#441
"Ken S. Tucker" wrote in
: On May 19, 6:16 pm, Mxsmanic wrote: ... No. Radios or not, if you have no instruments in IMC, you're doomed. Your radio will not help you, and you cannot trust your senses. I disagee. If all Instruments go dead, go to magnetic compass for heading, even in a fog, that's SOP. No, it isn't. Maintaining altitude is "seat of pants" thing, so what? Set cruise RPM and feel airspeed. Another idiot. Between the two of you you couldn't get a chuck glider airborne. Bertie |
#442
On May 17, 7:59 pm, "Ken S. Tucker" wrote:
I was a fairly good gymnast, so my orientational skills are likely a bit better than average. Ken Your superior orientational skills are just as useless as everyone else's ordinary orientational skills when in IMC. Dan |
#443
Mxsmanic wrote in
: gatt writes: DON'T CONTRADICT ME. I FLY PLANES AND YOU PLAY VIDEO GAMES. IF YOU DON'T KNOW THE DIFFERENCE BETWEEN "GRAVITY" AND A "SENSATION", THEN GO JUMP OFF A BRIDGE. Sounds like an epitaph. Be careful up there. I QUOTED YOU THE LITERATURE. SPECIFICALLY, FAA-H-8083-3A: IE, The Federal Aviation Administration Airplane Flying Handbook, chapter 3, page 2. I've read the literature, thanks. The FAA knows a whole hell of a lot more about flying than you, regardless of what you claim you've read. No doubt. But I'm not debating this with the FAA. You aren't debating, period, you're just being an asshole, as always. Bertie |
#445
Ken S. Tucker writes:
I disagee. If all Instruments go dead, go to magnetic compass for heading, even in a fog, that's SOP. If you have a compass, all instruments are not dead. However, that won't be enough in IMC. Maintaining altitude is "seat of pants" thing, so what? Set cruise RPM and feel airspeed. That isn't possible. |
#446
Mxsmanic wrote in
: Ken S. Tucker writes: I disagee. If all Instruments go dead, go to magnetic compass for heading, even in a fog, that's SOP. If you have a compass, all instruments are not dead. However, that won't be enough in IMC. Do tel, what is, fjukkwit? Bertie |
#447
On May 18, 3:19 pm, terry wrote:
Would love to know what your sources are on that information MX. in all the aircraft I have flown both the AI and DI were powered from the same vacuum pump and the pump is the most common cause of failure of gyroscopic instruments. How do I know that? not from any books I have read, and I have many on aviation, but from first hand advice from several flying instructors, and actually had a vacuum pump failure in a Warrior on one of my PPL flight tests ( and you are not allowed to ask why I had more than one test :) ) We have no vacuum pump failures anymore. Just gyro failures. Cessna now requires a pump replacement every 500 hours, or a pump with an inspection port that can be replaced when the vanes wear to certain point, which takes around 1100 hours on a Lyc, less on a Continental because of the higher rotational spped of the pump on the Cont. It's almost always vanes worn beyond limits that cause pump failure, or rotten and breaking-up vac hoses that release junk into the pump and lunch it. Cessan wants those hoses replaced every 10 years. Now you know why. Of course, so many owners and mechanics ignore the manufacturer's requirements that pump failures will continue to be a major problem. Dan |
#448
On May 19, 6:54 pm, Mxsmanic wrote:
Ken S. Tucker writes: I disagee. If all Instruments go dead, go to magnetic compass for heading, even in a fog, that's SOP. If you have a compass, all instruments are not dead. Well duh, it's a magnetic compass in a fluid. However, that won't be enough in IMC. Is for me. Maintaining altitude is "seat of pants" thing, so what? Set cruise RPM and feel airspeed. That isn't possible. Sure it is. As long as you're not accelerating, which is something that can be sensed by audio RPM , the magnetic compass can operate as an artificial horizon too, because it's like a plumb-bob. It's of course, independant of operating systems. IIRC, the magnetic compass is on pre-flight check list, date of calibration and ascertain operation on taxi. Ken |
#449
Ken S. Tucker wrote:
On May 19, 6:54 pm, Mxsmanic wrote: Ken S. Tucker writes: I disagee. If all Instruments go dead, go to magnetic compass for heading, even in a fog, that's SOP. If you have a compass, all instruments are not dead. Well duh, it's a magnetic compass in a fluid. However, that won't be enough in IMC. Is for me. Maintaining altitude is "seat of pants" thing, so what? Set cruise RPM and feel airspeed. That isn't possible. Sure it is. As long as you're not accelerating, which is something that can be sensed by audio RPM , the magnetic compass can operate as an artificial horizon too, because it's like a plumb-bob. It's of course, independant of operating systems. IIRC, the magnetic compass is on pre-flight check list, date of calibration and ascertain operation on taxi. Ken Instrument Flying Made Easy~ Most people wish to fly on the old gauges at one time or another but are prevented by the high cost of the instruments necessary for this form of flight. The following is a more or less known and extremely simple method which may be used by all. Place a live cat on the cockpit floor, because a cat always remains upright, he or she can be used in lieu of a needle and ball instrument. Merely watch to see which way he leans to determine if a wing is low and if so, which one. This will enable you to your aircraft level in route with complete accuracy and confidence. A duck is used for final instrument approach and landing, because of the fact that any sensible old duck will refuse to fly under instrument conditions, it is only necessary to hurl your duck out of the cockpit window and follow her to the ground. There are some limitations on the cat and duck method, but by rigidly adhering to the following check list a degree of success will be achieved which will not only startle you, but will astonish your passengers as well, and may have an occasional tower operator with an open mouth. · Get a wide-awake cat, most cats do not want to stand up all the time, so it may be necessary to carry a fierce dog along to keep the cat at attention. · Make sure your cat is clean, dirty cats will spend all the time washing. Trying to follow a washing cat usually results in a slow roll followed by an inverted spin. You will see that this is most unprofessional. · Old cats are the best, young cats have nine lives, but an old used up cat with only one life left has just as much to loose and will be more dependable. · Avoid stray cats. Try to get one with good character because you may want to spend time with her. · Beware of cowardly ducks, if the duck discovers that you are using the cat to stay upright, she will refuse to leave the airplane without the cat. Ducks are no better on instruments than you are. · Get a duck with good eyes. Near sighted ducks sometimes fail to recognize that they are on the old gauges and will go flogging into the nearest hill. Very near sighted ducks will not realize that they have been thrown out and will descend to the ground in a sitting position. This is a most difficult maneuver to follow in an airplane. · Choose your duck carefully, it is easy to confuse ducks with geese. Many large birds look alike. While they are very competent instrument fliers, geese seldom want to go in the same direction that you do. If your duck seems to be taking a heading to Ireland or Sweden, you may be safe in assuming that someone has given you a goose. (Can't recall the source, but I've always thought it was funny :-) -- Dudley Henriques |
#450
Well duh, it's a magnetic compass in a fluid. The fluid can leak out. Is for me. You're brave. |
DC-3 parts to give away | Robert Little | Restoration | 2 | November 23rd 06 03:30 AM |
Who can give a checkout? | Mark S Conway | General Aviation | 2 | May 9th 05 12:15 AM |
Winch give-away | KP | Soaring | 6 | January 11th 05 08:04 PM |
Did you ever give up on an IR? | No Such User | Piloting | 24 | November 26th 03 02:45 PM |
FS 2004 give away | Ozzie M | Simulators | 0 | November 23rd 03 03:50 PM |
