a large proportion of LSA aircraft are simply operated over gross. I suspect (and this could lead to a dangerous safety culture) that many LSA's really have two gross weights. One gross weight that satisfies the Light Sport regulation, and a "whisper" gross weight at which they really are operated. The actual engineering of the plane may (or may not) actually support that "whisper" figure. Of course if you guess wrong and die, it is on you. Just look at the useful load of the Cessna 162 with a full fuel payload of 346 #. That means that if you have full tanks and a 200# student you have 146 pounds left over for the instructor and the flight bags etc.. I call that a 1 passenger airplane! Vaughn I agree. Peter |
#40
![]() "Peter Dohm" wrote in message ... Actually, part of it is because I goofed. I should have said 800Kg for the weight--because I wanted my weight to include the common existing basic trainers, such as the 152 and Tomahawk which actually weigh about 760Kg. The other big problem with the weight is that it still seems to press the limits of the available materials, so that many of the LSA aircraft are forced to use a lot of carbon fiber in an effort to give a practical usefull load--and even then it is not enough because so many of the pilots who have a problem medical certification are overweight. Therefore, I strongly suspect that a large proportion of LSA aircraft are simply operated over gross. I also have two problems with the speed range allowed. First, I fail to see any good reason that an entry level aircraft should not deliver a practical speed for travel. The second is safety--the slower an aircraft lands and takes off, the less crosswind it can usually tolerate. In addition to my personal belief in nationalism, it would have been so much simpler to just create the Light Sport Pilot classification to cover 2 seat aircraft that are neither complex nor high performance. That would have allowed the development of a far more capable class of LSA--and one free from the poor initial accident record tat we have experienced. Peter Splendid outline, I couldn't agree more. But it seems to me the deliberately intended to limit all LSA pilots to the fat ultralights that had grown out of control. I don't think they were trying to do anyone a favor, just pencil whip a problem that had grown beyond there desire to control it. |
Glass Panel Longevity | john smith | Piloting | 47 | October 24th 06 04:52 AM |
Glass Panel construction DVD | [email protected] | Home Built | 0 | July 20th 06 05:41 AM |
A Glass Panel for my old airplane? | Brenor Brophy | Owning | 8 | July 25th 05 07:36 AM |
Glass Panel Scan? | G Farris | Instrument Flight Rules | 6 | October 13th 04 04:14 AM |
C182 Glass Panel | Scott Schluer | Piloting | 15 | February 27th 04 03:52 PM |
