Anyone used FlywithCE?
Old June 6th 11, 08:30 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
Default Anyone used FlywithCE? (slight digression)
On Mon, 06 Jun 2011 11:02:01 -0700, bumper wrote:
After reading numerous reviews, this is the best AA and AAA cell battery
charger I've used. Also comes with 4 ea AA and AAA cells that have held
up well. Charger will charge, charge/discharge, refresh, charge at
multiple rates etc.
It does look OK apart from one niggle - you can't use it to cycle and
measure the capacity of your SLAs like I can with my Pro-Peak Prodigy II
model charger, which handles NiCd/NiMH/lead-acid/and Li-poly/Li-ion
batteries. OTOH its somewhat cheaper.
Yer pays yer money and takes yer choice I guess.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
  #42
Old June 6th 11, 08:46 PM posted to rec.aviation.soaring
Mark Jardini
I had a 9 amp powersonic go bad in less than a year, Shorted between
the + and - so no resistance.
Anyone else have problems with that product. I don't think I will buy
another one.
Mark
  #43
Old June 7th 11, 01:24 AM posted to rec.aviation.soaring
smithcorp
On Jun 7, 12:19*am, Martin Gregorie
On Mon, 06 Jun 2011 12:46:09 +0000, Jim Beckman wrote:
I think your push-to-talk button is stuck.
Agreed and apologies to all.
The stuck PTT was somewhere in the interaction between my copy of Pan and
my ISP's NNTP server - Pan was merely reporting an inability to contact
the server while all this duplication was going on. Eventually I decided
that the problem wasn't going to clear itself and killed Pan.
martin@ * | Martin Gregorie
org * * * |
Thanks for the replies Martin
I've just invested in some good quality rechargeables and a charger
from here (they sell Eneloops in Australia too thanks goodness).
http://protog.com.au/aaa-rechargeabl...ries-c-55.html
Anyone used FlywithCE? rec.aviation.soaring[_2_] Soaring 0 June 5th 11 07:28 PM
flyWithCE tip #2: flyWithCE Flight Recorder and OLC urosp Soaring 0 February 16th 11 06:28 PM
flyWithCE tip #1: How can you view flights in flyWithCE Logbook? urosp Soaring 0 February 11th 11 07:39 AM
FlywithCE PC[_2_] Soaring 1 January 10th 08 04:34 AM
FlyWithCE V2.1 SUA Ken Kochanski (KK) Soaring 1 June 14th 06 09:34 PM
