#41
In article , "Bushy"
writes: Substitute pitot tube cover: Brightly coloured squeaky dog toy. Once your dog chews a hole in it and the squeaker won't work unless you hold your finger over it to confuse your poor puppy, then you can use it knowing that it will be visible and remembered during preflight. I use an old tennis ball. Cut a slit in the ball and squeeze the ball to open the slit to make it easy to put on. Also two balls to cover the vents. Attach a foot long piece of red spinnaker cloth to each. Chuck |
#42
After climbing out, he rummaged through the area behind the front seat.
Not finding what he was looking for there, he then opened the baggage door and pulled out two pieces of 12"x12"x0.75" plywood. That's a great idea. Yet another thing to bring to OSH! -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
#43
"Jay Honeck" wrote in message news:fpTUb.108019$U%5.554166@attbi_s03... I made some cheap light wheel-chocks from PVC pipe. Jim Weir made a pair for us last year -- with Atlas' "N" number on them and everything! They are very cool, and work very well -- but (as Jim warned us up front) you DO have to be careful using them on grass with wheel pants. Park your plane at Sun N Fun for a few days, and it WILL sink so that the wheel pants are setting on top of the chocks! Thus obviating the need for chocks in the first place... Happy Flying! Scott Skylane |
#44
On Fri, 6 Feb 2004 15:44:44 -0500, "Bob Chilcoat"
wrote: I've been looking for a cargo net that will hold down the stuff that's stored in the baggage area (two quarts of oil, small tool box, tiedown kit, etc. I have this image of having to remove the tool box from someone's head after landing out somewhere. Anyone seen one that will work well in an Archer? Go to the West Marine site and look for their cargo hammock. To give you an idea of its size, we used to have one to hold the kid's stuffed animals. You might be able to modify one. Don |
#45
"PaulaJay1" wrote in message ... I use an old tennis ball. Cut a slit in the ball and squeeze the ball to open the slit to make it easy to put on. Also two balls to cover the vents. Attach a foot long piece of red spinnaker cloth to each. A friend of mine with a 195 uses a stuffed duck as a pitot cover. It gives the appearance that the duck was skewered from the rear. |
#46
In article , Blanche
wrote: Is anyone collecting this list? yes I'll give it a few days, and then try to summarize. Then people can have fun correcting me. :-) -- Bob Noel |
#47
gives the appearance that the duck was skewered from the rear. I believe I saw his 195 at OSH. Great looking bird(s)! -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
#49
A few more tricks that come to mind:
- Someone may have already mentioned this, but a permanent marker (Sharpie) touches up the paint on your panel easily and perfectly. (It also works as a temporary cosmetic fix on chipped wing-walk material.) - Hairspray dissolves ink on vinyl or leather. - A cheap sleeping bag and two straps with velcro can be used to make a custom-fitted cowl cover for less that $25. - If you don't have cylinder heaters, lay a trouble light on top of the engine, and lay a sleeping bag over the cowl. Combined with a sump heater, you will have 85 degree oil at every start. - A temperature-sensitive cube (comes on at 35, goes off at 40) can be used to control your Tannis heater in your hangar. - Metal tape (NOT duct tape) makes a great oil cooler baffle in winter. - Fill all the little gaps in your engine baffling with high temperature RTV. You'll see you CHTs go down noticeably. - Silicone spraying your yokes will make your landings better. - Labeling your tow bar with your name and airport identifier is a good idea. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
#50
Dan Thompson wrote ...
Cool. This is like Heloise meets Sky King! Now THAT's funny! Daniel |
| Thread Tools | |
| Display Modes | |
| rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | December 1st 04 07:28 AM |
| rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | November 9th 04 04:47 PM |
| rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | February 1st 04 08:27 AM |
| rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | January 1st 04 07:27 AM |
| Conspiracy Theorists (amusing) | Grantland | Military Aviation | 1 | October 2nd 03 01:17 AM |
