#41
aaronw wrote:
In the C-172SP I fly I do: /snip/ A quick glance at the engine gauges to ensure that oil pressure (above all else) is in the green. aw Sooo, what do you do if the oil pressure is not in the green? You DON'T land??? |
#42
![]() Larry Dighera wrote: On Fri, 07 Nov 2003 08:41:12 -0500, Steve Robertson wrote in Message-Id: : Full throttle with carb heat on will still get you enough power to go around Full throttle with carburetor head applied is also likely to cause detonation due to an excessively lean mixture. This preignition applies all the instantaneous force of the _exploding_ (as opposed to burning) gasoline/air mixture directly against the top of an ascending (not descending as normal) piston. Detonation can bend piston rods or crack the case. Over a longer period of time, detonation can burn through the top of aluminum pistons. Induced engine damage: http://www.lycoming.textron.com/main...ips/index.html Detonation and preignition: http://www.lycoming.textron.com/main...ips/index.html No argument from me, Larry. Long term use is not good. But I am talking about a go-around situation where the pilot's choice is full throttle or crash. And the carb heat can be turned off in a matter of seconds after going full throttle. I'm trying to convince a guy to use carb heat on final as directed by the POH. You are not helping! (By the way, applying carb heat enrichens the mixture in most flight regimes because the hot air is less dense than cold air. The laws of physics are seldom broken by us mortals.) Also, your references are for Lycoming engines, which are, in general, much less suseptible to carb ice than small Continentals due to the design of the intake system. Best regards, Steve Robertson N4732J 1967 Beechcraft A23-24 |
#43
On Fri, 07 Nov 2003 13:29:39 -0500, Steve Robertson
wrote in Message-Id: : I'm trying to convince a guy to use carb heat on final as directed by the POH. You are not helping! I agree. Pilots should do what it says in the POH. You'll get no argument from me on that point. If you'd ever applied carburetor heat and full throttle on a Lycoming O-235, you'd understand the reason I mentioned detonation. I suppose that (and the way the Lycoming induction system is plumbed against the warm engine oil sump) is why the Piper POH doesn't recommend the use of CH unless induction icing has actually occurred, unlike Cessna. |
#44
I've had my share of emergencies, Orval, in singles and twins, and I stand
by my comments. Bob Gardner "Orval Fairbairn" wrote in message news ![]() In article F9vqb.94384$ao4.279861@attbi_s51, "Bob Gardner" wrote: I don't like situational instruction, where one action is required under one set of circumstances and a different action is required under a different set of circumstances. Teach one procedure that works all the time. There AIN'T no such thing! If you have an emergency, you're screwed with that policy! "BoDEAN" wrote in message ... How many people do / teach doing a full before landing checklist when doing pattern work? I do with my students, but other cfi's I work with use a quick / abbreviated one for our Cessna 172/152 |
#45
That's exactly what I meant, David....way to go! There was a time when
fixed-gear Beech trainers had a faux landing gear switch, just to develop the habit pattern. Bob Gardner "David Brooks" wrote in message ... "G.R. Patterson III" wrote in message ... BoDEAN wrote: How many people do / teach doing a full before landing checklist when doing pattern work? I flew with at least six different instructors during training for my PPC, two others for transition to tailwheel, and several others for BFRs. None used checklists during landing, nor did any of them recommend that I create one or use one. My instructors talked about it, but didn't regularly reinforce the habit and as a result I often forget. In a 172 and similar, there really is nothing to actually *do* as a result of the checklist (I think that was the point about the seatbelts; you always know you are wearing them) and, ironically, if you do the check on downwind you probably don't pull the carb heat yet. On the occasions when I do remember or am reminded, I usually take care to actually touch the fuel selector, mixture, and primer, and look down at the gear. I hope I'm creating habits that will help when I fly something more complex, but right now I'm worried about re-creating the checklist habit in the first place. -- David Brooks |
#46
![]() "Robert Moore" wrote in message . 6... T-Boy wrote You land with the carb heat ON? My Cessna provided pilot's operating handbook checklist for a 1959 C-172 reads as follows: J. BEFORE LANDING. (1) Set fuel selector to "Both". (2) Recheck mixture "Full Rich" (full in). (3) Apply carburetor heat before closing throttle. Of course this was before the FAA seatbelt regulation which added to later models a "Seatbelts ON" item. A commercially available C-172 N model checklist from AVTECH PILOT PRODUCTS reads as follows: BEFORE LANDING CHECKLIST Seats/Seatbelts............Secure Fuel Selector..............Fullest Tank/Both Carburetor Heat............ON Mixture....................Rich/As Required I've spent about six years landing with the carb heat ON. And on a go around it is possible to open the throttle and push the carb heat in at the same movement, its what the thumb is for. |
#47
This gets back to the discussion/controversy about "do" lists versus "check"
lists....students are taught to use the list as a "do" list, which requires taking an action (or touching a control) for each item on the list. With experience, pilots graduate to a "check" list, where they use a flow pattern or other method to do what needs to be done, and then refer to the list as a "Have I forgotten anything?" reminder. Bob Gardner "mrwallace" wrote in message ... "BoDEAN" wrote in message ... How many people do / teach doing a full before landing checklist when doing pattern work? I do with my students, but other cfi's I work with use a quick / abbreviated one for our Cessna 172/152 I do not have my students reading or referring to printed checklists while in the pattern, however I insist that they use them for specific phases of flight, for example, Level Off, Cruise, Arrival, Approach, etc. Strangely, there is a flight school in our area that specializes in light twin training and they did , and might still, have students referring to a written checklist on takeoff and climbout, they might also do this while in the pattern also. Kinda scary to think about. I would much rather have someone looking out of the window for traffic and keeping a simple, light, workload while in the pattern. Besides making sure that the lights are on, the gauges are green, mixture is set properly and that the carb ht. is set what else is there? No gear, no cowl flaps, no prop setting, no tanks to switch, no autopilot, no spoilers, no pres/diff, nothing to arm etc. besides the guys who have these things take care of them when in range and before they enter the pattern. Happy Flying R.Wallace |
#48
aaronw wrote:
[speaking of landing checklists] A quick glance at the engine gauges to ensure that oil pressure (above all else) is in the green. ....and if it's not, what do you do? land? Dave Remove SHIRT to reply directly. |
#49
mqd_117.3 wrote in message ...
Abbreviated checks means abbreviated life! What about blindly following checklists? For example : snip Mixture - rich Try this at a 7,000 ft. MSL on a warm summer day and you'll be disappointed in what happens when you advance the throttle to go around. I am on a personal crusade to get pilots to change this item to : Mixture - set appropriately John Galban=====N4BQ (PA28-180) |
#50
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 02:26 PM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
12 Dec 2003 - Today’s Military, Veteran, War and National Security News | Otis Willie | Naval Aviation | 0 | December 12th 03 11:01 PM |
Off topic - Landing of a B-17 | Ghost | Home Built | 2 | October 28th 03 04:35 PM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 01:27 PM |
