It appears that a lot of pilots are violating airspace even with GPS on
board. I would like to hear some feedback as to how pilots are violating airspace with GPS. I address this in my online book, www.cockpitgps.com. I have my hypothesis, but I would like to hear your experience or scenarios that you have heard involving this issue. Also of interest is how you might be using GPS to successfully avoid airspace violations. Other hypothesis are also welcome. Thanks, John Bell www.cockpitgps.com Here is my hypothesis: I have already mentioned in my discussion of database currency that you should set up a routing around any airspace and check it with a current chart before flight. Even with a current database, it is possible for the GPS to get you into trouble with airspaces. Aviation receivers can be setup to display airspace boundaries and to give warnings before entering certain airspace classifications such as category B airspace. These warnings can be a great benefit or a nuisance depending on the type of flying that you are doing. Thus, most receivers allow you to turn them on or off. Additionally, which boundaries will display and at what point of zooming out they will disappear can be set. The ability to make these settings is a good feature and I would not want to see this changed. However, it is possible to have the GPS not display or not warn of an impending airspace violation if you have the GPS set up incorrectly for the mission. Even if the airspace boundary is displayed, it is often difficult to decide what boundary a given line applies to. On the Garmin aviation receivers it is possible to cursor over the point to get a description. On a handheld GPS just press the rocker pad up, down, left, or right to start moving the cursor. On the GPS 400 and 500 series, press in on the knob and then start moving the cursor. Move the cursor to highlight the line and press the ENTER button to get information on the airspace. This is a great feature at the planning stage and is occasionally useful in flight. When you have preplanned the route and have a route line, the context of the border is obvious. However, I think that it is possible to confuse borders and violate airspace without first creating a route using a chart before flight. |
![]() "John Bell" wrote in message om... Other hypothesis are also welcome. Class B airspace, not category B. Your simplified definition of GPS, while one of the common ones often espoused has no basis in reality. This is not how GPS works. Your information on RAIM is wrong. What is unique about the RAIM used in IFR approved GPS's is not that it determines when the satellite geometry is giving you an error NOW, but computes if it will fail while during the expected duration of flying an instrument approach. |
I will see where I wrote category B instead of class B. It is simply a
typo. Thanks for catching that. I am certainly up for a better explanation of how GPS works. Indeed my information comes from the common espousals. I understand the concept of RAIM prediction, that the GPS can predict the unavailability of RAIM. However, I was not aware that RAIM had the ability to predict as oppose to detect positioning errors. I would appreciate further information on either basic GPS or RAIM. John Bell "Ron Natalie" wrote in message m... "John Bell" wrote in message om... Other hypothesis are also welcome. Class B airspace, not category B. Your simplified definition of GPS, while one of the common ones often espoused has no basis in reality. This is not how GPS works. Your information on RAIM is wrong. What is unique about the RAIM used in IFR approved GPS's is not that it determines when the satellite geometry is giving you an error NOW, but computes if it will fail while during the expected duration of flying an instrument approach. |
On Thu, 30 Oct 2003 20:38:40 GMT, "John Bell"
wrote in Message-Id: : I am certainly up for a better explanation of how GPS works. Are you aware of this mailing list? GPS for Aviation: http://www.lsoft.com/scripts/wl.exe?...ISTSERV.UNB.CA There are very knowledgable folks willing to answer all your questions there. |
Larry Dighera wrote
There are very knowledgable folks willing to answer all your questions there. :-) :-) Since John has written texts on GPS Navigation, I suspect that he was pulling someone's leg. http://www.smallboatgps.com/ http://www.cockpitgps.com/ Hi John, how's things going? Remember meeting at SnF? Bob Moore |
Robert,
I do indeed remember meeting you in Lakeland. Whenever I see one of your posts, it is like picking up a paper and seeing a byline from a reporter that I respect. Actually, my response to Ron Natalie was a little more than tongue in cheek. It was somewhat of a combination of defensiveness and worry that I might be spreading bad information. Ron's statement that my explanation of how GPS works: "while one of the common ones often espoused has no basis in reality. This is not how GPS works" has me curious. Unfortunately, Ron's statement unfortunately gives me little to correct my understanding if it is indeed wrong. Luckily, even if my explanation of how GPS works is totally incorrect, it should not have serious consequences as far as usage is concerned. John "Robert Moore" wrote in message . 7... Larry Dighera wrote There are very knowledgable folks willing to answer all your questions there. :-) :-) Since John has written texts on GPS Navigation, I suspect that he was pulling someone's leg. http://www.smallboatgps.com/ http://www.cockpitgps.com/ Hi John, how's things going? Remember meeting at SnF? Bob Moore |
In article , Ron Natalie wrote:
Your information on RAIM is wrong. What is unique about the RAIM used in IFR approved GPS's is not that it determines when the satellite geometry is giving you an error NOW, but computes if it will fail while during the expected duration of flying an instrument approach. That's RAIM *prediction*. RAIM is very capable of failing during an approach if you don't check the prediction ahead of time, at least on our Garmin 430. I don't know what John's information on RAIM is, since it will be two or three hours before his books is downloaded. Regards, Mike |
![]() "Mike Beede" wrote in message ... In article , Ron Natalie wrote: Your information on RAIM is wrong. What is unique about the RAIM used in IFR approved GPS's is not that it determines when the satellite geometry is giving you an error NOW, but computes if it will fail while during the expected duration of flying an instrument approach. That's RAIM *prediction*. RAIM is very capable of failing during an approach if you don't check the prediction ahead of time, at least on our Garmin 430. Yes...and if you read his document, he doesn't distinguish between RAIM (which many non-IFR units do just fine) and predictive rain. |
approach if you don't check the prediction ahead of time, at least on our Garmin 430. Yes...and if you read his document, he doesn't distinguish between RAIM (which many non-IFR units do just fine) and predictive rain. Ron, I am open to argument and corrections of any misunderstandings that I might have. It was my impression that RAIM is strictly a integrity monitoring scheme rather than a predictive function. RAIM uses redundant satellite signals as a cross check to monitor whether any satellite signals are bad. Since a GPS knows the satellite orbits from the almanac, a program can be designed to predict if satellite positioning will be adequate to support RAIM at a given time and place. Receivers such as the Garmin 430 have this RAIM prediction feature. Knowing the satellite orbit information, it is also possible to predict and issue a notam for areas and times when RAIM will be unavailable. Using the same techniques for predicting RAIM coverage, it would be possible to warn of impending satellite geometry and coverage problems. I do not know whether or not any GPS receivers do this automatically beyond the RAIM prediction program such as in the AUX menu of the Garmins. I guess I understand RAIM as a monitoring the integrity of the satellite signal rather than a predictive function. However, I will agree that there are ways to predict whether or not RAIM will be available. I am open to corrections if you will explain your reasoning and possibly site sources. Thanks, John Bell |
![]() "John Bell" wrote in message ... That's RAIM *prediction*. RAIM is very capable of failing during an \ I am open to corrections if you will explain your reasoning and possibly site sources. I believe you understand it, now go back and read your book. It is NOT the presence of RAIM that distinguishes the IFR GPS's (many non-IFR GPS's also have it), it's the predictive feature that is required/distinguishing. |
Must the PLANE be IFR-equipped to fly over17,500? | john smith | Home Built | 11 | August 27th 04 02:29 AM |
most of eastern Massachussetts airspace closed in July | Christopher C. Stacy | Instrument Flight Rules | 29 | June 19th 04 12:47 AM |
AOPA Sells-Out California Pilots in Military Airspace Grab? | Larry Dighera | Instrument Flight Rules | 12 | April 26th 04 06:12 PM |
Help - I busted into the Class B SEATAC airspace last night, does anyone have any advice ? | steve mew | Piloting | 38 | October 28th 03 06:08 PM |
FA: Congested Airspace: A Pilot's Guide | The Ink Company | Aviation Marketplace | 0 | August 10th 03 05:51 PM |
