#41
On Wed, 21 Jan 2004 03:08:30 GMT, "Greg Milligan"
wrote: Check Fisher Scientific under "aspirator". yes, https://www1.fishersci.com/Coupon?gid=109471&cid=1328 looks exactly like what I remember. The $63.24 looks about 10x what I think it would be worth to Jim ... is there a yellow tag? "GeorgeB" wrote in message .. . On Fri, 16 Jan 2004 08:41:07 -0800, Jim Weir wrote: Does anybody have an idea on how to make a tiny little vacuum pump on the order of an aquarium pump or so that will draw just a few inches of water? Preferably 110, but I can rig up a 12 volt supply if necessary. Thoughts? When I was in college, the chem labs used a venturi on water faucets to create a vacuum for filtration. I've tried Google to show where to get them, and failed. Just a little attachment with a side barbed fitting ... good vacuum levels, CHEAP, and appropriate for one who utilizes Bernoulli in other ways ... now where do I get it? |
#42
If you've got shop air, try looking for either a Vac Cubes or Piab venturi-type
vac injector. Both companies make some that are under 1" sq. and are used to pick up post cards, tec. on factory machines. Should be in the $20 range. You'll probably find them in your area at an industrial pneumatics supplier. Harry |
Newbie Question - Vacuum vs Electric | Bill Denton | Aerobatics | 1 | April 15th 04 11:30 PM |
Anybody need a fuel transfer pump? | Roy Smith | Home Built | 1 | January 5th 04 05:53 PM |
NACA duct ventrui | Chris W | Home Built | 7 | October 27th 03 04:11 PM |
Pumping fuel backwards through an electric fuel pump | Greg Reid | Home Built | 15 | October 7th 03 07:09 PM |
Fiberglass Vacuum Bagging Technique...Resin Infusion | Steve | Home Built | 5 | August 8th 03 06:10 PM |
