#411
Mxsmanic wrote:
Le Chaud Lapin writes: That, coupled with the delay inherent in the response of many engines and the delay in the airframe's reaction, makes it easier to fly if the engine can be heard. Fortunately, MSFS handles engine sounds in a fairly consistent and predictable way. No it doesn't, and this is not rec.aviation.simulation. -c Pilot, MSFS player. |
#412
Mxsmanic wrote:
writes: Did you read my post? Did you forget the fact my vacuum system wasn't working? How can I trust the instruments? You don't need vacuum for electric instruments. Once again you're totally clueless. Your Directional Gyro is vacuum driven. If you only needed electric instruments to fly, your primary instruments wouldn't be pitot-static. If you have an electrical problem, bus failure or inflight fire, you might lose all your electrical instruments. If you have no instruments and you're in IMC, you have a big problem. Only if you don't know how to use your radios and know which senses to trust. Not when the vacuum system is broke. I just experienced it yesterday. Don't fly IFR until it's fixed. The problem likely happened while he was in flight. In the real world, you don't get to hit "ALT" and fiddle with your settings until things works. Ah, why do I bother with you? You ask questions just to contradict literally everybody who answers them regardless of the experience they have or the official sources they quote. -c |
#413
Mxsmanic wrote:
To capture the glide slope, you watch the needles on your instruments. That's right. Bill Gates just miracles the rest of the approach into place. Applying power will not accelerate you downhill. Point one of your toy airplanes into an 70-degree descent and apply full power. Student pilots, consult your FAA Airplane Flying Handbook, Chapter 3, Page 19: "Through a wide range of nose-low attitudes, a descent is the only possible condition of flight. The addition of power at these attitudes will only result in a greater rate of descent at a faster airspeed." By the way, I'm no longer talking to MXNumbnuts here. He's a washout and a non-pilot. I'm talking to student pilots who might be led astray by his ignorance and misinformation. -Chris Gattman Commercial Pilot, Instrument, ASEL Advanced Ground Instructor |
#414
"gatt" wrote in message
. .. Point one of your toy airplanes into an 70-degree descent and apply full power. I did that last night in MSFS. They got it wrong. |
#415
Mxsmanic wrote:
Did you miss the part about the trim setting in a nose down position? The above answer is WRONG when you don't have the airplane configured correctly. Sorry, I try to keep the airplane configured correctly, so I don't have much experience with incorrect configurations. All of the sources I've consulted contradict all that you are saying. I have no reason to believe that you are more reliable than all those other sources. Name one. For example, I continue to name and quote the FAA Airplane Flying Handbook, FAA-H-8083-3A, and you don't respond to those posts. Meanwhile, you don't cite your sources, so I suspect that you are a liar. -c |
#416
Jay Honeck wrote:
In normal instrument flight, pilots are trained to ignore what their body is telling them. Not exactly. I was told to understand and be able to recognize various physiological illusions, but I was told NOT to ignore others. For example, if my ears--my body--tell me that the prop or engine is winding up, I might be experiencing a change in power, airspeed or a rapid descent even though the pitot-static instruments are not moving? To extend this logic, if my eyes--my body--tell me that there's a mountain in my way, do I ignore it just because the altitude indicator is stuck on 12,000? If my nose--my body--smells smoke or burning oil but the engine instruments don't show a problem, do I ignore my senses? If all of a sudden I feel like I weigh 500 pounds or an unbelted passenger is floating around the cabin, odds are something isn't right. -c Commercial Pilot, Instrument, ASEL Advanced Ground Instructor |
#417
Mxsmanic wrote:
Steve Foley writes: If the nose is pointed down (going downhill) , and you increase power, you WILL descend faster. Your increased speed will produce more lift, which will tend to raise the aircraft, slowing the rate of descent and potentially leveling the aircraft or producing a climb. So just remember, everybody, if you're at 500 feet in a spiral dive, and/or you're 500RPM past VNE, just increase power. Alternatively, you can hit PAUSE, push the MAP icon and simply add a few thousand feet to your altitude. "Through a wide range of nose-low attitudes, a descent is the only possible condition of flight. The addition of power at these attitudes will only result in a greater rate of descent at a faster airspeed." FAA-H-8083-3A 3-19. But, hey, what does the Federal Aviation Administration know about anything? -c |
#418
terry wrote:
On May 18, 11:01 pm, "Jay Honeck" wrote: Third, and most likely alternative: he's just stupid. MX is many things. Persistent, stubborn, blunt, thick-skinned, willing to argue that black-eyed-peas are really black-eyed-beans, yes. Occasionally annoying, often entertaining (mostly because of the responses he obtains), always willing to come back for more. He's like a Weebil that won't fall down. But stupid? I don't think so. -- I agree , definately not stupid, probably well above average IQ .A vertible human sponge of information. What he lacks--among a lot of things--is the ability to take the information that he learns into a true understanding of those concepts. The power-is-altitude thing is an example. If you point a Cessna 172 or a 747 straight at the ground and apply full power, there are a couple of very obvious reasons why this will not result in a climb, and these can even be demonstrated in a flight simulator. -c |
#419
Mxsmanic wrote:
writes: Out of 825+ flight hours I have flown, 59.4 were in IMC, so I would believe I am reasonably qualified to stress the importance of the above based on personal experience even though I am not an instructor. Perhaps when you have 500 hours in IMC, Perhaps when you have .005 hours in IMC, anybody here will give a damn what you suggest. -c |
#420
A Lieberman wrote:
On May 18, 11:14 am, Mxsmanic wrote: mplacency has no room in a cockpit of a real airplane. MSFS, yes you can be complacent, no big deal. In a real airplane that leaves the real ground, it doesn't work that way, VFR or IFR. TRUST BUT VERIFY.............. I talk from experience from using MSFS and flying a real airplane. Can you? I can, Lieberman. You are correct. -c |
DC-3 parts to give away | Robert Little | Restoration | 2 | November 23rd 06 03:30 AM |
Who can give a checkout? | Mark S Conway | General Aviation | 2 | May 9th 05 12:15 AM |
Winch give-away | KP | Soaring | 6 | January 11th 05 08:04 PM |
Did you ever give up on an IR? | No Such User | Piloting | 24 | November 26th 03 02:45 PM |
FS 2004 give away | Ozzie M | Simulators | 0 | November 23rd 03 03:50 PM |
