Seniors USA 2009 Start and Finish notes..... # 711 reporting
Old March 18th 09, 05:30 PM posted to rec.aviation.soaring
Darryl Ramm
Default Seniors USA 2009 Start and Finish notes..... # 711 reporting
On Mar 18, 10:15*am, Tim Newport-Peace wrote:
At 16:15 18 March 2009, Jim White wrote:
Perhaps the simple answer is to mount your colibri on the panel and use
logged altitude reading as your reference for starts, airspace, and
finishes. You do however need to know the difference in feet +/- between
real QNH/QFE and QNE (1013.2). I write this on a sticky.
At 14:31 18 March 2009, Andy wrote:
On Mar 18, 7:00=A0am, Darryl Ramm *wrote:
It is my impression that many piltos with built in loggers like the
Cambridge 302 do not understand that the flight recorder is using
cockpit ambient pressure and not the static line-in on the rear of
instrument (only used for airspeed calculations). This is a
requirement to prevent the pilot being able to connect to the static
line and tamperer with logged pressure altitude.
I'm aware of that but I see now that what I wrote may be ambiguous.
Perhaps this would have been better:
"loggers (which cannot have an external static connection) will read
lower than
an altimeter which has an external static connection. "
Andy
Just to put the record straight, since AL4 (25 May 2001) Pitot Static MAY
be used. However some older designs may still be using Cockpit Static.
/*Quote
Pressure Altitude - In a GNSS FR, this is a five numeric group indicating
the pressure altitude in metres with respect the International Standard
Atmosphere (ISA) used in aviation, to a sea level datum of 1013.25 HPa.
The pressure recorded in the *.IGC file may either be "cockpit static"
(vented within the FR box), or use a tube connection to the pressure from
glider instrument system static tubing. If the pressure altitude signal
within the FR is used for other purposes such as cockpit instrument
readings which can be set to other datums such as
QNH or QFE, a one-way transmission system must be used from the sensor so
that the IGC file always records the required ISA to the 1013 sea level
datum irrespective of other settings used for flight instruments. The
permitted use of instrument-static is intended for a GNSS FR mounted in
the instrument panel. With such an installation, an OO as part of the
inspection of the FR installation must check the tubing and the pressure
connection to the FR to ensure that they will be out-of-reach of the
aircrew in flight. This is to prevent alteration to the IGC-file pressure
altitude record by any method. (AL4)
Unquote*/
Tim Newport-Peace >
Skype: specialist_systemshttp://www.spsys.demon.co.uk/icom.htm
Oops. Thanks.
And hopefully the ultimate thing is to point people to their the IGC
approval document for their flight recorder (see (http://www.fai.org/
gliding/gnss/), all the ones I've looked at (C302, LX series, and even
the new Triadis) use the cockpit ambient pressure. Without looking
though all the approval documents, does anybody know of ones that do
use the static line?
Darryl
  #32
Old March 18th 09, 05:31 PM posted to rec.aviation.soaring
Also, an evil thought occurred to me - does Winscore check to see
whether you reset the logger altimeter between when you finish and
when you land? It strikes me you could finish really low then crank
the altimeter setting down 500 feet before you land. I'd guess someone
thought of that already and eliminated that opportunity for mischief.
For start and finish altitudes, Winscore checks the pressure altitude
as recorded in the secure data logger. I don't know of any secure
loggers that would permit you to "reset the logger altimeter" between
finish and landing.
Guy Byars
  #33
Old March 18th 09, 05:42 PM posted to rec.aviation.soaring
Karl Striedieck
The time saved by trying to finish right at the min finish height is
miniscule compared to the time used in getting that extra "waisted" altitude
in the last thermal.
The bottom line is that pilots should aim for around 150 feet high and
during the last couple miles spend 99% of the time looking
right/left/up/down/forward/back. As pointed out earlier, monitoring the
four-mile calls is useful.
Karl Striedieck
"Darryl Ramm" wrote in message
cockpit ambient pressure and not the static line-in on the rear of the
lower than
Andy
Andy, I had the sense you did know this. My comment was really to the
overall thread. The near universal situation will be IGC logger with
ambient cockpit pressure (an IGC requirement) and an altimeter with
ships' static (a type certification/airworthiness requirement for many
(all?) gliders). In which case the warnings from the CD make perfect
sense.
A Cambridge 302 or other IGC flight recorder that displays pressure
altitude or a PDA with pressure altitude being displayed from a logger
is the thing to look at if close. But looking for traffic better be
more important. Doing a comparison between an altimeter and Cambridge
302 pressure altitude display at different speeds would be interesting
and something I want to do for other reasons (but related to ambient
cockpit pressure induced altitude errors).
Hopefully most pilots will understand many gliders will have three
static sources, the fuselage static lines (for altimeter and ASI),
static from a multi-function probe (usually for flight computers/
direct reading/digital varios) and ambient cockpit static (used by IGC
fight recorders). Pretty nice redundancy and isolation provided by all
that.
Darryl
  #34
Old March 18th 09, 05:49 PM posted to rec.aviation.soaring
[email protected][_2_]
On Mar 18, 12:06*pm, wrote:
On Mar 18, 12:47*pm, Darryl Ramm wrote:
On Mar 18, 9:33*am, "
Oh great, now we are down to fiddling with altimeters, closing/opening
cockpit vents, and staring at a variety of altitude readouts (I
personally watch both the mechanical altimeter, after tapping, and my
SN10 digital readout) while on short final glide.
I still think there is a better (safer, easier) way, just haven't
figured it out yet.
Kirk
66
And the issue there is that most SN10s will be installed with the
static connected to the ship's static (that's what the manual says,
and is probably best for accurate wind calculations etc.) and AFAIK is
not able to display any pressure altitude delivered via NMEA from an
attached IGC flight recorder. So the SN10 is normally not sensing
cockpit ambient and unable to report what any attached IGC flight
recorder is sensing.
Hopefully the take away here is more allow a saftey margin and do soem
tests before hand rather than watch some stupid display while killing
yourself and others at a finish.
Darryl
Maybe us cheap guys are doing better with this. *My PDA is hooked up
to my logger and uses its output for altitude, so in theory I'm seeing
what's going into the logger file, no matter what static source is
being used for that (or GPS altitude for that matter). *All I have to
do is
just fly the final glide numbers so I arrive above the required finish
altitude.
-- Matt- Hide quoted text -
- Show quoted text -
Are you sure? My PDA is hooked to my IGC logger but gets only GPS
altitude, not the uncorrected pressure altitude that goes on the .igc
logfile and is used to score the finish (after correction for takeoff
pressure delta).
Kirk
66
  #35
Darryl Ramm
Darryl
Ugh - now I have to go run experiments to see what generates the
lowest cockpit ambient pressure across different speeds and vent
configurations.
Since the official altitude for finishes is the logger baro altitude I
just fly that. I guess I could worry about the 100 feet or so of
pressure error - it's worth maybe 15-20 seconds in theory. If I were
going to reset my logger's altimeter I'd want to do it at the start of
my final glide, not the end. *I suppose it would be okay for the CD to
call altimeter setting in addition to winds for finishers, but I'm not
sure it's worth the trouble.
Also, I don't recall whether my computer uses baro or GPS altitude for
calculating final glides, but it has never been so far off from the
logger baro readout that I can't just do what UH suggests in the last
mile or so - bleeding off speed to hold altitude as indicated by the
302 display, which is quite easy to scan.
The comments by UH, BB and others are REALLY important - staying on a
predictable track during the last part of final glide is a critical
safety practice. Thrashing around when you are low and fast is a
recipe for something really bad.
9B
Winscore usually can't tell. The QNH setting is often not in an IGC
file and the recorded pressure altitude is always referenced to
standard pressure.
And before Tim corrects me (again) there is an "ATS" extension for
recording the QNH setting and a flight recorder could write that in an
E (pilot event) record to keep track of the settigns during flight. I
have no idea what flight recorders do this if any.
Darryl
  #36
Old March 18th 09, 06:07 PM posted to rec.aviation.soaring
Darryl Ramm
On Mar 18, 10:49*am, "
figured it out yet.
Kirk
66
Darryl
do is
altitude.
Are you sure? *My PDA is hooked to my IGC logger but gets only GPS
pressure delta).
Kirk
66
It can depends on the flight recorder, settings in the flight recorder
as to what NMEA data is is outputting, PDA software features and
settings.
In my case with a C302 and SeeYou Mobile I don't think I can control
this, the C302 will put out pressure altitude in the NMEA stream and
SeeYou Mobile will use and display this pressure altitude.
Darryl
  #37
Old March 18th 09, 06:42 PM posted to rec.aviation.soaring
hretting
KIRK, If you go back a few replies, I close the vents to reduce noise.
At 130 kts and approaching the finish point, I don't want to miss an
important radio call. It was simply part of a pre-final glide cockpit
flow, and had nothing to do with all the altimeter/finish height
discussion.
Also, possibly crossing the finish 100' high by making a final glide
correction to the altimeter , as I have suggested will not have a
measurable impact on being a racing champion. Density altitude
increases as the day warms and 125' happens to be the normal , no TBs
at the field, everything okie dokie correction.
R
  #38
Old March 18th 09, 06:45 PM posted to rec.aviation.soaring
Peter Wyld[_2_]
pressure delta).
Kirk
66
What Software, What Logger ?
  #39
Old March 18th 09, 07:06 PM posted to rec.aviation.soaring
Mike the Strike
So, if I can summarize, the new start and finish rules result in the
following:
1) Your instruments may not show you the distance from the start to
the first turn.
2) Your instruments may not indicate the location of the finish.
3) Although it's a race, you may have to slow down at the finish.
Am I alone in thinking this a bit dumb-ass?
Thank goodness for OLC!
  #40
Old March 18th 09, 07:16 PM posted to rec.aviation.soaring
pressure delta).
To determine the altitude for finish scoring purposes, Winscore (as
per SSA rules), uses the more favaorable of the takeoff pressure delta
and landing pressure delta.
Guy Byars
Last Day Seniors USA 2009 #711 reporting [email protected] Soaring 0 March 15th 09 02:12 AM
Day 2 Seniors USA 2009 711 reporting. [email protected] Soaring 4 March 13th 09 01:10 AM
Seniors USA 2009 #711 reporting. [email protected] Soaring 1 March 9th 09 02:03 AM
# 2 Day 05 Seniors USA # 711 reporting [email protected] Soaring 2 March 11th 05 07:36 PM
Rules for 1000k with start/finish at midpoint. Andrew Warbrick Soaring 2 August 10th 04 05:04 AM
