FAR:Safety Pilot & High Performance/Complex?
Old August 7th 03, 04:25 PM
Default FAR:Safety Pilot & High Performance/Complex?
It is my understanding (always subject to correction) that as a safety pilot
you may log PIC time because you are indeed a required crew member for the
operation. However, to log PIC time you also must be qualified to act as
PIC of that particular aircraft.
Jim Burns III
Remove "nospam" to reply
"FryGuy" wrote in message
1...
I have a couple of questions that are unclear to me regarding being a
safety pilot and operating high performance and/or complex aircraft. I've
tried looking these up in the 2003 FAR but I wasn't able to find a good
answer to my questions. If you could give me the reference in the FAR if
there is one I would appreciate it. Here they a
1) I have a friend who needs to go practice some IFR approaches to stay
current. I am a private pilot ASEL. I'm pretty sure that it is not a
problem with me being his safety pilot but he told me I can log the time
PIC. Is this correct?
2) What are the requirements for complex and high performance aircraft? I
thought that an endorsement was required for planes with retractable gear
and a adjustable prop and another for planes with a greater than 200
horsepower engine. In my log book I see an endorsement line for the HP
(there isn't a FAR reference though) but not for the complex. I looked up
"complex" in the FAR and could not find anything regarding this.
3) Ok, now the combination of the two. Lets say I do need an endorsment
for the complex/HP aircraft. Can I log time as the safety pilot in this
plane if I haven't yet gotten the endorsment for complex/HP? 91.109.b.2
says the safety pilot just needs to be a private pilot with the
appropriate
category and class ratings.
Thanks for the information!
Jeff Frey
Old August 7th 03, 05:56 PM
John T
"Jim" wrote in message
news
must be qualified to act as PIC of that particular aircraft.
It is not required that you be qualified to be PIC of a particular aircraft,
only the category and class of the aircraft. As an example, if you don't
have a high performance endorsement, you will be hard pressed to find an FBO
to rent you a C182. However, you could still be a safety pilot in that
plane (and log PIC for the time actually spent as safety pilot) if you have
a PP-ASEL certificate.
John T
http://tknowlogy.com/tknoFlyer
__________
Old August 7th 03, 06:38 PM
I "think" John Lynch's take on the question is that you must have the
appropriate endorsements to log PIC when acting as safety pilot. If the
safety pilot does not act as the legal PIC he/she does not need the proper
endorsements, however they may not log the safety pilot time as PIC. New
question: Is there ever a case when you can log PIC time when you aren't
both properly rated and endorsed?
QUESTION: According to § 91.109(b), a safety pilot must possess at
least a private certificate with appropriate category & class ratings. Is
it necessary for that safety pilot to be "current" in the aircraft
(landings, etc.)? Requirements of 61.55 specifically exempt safety pilots
[§ 61.55(d)(4)], but where are the safety pilot criteria actually spelled
out. Section 61.57 refers to pilot-in-command requirements, but a safety
pilot is not PIC, only a required crew member. Further, has there ever been
an interpretation that the safety pilot must be Instrument Rated for that
type of VFR operation?
ANSWER: Ref. § 61.31(d)(1); § 61.51(e)(1)(iii), § 61.51(f)(2), §
61.3(c); § 61.56(c), § 61.57(c); A safety pilot is a "required crewmember"
and must hold at least a valid private pilot certificate with category and
class ratings appropriate to the aircraft being flown per § 91.109(b) and a
valid medical certificate per § 61.3(c). A valid pilot certificate is one
which has not been revoked or under suspension.
That person who is serving as a safety pilot may choose to act as the legal
pilot-in-command (per 14 CFR part 1) and log the time as PIC [per §
61.51(e)(1)(iii)], or otherwise log the time as SIC time [per §
61.51(f)(2)], but is not even required to log the time at all. However, the
safety pilot's name must be logged by the person practicing instrument
flight [per § 61.51(g)(3)(ii)]. If the safety pilot is going to act as the
legal PIC for the flight that person must ". . . Hold the appropriate
category, class, and type rating (if a class rating and type rating are
required) for the aircraft to be flown;" [per § 61.31(d)(1)]. ). And if
the flight is conducted in a high performance, complex, tail wheel, etc.
aircraft and the safety pilot is acting as the legal PIC that pilot must
have the appropriate endorsements that are required by § 61.31(e), (f)
and/or (i), as appropriate. This could be a reason why a safety pilot might
only be able to serve as an SIC and log it as SIC time.
And assuming the operation is a simulated instrument flight (as in the case
the flight is performed in VMC conditions under VFR), the safety pilot would
not need to hold an instrument rating. If any portion of the flight were
conducted on an IFR flight plan (e.g., in and out of the clouds and/or even
on an IFR flight plan) at least one of the pilots must have an instrument
rating and the § 1.1 PIC must be instrument current in accordance with §
61.57(c) and be Flight Review current in accordance with § 61.56(c).
"John T" wrote in message
ws.com...
news
aircraft,
FBO
have
John T
__________
Old August 7th 03, 08:39 PM
John T
the safety pilot does not act as the legal PIC he/she does not need
the proper endorsements, however they may not log the safety pilot
time as PIC.
Yeah, I already posted a retraction on my first answer. SIC would be
allowed under these circumstances, though.
John T
__________
Old August 7th 03, 06:06 PM
John T
1
1) I am a private pilot ASEL. I'm pretty sure that it is
not a problem with me being his safety pilot but he told me I can log
the time PIC. Is this correct?
Yes, you may log the time actually spent as a safety pilot as PIC.
aircraft?
Separate endorsements are needed for high performance and complex airplanes.
14 CFR 61.31
(e) Additional training required for operating complex airplanes. (1) Except
as provided in paragraph (e)(2) of this section, no person may act as pilot
in command of a complex airplane (an airplane that has a retractable landing
gear, flaps, and a controllable pitch propeller; or, in the case of a
seaplane, flaps and a controllable pitch propeller)...
(f) Additional training required for operating high-performance airplanes.
(1) Except as provided in paragraph (f)(2) of this section, no person may
act as pilot in command of a high-performance airplane (an airplane with an
engine of more than 200 horsepower)...
3) Can I log time as the safety
pilot in this plane if I haven't yet gotten the endorsment for
complex/HP? 91.109.b.2 says the safety pilot just needs to be a
private pilot with the appropriate category and class ratings.
You've answered your own question. The safety pilot needs to be rated
in the category and class of the aircraft.
John T
__________
Old August 7th 03, 06:10 PM
John T
ws.com
rated in the category and class of the aircraft.
Actually, now that I re-read the FAR sections I quoted (61.31), I think Jose
may be right. This sounds like a good question to fire off to the local
FSDO and/or AOPA.
John T
__________
Old August 7th 03, 10:12 PM
Roger Halstead
. 41
aircraft?
14 CFR 61.31
IE Single engine land.
OTOH, I fly high performance/complex/retract. Now days I only care
that the safety pilot know what they are doing. When I was a
beginning student, I wanted some on in the right seat who could take
over if I screwed up. I want a pair of eyes that are busy looking
outside and at least somewhat familiar with the system.
Even now, although I say I only want a set of eyes and ears, the first
time someone serves as safety pilot with me, we go out and spend an
hour doing maneuvers so they can get familiar with the airplane and
its characteristics and that includes stalls and emergency procedures.
Roger Halstead (K8RI EN73 & ARRL Life Member)
www.rogerhalstead.com
N833R World's oldest Debonair? (S# CD-2)
Old August 7th 03, 06:28 PM
john smith
Cannot log PIC but can log Second in command.
Depends on the owner's insurance company's requirements for that
says the safety pilot just needs to be a private pilot with the appropriate
Airplane, single engine land. What does your certificate say? Does it
say high-performance or complex?
Old August 7th 03, 08:47 PM
John T
"john smith" wrote in message
Would the certificate ever say "high-performance" or "complex"? Or would
that be just the logbook?
John T
__________
Diamond DA-40 with G-1000 pirep C J Campbell Instrument Flight Rules 117 July 22nd 04 05:40 PM
Pilot Error? Is it Mr. Damron? Badwater Bill Home Built 3 June 23rd 04 04:05 PM
Enlisted pilots John Randolph Naval Aviation 41 July 21st 03 02:11 PM
