#31
It will be important for Soaring pilots to know whether the recent
crashes were from a spinning or a spiraling ship..That most likely can be determined by the type of impact. Simply, every pilot should recognize and recover from an incipient spin. If he or she is not sure, one should be shown in a Blanik or similar spin happy ships. A glider in flight should really never come close to a spiral, since it is approaching red line fast. I feel the reason gliders get into spirals is not only the lack of spin recognition of the pilot, but poor flying technique. Yaw string, airspeeds, coordination. Of course all those problems can happen to a pilot becomming sick, passing out or similar. I have programmed myself to immidiately pull the trim all the way back and let go of the controls. Not sure if that would help, depends on the ship? soarski |
#32
On Jul 3, 7:36*pm, soarski wrote:
It will be important for Soaring pilots to know whether the recent crashes were from a spinning or a spiraling ship..That most likely can be determined by the type of impact. Simply, every pilot should recognize and recover from an incipient spin. If he or she is not sure, one should be shown in a Blanik or similar spin happy ships. A glider in flight should really never come close to a spiral, since it is approaching red line fast. I feel the reason gliders get into spirals is not only the lack of spin recognition of the pilot, but poor flying technique. Yaw string, airspeeds, coordination. Of course all those problems can happen to a pilot becomming sick, passing out or similar. I have programmed myself *to immidiately pull the trim all the way back and let go of the controls. *Not sure if that would help, depends on the ship? soarski The programing myself, I meant If I had the time or the chance, to do so before getting incapasitated. |
#33
If may, I would like to get off on a bit of a tangent, i.e. the
original subject stated in the title of this thread. One of the problems that I have observed with students and a few high time pilots alike is the following: when presented with a spin or a spiral dive, mis-diagnosing the problem and applying the wrong recovery. To some who experience these maneuvers infrequently, they appear similar enough to bring about confusion and as you know, applying the wrong recovery can get grim. I believe airspeed, sound and G are the keys with the latter two very important. Some are so confused by the ground spinning around that they don't think about looking at the airspeed indicator. But they do seem to sense if it is relatively quiet or loud and if they are experiencing more than 1G. A thorough ground briefing on the differences and then demonstrating both on the same flight really helps. Then follow that with a lesson where they must make the diagnosis and apply the proper recovery. This has worked for me. I would enjoy hearing from others who have thoughts on this very important subject. Paul ZZ 8 wrote: Okay guys, here's your new thread. Please... Del asks "how well will pilots react if they unexpectedly get into a spin or a spiral dive? Normally you gird your loins up first before doing a deliberate spin!" Answer: this depends on the pilot, of course. By the time you are gaggle flying, thermaling up off ridges or flying in competition it damned well better be automatic, reflexive. The only point to doing deliberate spins by stalling straight ahead and kicking rudder is to get some sense of how the sailplane behaves and what it takes to recover from a fully developed spin. It might also help you develop some sense of spin entry feel, but unintentional spins normally come from some combination of turning, skidding flight, gusts, etc. Oh, there's also the famous pilot who transitioned from 15m to std class and early on charged into a gaggle, pulled up, reached for the "flap" handle and spun out of the gaggle with spoilers deployed. UH, hUH! But I won't mention any names :-). I love that story. What you should practice is realistic spin entries from thermaling turns and simulated pattern turns gone bad. Do 'em in all aircraft configurations. In flapped ships the behavior changes quite a lot. If you are fooling with CG location, check that out too. Your responses can and should become fast and accurate. You should do this until you aren't "girding your loins", you aren't tense. No panic. Aircraft departs controlled flight: so what, you deal with it, get it back. regards, Evan Ludeman / T8 |
#34
In message
, soarski writes snip A glider in flight should really never come close to a spiral, since it is approaching red line fast. I feel the reason gliders get into spirals is not only the lack of spin recognition of the pilot, but poor flying technique. Yaw string, airspeeds, coordination. You could say exactly the same thing about spins. Of course all those problems can happen to a pilot becomming sick, passing out or similar. I have programmed myself to immidiately pull the trim all the way back and let go of the controls. Not sure if that would help, depends on the ship? soarski I suspect you are being very optimistic that you could do anything to avert disaster. You might pass out, or you might be in so much pain that you are totally incapacitated. I can't see what the point of trimming all the way back is, either. -- Surfer! Email to: ramwater at uk2 dot net |
#35
On Jul 4, 12:32*pm, n7ly wrote:
I've experienced such episodes and no longer will "explore" that part of a flight envelope. An appropriate phrase for such activity is "practice bleeding". Hey at least we can do RTSL aborts ok! |
#36
On Jul 4, 7:06*pm, Surfer! wrote:
I suspect you are being very optimistic that you could do anything to avert disaster. *You might pass out, or you might be in so much pain that you are totally incapacitated. *I can't see what the point of trimming all the way back is, either. If you trim well back and add as much drag as possible using airbrakes, wheel down etc and get off the controls then you will probably get a fairly stable and low speed "benign spiral" which may even be survivable on contact with the ground depending on what you hit. Try it in your own ship at altitude and find out. |
#37
I have already been flamed once for bringing up this subject in the
original Parowan accident thread, as being irrelevant to highly experienced competition pilots! However for those of them who are not also instructors, that experience consists of many hundreds or thousands of hours of either flying straight or circling in thermals! How well would they cope in the event of a sudden and unexpected upset? It is important to be able to differentiate between a spin and a spiral dive because the recovery actions are quite different. In a spin, the nose will often go well down, despite the fact you are stalled, the ground will rotate in front of you, and there will be very little build up of g. The ASI is likely to totally misread due to the amount of yaw present; it may even go back though zero and show a very high reading. In a spiral dive, the nose may remain fairly well up, despite the fact you are not stalled, and airspeed and g will build up rapidly and continue to do so. In many ways spiral dives are more dangerous as you risk going through Vne and breaking up the glider. Spins in themselves are not dangerous at all, at least as long as you recover before hitting the deck. Just a quick reminder of the standard recovery actions: Spin: 1) Centralise the ailerons 2) Apply full outspin rudder 3) Move the stick steadily and progressively forward until the spin stops 4) Centralise the rudder and ease out of the dive Spiral dive: 1) Keep the stick fairly well back and use the controls normally to reduce the angle of bank - a spiral dive is just a very overbanked turn. IMHO spins and spiral dives should be a part of periodic check flights. Derek Copeland (UK Gliding Instructor) At 04:15 04 July 2009, ZZ wrote: If may, I would like to get off on a bit of a tangent, i.e. the original subject stated in the title of this thread. One of the problems that I have observed with students and a few high time pilots alike is the following: when presented with a spin or a spiral dive, mis-diagnosing the problem and applying the wrong recovery. To some who experience these maneuvers infrequently, they appear similar enough to bring about confusion and as you know, applying the wrong recovery can get grim. I believe airspeed, sound and G are the keys with the latter two very important. Some are so confused by the ground spinning around that they don't think about looking at the airspeed indicator. But they do seem to sense if it is relatively quiet or loud and if they are experiencing more than 1G. A thorough ground briefing on the differences and then demonstrating both on the same flight really helps. Then follow that with a lesson where they must make the diagnosis and apply the proper recovery. This has worked for me. I would enjoy hearing from others who have thoughts on this very important subject. Paul ZZ 8 wrote: Okay guys, here's your new thread. Please... Del asks "how well will pilots react if they unexpectedly get into a spin or a spiral dive? Normally you gird your loins up first before doing a deliberate spin!" Answer: this depends on the pilot, of course. By the time you are gaggle flying, thermaling up off ridges or flying in competition it damned well better be automatic, reflexive. The only point to doing deliberate spins by stalling straight ahead and kicking rudder is to get some sense of how the sailplane behaves and what it takes to recover from a fully developed spin. It might also help you develop some sense of spin entry feel, but unintentional spins normally come from some combination of turning, skidding flight, gusts, etc. Oh, there's also the famous pilot who transitioned from 15m to std class and early on charged into a gaggle, pulled up, reached for the "flap" handle and spun out of the gaggle with spoilers deployed. UH, hUH! But I won't mention any names :-). I love that story. What you should practice is realistic spin entries from thermaling turns and simulated pattern turns gone bad. Do 'em in all aircraft configurations. In flapped ships the behavior changes quite a lot. If you are fooling with CG location, check that out too. Your responses can and should become fast and accurate. You should do this until you aren't "girding your loins", you aren't tense. No panic. Aircraft departs controlled flight: so what, you deal with it, get it back. regards, Evan Ludeman / T8 |
#38
ZZ wrote:
One of the problems that I have observed with students and a few high time pilots alike is the following: when presented with a spin or a spiral dive, mis-diagnosing the problem and applying the wrong recovery. To some who experience these maneuvers infrequently, they appear similar I was still a fairly unexperienced pilot when I received my primary aerobatics training. My third or so spin (which means that I was really unexperieced) changed unexpectedly into a spiral dive after one rotation or so, something I had never experienced before. I needed about half a second to recognize the situation and apply the correct controls. Spin and spiral dive feel completely different. |
#39
While I agree that practice recovering from "realistic entry" spins
and/or spiral dives is highly desirable, there are real problems with trying to do so. For example, my LS8-18 POH specifically states "Aerobatic flight not approved". My club's Grob 103s are approved for spins, but the club insurance policy prohibits doing them. There is one nearby commercial operator who offers an introductory aerobatics course using a Blanik L-13AC, but as he wants to get out of the flying business that option won't be available much longer. -John |
#40
For those of you who think spins can only be entered from almost straight
flight in a nose height attitude with a bootful of rudder, have a look at the following video: http://www.youtube.com/watch?v=_xCct8cDtyk This was an attempted downwind landing after a winch launch cable break at 80 metres (260ft). Note that the glider is never in a nose high attitude. The pilot may have tried to rudder it round the low final turn, you can't really tell from the quality of the video, but there was a reasonable amount of bank on. What finally seems to have triggered the spin was opening the airbrakes half way round the final turn. Note also the amount of of rotational energy stored up once the spin developed, with the glider continuing to rotate even after it crashed into the ground. Reducing the rotation rate is the first action in recovering from a fully developed spin, i.e. full outspin rudder. At the wing drop or incipient stage, it is only necessary to move the stick forward to unstall the wings and prevent a full spin from developing. This will cost the minimum amount of height. The full spin recovery at this point may actually cause a flick in the opposite direction as well as delaying the recovery. So it's basically move the stick forward, maybe using the rudder as well to minimise any build up of yaw, and then sort out the bank and attitude by using the controls normally once the airflow is re-attached to the wings. Derek Copeland |
Any Spins Lately?? | Ol Shy & Bashful | Piloting | 28 | September 6th 07 10:22 PM |
Found on another site 08-747 Spiral stairs to lounge 08.jpg (1/2) | Just Plane Noise[_2_] | Aviation Photos | 0 | August 10th 07 02:39 PM |
Found on another site 08-747 Spiral stairs to lounge 08.jpg (2/2) | J.F. | Aviation Photos | 0 | August 10th 07 02:14 PM |
Spiral Dives Explanation. | Sandy Stevenson | Soaring | 6 | August 26th 05 12:34 PM |
Paraglider spiral dive, throws chute and ends up in the trees | Stewart Kissel | Soaring | 8 | March 1st 05 10:04 PM |
