Lightspeed Battery Box Warning
Old July 8th 03, 02:22 AM
David Rind
Default Lightspeed Battery Box Warning
Sydney Hoeltzli wrote:
Lightspeed is sending replacement UPS red. But. This is
a known (though infrequent) problem. Caveat Lightspeed
User; don't leave your **** battery box lying on anything
expensive or any plastic part of the plane it would be a
PITA to replace. 'Cuz that puppy was Hot Hot Hot.
Is this just a known problem with the 30 or with other Lightspeed
ANR models as well?
David Rind
Old July 8th 03, 02:45 AM
Justin Case
Lightspeed seems to know everything about all of their problems and
they all seem infrequent. Just too many infrequent problems for me.
On Mon, 07 Jul 2003 21:45:22 GMT, Sydney Hoeltzli
Just got back from our annual jaunt to NW MA. Might write more
later (have I mentioned recently how much I abhore flying or
driving through the state of Ohio, no offense intended to anyone
living there)
Anyway, landing at a fuel stop on the return trip, husband
said batteries were low in my new Lightspeed 30 3G (pilot
gets to use it). Went in the FBO, lunch, wx, came out to
preflight while husband filed (VFR in 1800 ft ceilings,
wanted me to fly it, such a nice guy). Replaced batteries
in Lightspeed 30 3G.
Went back into FBO to change 3 yr olds wet undies for pullup,
get the glad tidings on who gets to fly in what from DH.
Thanks. I think. What does Louisville Approach have against
small airplanes bopping around in 6 miles vis at 2000 MSL?
You'd think I was scud running or something. Anyway, I
digress.
10 minutes later opened plane to hop in, stench of burning
plastic.
Sniffer traced to 30-3G battery box, which had been left
lying across the yoke.
Batteries were almost too hot to touch. Hot enough to
have melted the plastic of the battery box. Holy S***.
Love the Lightspeed comfort; like the Lightspeed NR;
Lightspeed QC needs some d*** ketchup. Maybe they oughtta
try to hire someone away from Dave Clark (alternatively
maybe someone at Dave Clamp ought to hire an ergonomics
guy away from Lightspeed).
Hola!
Sydney
Old July 8th 03, 03:13 AM
G.R. Patterson III
I take your point. As a matter of curiousity, would you prefer that to hearing
"Never heard of that problem before." That's what I get out of Maule Air. I
would never accuse them of lying, but I can think it.
George Patterson
The optimist feels that we live in the best of all possible worlds. The
pessimist is afraid that he's correct.
James Branch Cavel
Old July 8th 03, 01:27 PM
Dennis O'Connor
LS owners seem to fall into two groups... Those who have never had any
problem over a number of years of continuous use, and those who seem to
lurch from crises to crises... Strange...
Denny
"Justin Case" wrote in message
Old July 8th 03, 02:40 PM
Sydney Hoeltzli
Well, I guess I must be the exception which "proves" your rule, since
in general we have been very pleased with our Lightspeeds and while
we have had a previous problem with my 20Ks, I certainly wouldn't
describe it as a 'crisis'. Nor would I personally describe 2 problems
in 5 yrs ownership of 3 different headsets as "lurching from crisis
to crisis".
What seems strange to me is your perception, actually, but that
wouldn't be the first time.
Cheers,
Sydney
Old July 8th 03, 04:04 PM
Jay Honeck
I believe Denny is perceiving this:
The only reason many Lightspeed owners have NOT had repeated problems with
broken wires at the plug is because they specifically lay the battery box on
the floor, or tuck it in a side pocket. This removes the weight of the
battery box from the inadequately designed wire and plug assembly, and keeps
the wires from breaking.
NOW it has come to light that laying the battery box on the floor (or
tucking it in a pocket) can result in a conflagration of your aircraft.
This is, indeed, a "crisis" of quality control, in my opinion. And, as I
have repeatedly stated in the past, is truly a shame, as we absolutely,
positively LOVE our Lightspeed headsets.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
"Sydney Hoeltzli" wrote in message
to crisis".
Cheers,
Sydney
Old July 8th 03, 04:33 PM
Sydney Hoeltzli
Jay Honeck wrote:
Actually, Jay, if you reread Denny's post carefully, I don't think
this is what he's seeing or refering to as "some owners lurch from
crisis to crisis" but it's not worth addressing further.
Actually I think that's overstating the possible outcomes considerably.
What happens is this. The battery box shorts. The batteries get hot.
The battery box gets hot. The battery box begins to melt. The
batteries lose contact w/ the deformed battery box, the short circuit
is broken, and the heating stops.
The worst case is if the battery box happens to get hot enough to
melt low-temperature plastic trim, which can be expensive and costly
to replace.
The fabrics used in the interior of the aircraft had durned well better
withstand a much higher temperature without igniting, or someone
installed the wrong stuff. Likewise, it should not get hot enough to
ignite paper.
I discussed this in detail with the Lightspeed engineer. DH, who has
extensive training in fire hazard prevention, concurs. Of course, there
can always be some combination of factors which lead to a different
result.
So I wouldn't worry that your Lightspeed battery box is likely to
cause conflagration of your aircraft.
However, I would make sure you don't place it somewhere which might
melt and cost you time and $$. For example, we've been securing our
20K and 25XL battery boxes with velcro (sewn to the plane interior,
glued to the battery box). This is gonna stop, because velcro melts
at rather low temperature and melted velcro would trash my interior
panels.
A fabric pocket should actually be a good place, provided the fabric
meets standard aircraft flammability tests.
Cheers,
Sydney
Old July 9th 03, 07:31 PM
Ron Rapp
On Tue, 08 Jul 2003 15:04:24 GMT, "Jay Honeck"
That can't be true in my case, at least. My battery box is plugged
into the middle of the panel (left of the turn coordinator) and the
battery box hangs down from there. The box's weight causes the cord
to bend 90 degrees right after it comes out of the plug. That has got
to be about as high stress as you can get on the cord. Why I have had
no problems is a mystery to me. The only thing I can thing of is that
I leave the headset in the plane most of the time rather than plugging
it in and removing it again. That probably reduces the strain on the
cord.
--Ron
Old July 8th 03, 04:13 PM
James M. Knox
Sydney Hoeltzli wrote in news:3F0AC7D5.9020908
@swbell.net:
to crisis".
Sydney,
First off, thanks for the post. I would be interested in knowing what
actually shorted out (sounds like a spring contact or some such, most
likely, in the battery box).
You are right that, compared to having, oh say, a wing spar break, it's
hardly a "crisis." OTOH, I've got two Peltor's and a Dave Clark ANR -
average life 10 years - and never had a problem (other that physically
wearing out the earpads) with any of them. So you can see that, relative
to the "crowd," you are well to one side of the curve.
[Not that we wouldn't expect you to stand out in a crowd regardless. G]
James M. Knox
TriSoft ph 512-385-0316
1109-A Shady Lane fax 512-366-4331
Austin, Tx 78721
Old July 8th 03, 04:39 PM
Sydney Hoeltzli
I think that's an excellent educated guess. The point of maximum
deformation was just to the side of a spring contact. There appeared
to be some material covering the bottom of the box which might have
been installed off-center, leaving an area where a short could occur,
but I'm not sure about this.
Well, Denny was specifically referring to different groups of
*Lightspeed* owners, so I don't think your perception applies to
his post. He posits two different populations of *Lightspeed*
owners, those whose headsets are trouble free and those who "lurch
from crisis to crisis".
However, you get no argument from me: I love my Lightspeeds because they
are comfortable comfortable comfortable whereas after about an hour
I want to throw DC's out the window. But on the "longevity" and
"durability" front, I must admit they do not measure up. Their customer
service and support is *excellent* -- but it has to be. I would much
prefer far less need for said good support.
By the way, after calling Lightspeed Customer service yesterday about
4:30 central time, I had a new headset in hand (!!!!) by 9:30 central
time.
Why thank you!
Cheers,
Sydney
RG Battery Charger by Jim Weir in Kitplanes Kevin O'Brien Home Built 4 January 6th 05 01:19 AM
Handheld battery question RobsSanta General Aviation 8 September 19th 04 03:07 PM
For Keith Willshaw... robert arndt Military Aviation 253 July 6th 04 05:18 AM
Plane with no stall warning device? Roy Smith General Aviation 23 February 17th 04 03:23 AM
Lightspeed -- Was:Oshkosh 2003 Redux Jack McAdams Home Built 8 August 14th 03 03:19 PM
