#31
That's the joy of F-22 (and -23)--the interceptor dies long before
he/she ever gets within a range that would allow their radar to detect the small RCS. You simply cruise along, passively detecting the enemy and plinking them at your leisure. No sweating, grunting, groaning, Is F22 (jurassicfighter) is a Bomber? |
#32
Active homers also need the return to bounce straight back toward them
too. The very thing stealth is designed to defeat. Quite so,stealth reduces backscatterers very significantly but cannot totally eliminate it. If you can guide an active homer close enough to your target using multistatic tracking data,it will start receiving its own bacscatter .Figthers don't have multistatic radars. Long range missiles cost big $$$. If the need came up (meaning if hell froze over and we actually saw any of these systems in service) we could just slap a small turbojet on the SDB and be back in business. Thats correct but air force tries to develop an UCAV based system. |
#33
One of the big ugly problems with multistatics is that they're *really*
vulnerable to wideband jamming. Put up a half-dozen very low power jammers in their line of sight, and they're screwed. Thats partly true,if you process and analyse polarimetric data forward scatterer contains you can even find out type of material that reflected this signal. (Thats the advantage of german design) |
#34
#35
The joy of stealth, you wake up dead never
knowing that there was an attack on the way. You don't die all tensed up. Joy of multi statics is also very similar,they track stealth platforms,but they dont even know that before its too late. |
#36
#37
It's sounding more and more like those Cold War claims of Amazing
Russian Wonder Weapons that would destroy the West with no trouble at all. With a small difference,Made in USA and other western countries. For the introduction of really "amazing" weapons we all need to wait till next decade. |
#38
![]() You are approaching to the problem from the opposite direction,to solve the problems you described correctly you have to install receiver/processor unit of multistatic system inside every SAM,which is currently technologically and more importantly financially not feasible. But solution is very cheap,though not so excellent like turning SAM missiles into multistatic processors. 1)Multi statics can track stealth platform at extremely long ranges. 2)Stealth platforms designed to reduce backscatter.They reduce backscatter significantly but total elimination of bacscatter is not possible.(Thats the reason why a particular backscatter radar detects conventional aircraft at 100 m but identical sized stealth aircraft only at 5 or 10 miles) If your radar receiver comes close enough to stealth target (or target comes close to bacscatter receiver) at some point backscatterer receiver will start receiving backscatterers from target. So, 1)You are tracking your target precisely using multistatics (You might not even need very precise tracking using multistatics (expensive),If you use the methods used by Serbians,you can detect stealth ,but you cannot track it.(your SAM crews must be lighting fast) 2)If you want to use an semi active system ,turn on guidance radar and aim it according to multistatic radar tracking data. (or if you use serbian style interconnected bacscatterers to the latest known position position ) Do you know what "semiactive" is/means? 3)Fire missiles guide them to target by command guidance Command guidance? I'll bet a HARM would just LOVE that. ,as missile nears to the target missiles own backscatter receiver will be able to receive backscatter signals (not forward scatterers used by multistatics) from its own guidance radar. An active radar seeker on a AAM likely wouldn't work very well against stealh. You'd be better off with an IIR seeker. If you can use an active homer skip step2 and use missiles active seeker as terminal guidance only. A high frequency radar against a stealth aircraft? |
#39
#40
what is good sound proofing for interior?!?! | Rick | Home Built | 12 | May 13th 04 02:29 AM |
How Aircraft Stay In The Air | Sarah Hotdesking | Military Aviation | 145 | March 25th 04 05:13 PM |
Pulse jet active sound attentuation | Jay | Home Built | 32 | March 19th 04 05:57 AM |
The sound of survival: Huey's distinctive 'whop-whop' will be heard again locally, By Ian Thompson/McNaughton Newspapers | Otis Willie | Military Aviation | 0 | February 19th 04 12:01 AM |
F-86 and sound barrier | VH | Military Aviation | 43 | September 26th 03 02:53 AM |
