In the more than 30 years I have been involved in gliding/soaring I
have had my wing run many times, have run other pilot’s wings, and have taught novices to run wings for ground and aerotow launches. At a recent national contest I saw a wing running technique that I had never seen before. I was so concerned about the way my wing was being handled that I stopped the launch. I was later told that the method being used was not only common place but safer than the method I am used to using. The two methods are as follows: Method 1 – Runner stands outboard of wing tip facing in the direction of launch and holding the wing tip trailing edge with the hand nearest the glider. Method 2 – Runner stands close behind the wing just inboard of the wing tip and holds the trailing edge of the wing with both hands. Possible advantages and disadvantages of each method For Method 1: – Wing runner has one arm free to swing and should be able to run faster than a person holding a wing with both hands. – In the event of a tail wind launch the wing runner can start slightly ahead of the wing (Note that “ahead of” does not mean “in front of”. The wing runner in this case is still outboard of the tip) – If wing runner falls he will not obstruct the wing. Against Method 1: – None known For Method 2 (My interpretation of what I was told by those advocating this method): – Use of two hands makes it possible to hold a heavy wing that could not be held up by one hand alone. – Launch is safer because the runner is not in front of the wing. Against Method 2 (My opinion): – Wing runner can fall on the wing at the start of the launch risking personal injury and potentially causing the glider to ground loop. – A person holding onto something with 2 hands cannot run as fast as someone with one arm free. – If the glider is so badly out of balance that 2 hands are needed to support the wing the launch should not be started. What wing running technique is used where you fly and, if it is method 2, can you please explain the advantages over method 1? Andy |
On 10 July, 22:27, Andy wrote:
In the more than 30 years I have been involved in gliding/soaring I have had my wing run many times, have run other pilot’s wings, and have taught novices to run wings for ground and aerotow launches. At a recent national contest I saw a wing running technique that I had never seen before. *I was so concerned about the way my wing was being handled that I stopped the launch. *I was later told that the method being used was not only common place but safer than the method I am used to using. The two methods are as follows: Method 1 – Runner stands outboard of wing tip facing in the direction of launch and holding the wing tip trailing edge with the hand nearest the glider. Method 2 – Runner stands close behind the wing just inboard of the wing tip and holds the trailing edge of the wing with both hands. Possible advantages and disadvantages of each method For Method 1: – * * Wing runner has one arm free to swing and should be able to run faster than a person holding a wing with both hands. – * * In the event of a tail wind launch the wing runner can start slightly ahead of the wing (Note that “ahead of” does not mean “in front of”. The wing runner in this case is still outboard of the tip) – * * If wing runner falls he will not obstruct the wing. Against Method 1: – * * None known For Method 2 (My interpretation of what I was told by those advocating this method): – * * Use of two hands makes it possible to hold a heavy wing that could not be held up by one hand alone. – * * Launch is safer because the runner is not in front of the wing. Against Method 2 (My opinion): – * * Wing runner can fall on the wing at the start of the launch risking personal injury and potentially causing the glider to ground loop. – * * A person holding onto something with 2 hands cannot run as fast as someone with one arm free. – * * If the glider is so badly out of balance that 2 hands are needed to support the wing the launch should not be started. What wing running technique is used where you fly and, if it is method 2, can you please explain the advantages over method 1? Andy I am impressed that you present a reasoned discussion - I would just think method 2 is nuts and would decline to be launched that way. John Galloway |
Andy wrote:
In the more than 30 years I have been involved in gliding/soaring I have had my wing run many times, have run other pilot’s wings, and have taught novices to run wings for ground and aerotow launches. At a recent national contest I saw a wing running technique that I had never seen before. I was so concerned about the way my wing was being handled that I stopped the launch. I was later told that the method being used was not only common place but safer than the method I am used to using. As PIC, I presume it is exclusively your choice. The two methods are as follows: Method 1 – Runner stands outboard of wing tip facing in the direction of launch and holding the wing tip trailing edge with the hand nearest the glider. Method 2 – Runner stands close behind the wing just inboard of the wing tip and holds the trailing edge of the wing with both hands. Not a problem on a high wing (much) like a SGS 2-33, but wouldn't some gliders require a stance like that used in pushing a wheel barrow? (I've been told not to run with wheelbarrows or scissors.) Method 3 - Runner lifts glider over head and heaves it upward into the nearest thermal. Advantage of method 3 is no tow or winch is needed. Invite Hercules or Atlas to your next glider launch. |
On Jul 10, 3:27*pm, Andy wrote:
In the more than 30 years I have been involved in gliding/soaring I have had my wing run many times, have run other pilot’s wings, and have taught novices to run wings for ground and aerotow launches. At a recent national contest I saw a wing running technique that I had never seen before. *I was so concerned about the way my wing was being handled that I stopped the launch. *I was later told that the method being used was not only common place but safer than the method I am used to using. The two methods are as follows: Method 1 – Runner stands outboard of wing tip facing in the direction of launch and holding the wing tip trailing edge with the hand nearest the glider. Method 2 – Runner stands close behind the wing just inboard of the wing tip and holds the trailing edge of the wing with both hands. Possible advantages and disadvantages of each method For Method 1: – * * Wing runner has one arm free to swing and should be able to run faster than a person holding a wing with both hands. – * * In the event of a tail wind launch the wing runner can start slightly ahead of the wing (Note that “ahead of” does not mean “in front of”. The wing runner in this case is still outboard of the tip) – * * If wing runner falls he will not obstruct the wing. Against Method 1: – * * None known For Method 2 (My interpretation of what I was told by those advocating this method): – * * Use of two hands makes it possible to hold a heavy wing that could not be held up by one hand alone. – * * Launch is safer because the runner is not in front of the wing. Against Method 2 (My opinion): – * * Wing runner can fall on the wing at the start of the launch risking personal injury and potentially causing the glider to ground loop. – * * A person holding onto something with 2 hands cannot run as fast as someone with one arm free. – * * If the glider is so badly out of balance that 2 hands are needed to support the wing the launch should not be started. What wing running technique is used where you fly and, if it is method 2, can you please explain the advantages over method 1? Andy Hold up a heavy wing??? The wing runner is supposed to balance the wing so there would be no weight hold up if they're doing it right. There is no reason a runner in method 1 should be in front of the wing. I would only add that the pilot should hold neutral aileron so he's not fighting the runner. |
On Sat, 10 Jul 2010 14:27:16 -0700, Andy wrote:
What wing running technique is used where you fly and, if it is method 2, can you please explain the advantages over method 1? I have never seen method 2 used. It should go without saying that I was taught method 1 and have used it on heavy gliders up to and including an ASH-25. I agree with John Galloway that the weight of the wing should be reason for aborting the launch rather than using two hands and would add another reason for not launching as well as a heavy (out of balance) wing: that is a cross-wind strong enough to make the wing that heavy is probably in excess of the glider's cross-wind launch limit. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
On 7/10/2010 4:27 PM, Andy wrote:
In the more than 30 years I have been involved in gliding/soaring I have had my wing run many times, have run other pilot’s wings, and have taught novices to run wings for ground and aerotow launches. At a recent national contest I saw a wing running technique that I had never seen before. I was so concerned about the way my wing was being handled that I stopped the launch. I was later told that the method being used was not only common place but safer than the method I am used to using. The two methods are as follows: Method 1 – Runner stands outboard of wing tip facing in the direction of launch and holding the wing tip trailing edge with the hand nearest the glider. Method 2 – Runner stands close behind the wing just inboard of the wing tip and holds the trailing edge of the wing with both hands. Possible advantages and disadvantages of each method For Method 1: – Wing runner has one arm free to swing and should be able to run faster than a person holding a wing with both hands. – In the event of a tail wind launch the wing runner can start slightly ahead of the wing (Note that “ahead of” does not mean “in front of”. The wing runner in this case is still outboard of the tip) – If wing runner falls he will not obstruct the wing. Against Method 1: – None known For Method 2 (My interpretation of what I was told by those advocating this method): – Use of two hands makes it possible to hold a heavy wing that could not be held up by one hand alone. – Launch is safer because the runner is not in front of the wing. Against Method 2 (My opinion): – Wing runner can fall on the wing at the start of the launch risking personal injury and potentially causing the glider to ground loop. – A person holding onto something with 2 hands cannot run as fast as someone with one arm free. – If the glider is so badly out of balance that 2 hands are needed to support the wing the launch should not be started. What wing running technique is used where you fly and, if it is method 2, can you please explain the advantages over method 1? Andy How can the wing runner signal take up slack and launch if he doesn't have a free hand? That's just as important as holding the wings level. -- Mike Schumann |
On Jul 10, 4:34*pm, Mike Schumann
wrote: On 7/10/2010 4:27 PM, Andy wrote: In the more than 30 years I have been involved in gliding/soaring I have had my wing run many times, have run other pilot’s wings, and have taught novices to run wings for ground and aerotow launches. At a recent national contest I saw a wing running technique that I had never seen before. *I was so concerned about the way my wing was being handled that I stopped the launch. *I was later told that the method being used was not only common place but safer than the method I am used to using. The two methods are as follows: Method 1 – Runner stands outboard of wing tip facing in the direction of launch and holding the wing tip trailing edge with the hand nearest the glider. Method 2 – Runner stands close behind the wing just inboard of the wing tip and holds the trailing edge of the wing with both hands. Possible advantages and disadvantages of each method For Method 1: – * * * *Wing runner has one arm free to swing and should be able to run faster than a person holding a wing with both hands. – * * * *In the event of a tail wind launch the wing runner can start slightly ahead of the wing (Note that “ahead of” does not mean “in front of”. The wing runner in this case is still outboard of the tip) – * * * *If wing runner falls he will not obstruct the wing. Against Method 1: – * * * *None known For Method 2 (My interpretation of what I was told by those advocating this method): – * * * *Use of two hands makes it possible to hold a heavy wing that could not be held up by one hand alone. – * * * *Launch is safer because the runner is not in front of the wing. Against Method 2 (My opinion): – * * * *Wing runner can fall on the wing at the start of the launch risking personal injury and potentially causing the glider to ground loop. – * * * *A person holding onto something with 2 hands cannot run as fast as someone with one arm free. – * * * *If the glider is so badly out of balance that 2 hands are needed to support the wing the launch should not be started. What wing running technique is used where you fly and, if it is method 2, can you please explain the advantages over method 1? Andy Even if it were a good idea to hold up a heavy wing Method 2 would be a terrible way to do it - the mechanics are all wrong. Someone may have been concerned with a wing runner grasping the tip and holding it back rather than letting it slip from his/her hands as the glider accelerates, but the best idea is to train in Method 1 properly. The big disadvantages I see with Method 2 a 1) the runner has very little room to absorb a slingshot start if the towplane surges forward and, 2) any misstep will put the runner's face on top of the wing trailing edge with the expected bad outcome. The best technique I know is with the wing runner next to the wing lightly grasping the trailing edge of the tip applying as little pressure as possible. 9B |
wrote: How can the wing runner signal take up slack and launch if he doesn't have a free hand? *That's just as important as holding the wings level. For US contest launches it is common for the signaler to be a separate person from the wing runner. Andy |
In the more than 30 years I have been involved in gliding/soaring I have had my wing run many times, have run other pilot’s wings, and have taught novices to run wings for ground and aerotow launches. At a recent national contest I saw a wing running technique that I had never seen before. *I was so concerned about the way my wing was being handled that I stopped the launch. *I was later told that the method being used was not only common place but safer than the method I am used to using. The two methods are as follows: Method 1 – Runner stands outboard of wing tip facing in the direction of launch and holding the wing tip trailing edge with the hand nearest the glider. Method 2 – Runner stands close behind the wing just inboard of the wing tip and holds the trailing edge of the wing with both hands. Possible advantages and disadvantages of each method For Method 1: – * * Wing runner has one arm free to swing and should be able to run faster than a person holding a wing with both hands. – * * In the event of a tail wind launch the wing runner can start slightly ahead of the wing (Note that “ahead of” does not mean “in front of”. The wing runner in this case is still outboard of the tip) – * * If wing runner falls he will not obstruct the wing. Against Method 1: – * * None known For Method 2 (My interpretation of what I was told by those advocating this method): – * * Use of two hands makes it possible to hold a heavy wing that could not be held up by one hand alone. – * * Launch is safer because the runner is not in front of the wing. Against Method 2 (My opinion): – * * Wing runner can fall on the wing at the start of the launch risking personal injury and potentially causing the glider to ground loop. – * * A person holding onto something with 2 hands cannot run as fast as someone with one arm free. – * * If the glider is so badly out of balance that 2 hands are needed to support the wing the launch should not be started. What wing running technique is used where you fly and, if it is method 2, can you please explain the advantages over method 1? Andy http://www.soaringsafety.org/school/wingrunner/toc.htm |
On Jul 10, 10:27*pm, Andy wrote:
In the more than 30 years I have been involved in gliding/soaring I have had my wing run many times, have run other pilot’s wings, and have taught novices to run wings for ground and aerotow launches. At a recent national contest I saw a wing running technique that I had never seen before. *I was so concerned about the way my wing was being handled that I stopped the launch. *I was later told that the method being used was not only common place but safer than the method I am used to using. The two methods are as follows: Method 1 – Runner stands outboard of wing tip facing in the direction of launch and holding the wing tip trailing edge with the hand nearest the glider. Method 2 – Runner stands close behind the wing just inboard of the wing tip and holds the trailing edge of the wing with both hands. Possible advantages and disadvantages of each method For Method 1: – * * Wing runner has one arm free to swing and should be able to run faster than a person holding a wing with both hands. – * * In the event of a tail wind launch the wing runner can start slightly ahead of the wing (Note that “ahead of” does not mean “in front of”. The wing runner in this case is still outboard of the tip) – * * If wing runner falls he will not obstruct the wing. Against Method 1: – * * None known For Method 2 (My interpretation of what I was told by those advocating this method): – * * Use of two hands makes it possible to hold a heavy wing that could not be held up by one hand alone. – * * Launch is safer because the runner is not in front of the wing. Against Method 2 (My opinion): – * * Wing runner can fall on the wing at the start of the launch risking personal injury and potentially causing the glider to ground loop. – * * A person holding onto something with 2 hands cannot run as fast as someone with one arm free. – * * If the glider is so badly out of balance that 2 hands are needed to support the wing the launch should not be started. What wing running technique is used where you fly and, if it is method 2, can you please explain the advantages over method 1? Andy I personally hold either the wingtip or the trailing edge, depending on where the aileron cutout is, between the thumb and finger of one hand at arm's length, and let go as soon as I can't run any faster. There are some risks to the wing tip runner. On one occasion I nearly lost a little finger when it got trapped in the aileron gap of a Slingsby T21, a vintage type where the ailerons extend right out to the wing tip. I only just managed to pull it out in time and it ached for a week afterwards. I know of another case where a lady actually lost a finger when her wedding ring snagged on a skid plate. A kind farmer with a small airstrip offered to run my wing for an aerotow retrieve: Unfortunately he tripped on a piece of uneven ground and went base over apex pulling my wing back down onto the ground as he did so. Fortunately there were no injuries to either party. Derek C |
Low wing landing, high wing taking off...oops | [email protected] | Piloting | 1 | May 16th 08 09:41 PM |
Soft field landings - low wing vs high wing aircraft | Justin Gombos | Piloting | 19 | May 23rd 07 05:21 AM |
Books on Military Rotary Wing to Civilian Fixed Wing Transition? | Greg Copeland | Piloting | 5 | May 2nd 07 03:23 AM |
High wing to low wing converts...or, visa versa? | Jack Allison | Owning | 99 | January 27th 05 11:10 AM |
Mylar tape wing seals - effect on wing performance | Simon Waddell | Soaring | 8 | January 1st 04 03:46 PM |
