#41
Interesting, I took a couple of pictures of the hinge and they seem to show
no structural connection from the side rails to my cross member ? I am flying tomorrow so I will examine this further, but I wonder if they varied the construction. Many of my aluminium support brackets are glued to the shell with what looks like a black polyurethane glue, similar to that used in the car industry to glue panels. I assumed this was the case for this cross member. I agree that It would be ideal to change one bolt at a time, but I was thinking of implement Steve Koerners mod which I believe would require you to remove both bolts to get the 1/4" spacer under the handle ? It is riveted to the top side rails. However one US owner has found all rivets sheared. All mine seem ok. In any event you should only change one bolt at a time! Andy |
#42
#43
On May 23, 10:39*am, Ian Reekie wrote:
Interesting, I took a couple of pictures of the hinge and they seem to show no structural connection from the side rails to my cross member ? I am flying tomorrow so I will examine this further, but I wonder if they varied the construction. *Many of my aluminium support brackets are glued to the shell with what looks like a black polyurethane glue, similar to that used in the car industry to glue panels. *I assumed this was the case for this cross member. I agree that It would be ideal to change one bolt at a time, but I was thinking of implement Steve Koerners mod which I believe would require you to remove both bolts to get the 1/4" spacer under the handle ? It is riveted to the top side rails. However one US owner has found all rivets sheared. All mine seem ok. In any event you should only change one bolt at a time! Andy- Hide quoted text - - Show quoted text - Mine also has the black glue. Email me and I'll send you a photo that shows the rivet locations. It should be easy to change one bolt at a time even when introducing the new plate. Just leave the first new bolt slightly loose so the plate can be rotated into alignment after the second bolt is removed. Even if you decide to remove the handle to work on it you can still put bolts in place to maintain the alignment. Having dealt with this issue once I would go to great length to ensure that both bolts were never removed at the same time. If you want all the bolts out then raising the top, disconnecting the gas struts, and then doing all the hinge work with the top closed may be the way to go. You'll need several strong friends or an overhead hoist though. Andy |
#44
On 5/22/2011 7:54 PM, MKoerner wrote:
Like Eric’s, my trailer has “bridged” its way around the west, at least until I got bigger tires and wheels (Eric, get bigger tires and wheels). That would make the rear of the trailer too high for convenient rigging with the trailer attached, something I commonly do when traveling with the motorhome (the trailer's primary motive force). Removing it to rig is a nuisance, especially since I need to reconnect it after rigging, so my wife can retrieve or follow me, as needed. A Cobra trailer dealer told me they are designed to be supported entirely by the tail and the tongue without damage, so I don't think the bridging causes the trailer any problems. I do have to replace the aluminum tail skids every 100,000 miles. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm http://tinyurl.com/yb3xywl - "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what you need to know tinyurl.com/yfs7tnz |
Cobra Trailer Spare Tire mount failure | Barny | Soaring | 29 | July 23rd 15 12:52 AM |
Cobra bottle jack failure | db_sonic | Soaring | 15 | October 30th 09 03:34 PM |
cobra trailer brake lever gas strut failure? | Frank[_1_] | Soaring | 11 | March 31st 09 08:59 PM |
Hanger Queen meets Cobra - Cobra Girl 07.jpg (1/1) | Alan Erskine[_3_] | Aviation Photos | 9 | September 20th 08 04:35 PM |
Hanger Queen meets Cobra - Cobra Girl 05.jpg (1/1) | Glenn[_2_] | Aviation Photos | 0 | September 19th 08 03:41 PM |
