#31
#32
Dave Doe wrote
It was suggested (stated I spose) by another poster here that "most" landings are autolands. I categorically disagreed with that statement. Air New Zealand do about 1 in 7 autolands. What ratio did you do? Probably about 1 in 20. The company would have liked more, but that took all of the fun out of flying. ![]() Bob Moore |
#33
Robert Moore wrote:
wrote The shuttle does an autoland approach and touches down manually. Not according to Wikipedia..... Well, according to NASA, it does: http://science.ksc.nasa.gov/shuttle/...n_profile.html http://www-pao.ksc.nasa.gov/kscpao/n...andingaids.htm http://www-pao.ksc.nasa.gov/kscpao/r.../1992/1-92.htm -- Jim Pennino Remove .spam.sux to reply. |
#34
On Sat, 07 Mar 2009 00:49:41 GMT, Robert Moore
wrote: wrote The shuttle does an autoland approach and touches down manually. Not according to Wikipedia..... From Wikipedia, the free encyclopedia In aviation, autoland describes a system that fully automates the landing phase of an aircraft's flight, with the human crew merely supervising the process. With 25 years of airline experience flying Boeing jetliners, I would suggest that I know more about "autoland" operations and equipment than either you or MX. More from Wikipedia..... Autoland requires the use of a radio altimeter to determine the aircraft's height above the ground very precisely so as to initiate the landing flare at the correct height (usually about 50 feet). Autoland is highly accurate, and it lands the plane at the same spot on the runway every time with very high accuracy. This is in contrast to manual landings, where touch down points are relatively widely distributed within the Touch Down Zone on the runway. Bob Moore PanAm (retired) the problem here seems to be the inappropriate substitution of "coupled approach" with "autoland" by certain people. |
#35
#36
#37
Just go look it up! wrote
the problem here seems to be the inappropriate substitution of "coupled approach" with "autoland" by certain people. Yep! Bob |
#38
Mxsmanic wrote:
writes: The shuttle does an autoland approach and touches down manually. There's no such thing as an "autoland approach." You can automate the approach, but if the automation doesn't take you to touchdown, it's not an autoland. Funny, the FAA seems to think otherwise: http://www.faa.gov/airports_airtraff...pubs/PCG/A.HTM From the ink: "AUTOLAND APPROACH- An autoland approach is a precision instrument approach to touchdown and, -IN SOME CASES-, through the landing rollout." Emphasis mine. Wrong again. -- Jim Pennino Remove .spam.sux to reply. |
#39
Mxsmanic wrote:
writes: Yeah, right. I know, thanks. It is routine to turn on autoland during approach and turn it off just before touchdown. If you turn it off, it's not autoland. Nope, it is an autoland approach as defined by the FAA in: http://www.faa.gov/airports_airtraff...pubs/PCG/A.HTM -- Jim Pennino Remove .spam.sux to reply. |
#40
Manchester (EGCC) Turkish Airlines TC-JRA | Andrew B | Aviation Photos | 0 | May 29th 08 08:01 PM |
ATC radio for cabin on airlines besides United? | [email protected] | Piloting | 1 | May 1st 06 10:48 PM |
Los Angeles radio tower crash kills 2 | Paul Hirose | Piloting | 178 | August 6th 05 03:46 PM |
Thunderbird pilot found at fault in Mountain Home AFB crash | Ditch | Military Aviation | 5 | January 27th 04 01:32 AM |
Recommendation for Radio, transponder and Altimeter | Ron Natalie | Home Built | 0 | July 8th 03 03:40 PM |
