I give up, after many, many years!
Old May 20th 08, 02:00 PM posted to rec.aviation.piloting,rec.aviation.student
B A R R Y
Default I give up, after many, many years!
On Tue, 20 May 2008 06:32:27 -0500, "Dan Luke"
There truly must be no saturation limit for cluelessness.
Thinking of what my a compass looks like in even minor bumps, much
less turbulence, I enjoyed the "compass as an AI" solution! G
Off to find a wide-awake cat and a ****ed-off duck.
Do we have to undershoot or overshoot the cat on north or south
headings?
  #482
Old May 20th 08, 02:16 PM posted to rec.aviation.piloting,rec.aviation.student
Steve Foley
"B A R R Y" wrote in message
headings?
Don't shoot the cat, or someone will call the SPCA
  #483
Old May 20th 08, 02:34 PM posted to rec.aviation.piloting,rec.aviation.student
Bertie the Bunyip[_25_]
B A R R Y wrote in
less turbulence, I enjoyed the "compass as an AI" solution! G]
Can you inagine? You might as well read tea leaves to decide where up
is.
headings?
Groan!
  #484
Old May 20th 08, 03:44 PM posted to rec.aviation.piloting,rec.aviation.student
gatt[_3_]
Mxsmanic wrote:
gatt writes:
Once again you're totally clueless. Your Directional Gyro is vacuum
driven. If you only needed electric instruments to fly, your primary
instruments wouldn't be pitot-static. If you have an electrical
problem, bus failure or inflight fire, you might lose all your
electrical instruments.
You think it terms of tiny airplanes.
Bertie doesn't, and he agrees with me: You're clueless.
-c
  #485
On May 19, 8:43 pm, "Ken S. Tucker" wrote:
That isn't possible.
Sure it is.
As long as you're not accelerating, which is something
that can be sensed by audio RPM , the magnetic
compass can operate as an artificial horizon too,
because it's like a plumb-bob.
It's of course, independant of operating systems.
You haven't flown, really, have you? If you had, you'd
know that the compass, being suspended from a pivot, is kept upright
by gravity, just like the ball in the turn coordinator stays in the
bottom of its tube by gravity. However, in a coordinated turn, the
TC's ball stays centered and the compass's card stays level with the
airplane's wings, not with the horizon. If it did we wouldn't need to
spend $900 on an attitude indicator; we could use the ball and
compass.
The compass reads all haywire during turns, too, not just
during acceleration. You can't use it to roll out on a heading. Timed
turns are for that.
Both you and Mx would be awful surprised the first time you
flew under the hood or in IMC. Vertigo, or what we call "crookedhead"
around here, would get you big time in no time. It surprises all new
guys, especially guys who "have it all figured out" and are trying to
teach the teachers. They come home with their tails between their
legs, same as the know-it-all trike pilot who has just had his first
taildragger experience.
Dan
  #486
gatt[_3_]
Mxsmanic wrote:
gatt writes:
For example, I continue to name and quote the FAA Airplane Flying
Handbook, FAA-H-8083-3A, and you don't respond to those posts.
Meanwhile, you don't cite your sources, so I suspect that you are a liar.
If I cared nothing about others, I'd suggest that you go up and do some flying
in IMC to make me a liar.
I do fly in IMC, liar.
-c
  #487
Old May 20th 08, 03:46 PM posted to rec.aviation.piloting,rec.aviation.student
gatt[_3_]
Mxsmanic wrote:
gatt writes:
Like what. What other things?
A climb. You cannot tell whether you are climbing or turning based on
sensations alone in IMC.
You wouldn't know. You haven't done it.
I have. And...let me check...I'm still alive.
:O
Go play with your toy airplanes.
-c
  #488
Old May 20th 08, 03:47 PM posted to rec.aviation.piloting,rec.aviation.student
gatt[_3_]
Mxsmanic wrote:
gatt writes:
The FAA knows a whole hell of a lot more about flying than you,
regardless of what you claim you've read.
No doubt. But I'm not debating this with the FAA.
I quoted you chapter and verse directly from the FAA, and you
contradicted it, liar.
Bye now. Your opinions here are not worth further reading or discussion.
-c
  #489
Old May 20th 08, 03:51 PM posted to rec.aviation.piloting,rec.aviation.student
gatt[_3_]
Bertie the Bunyip wrote:
Well duh, it's a magnetic compass in a fluid.
The fluid can leak out.
What? Your TV screen is that realistic?
Shouldn't set Kool-Aid glasses on the monitor.
-c
DC-3 parts to give away Robert Little Restoration 2 November 23rd 06 03:30 AM
Who can give a checkout? Mark S Conway General Aviation 2 May 9th 05 12:15 AM
Winch give-away KP Soaring 6 January 11th 05 08:04 PM
Did you ever give up on an IR? No Such User Piloting 24 November 26th 03 02:45 PM
FS 2004 give away Ozzie M Simulators 0 November 23rd 03 03:50 PM
