Forward CG Experience
Old November 14th 03, 02:42 PM
Jay Honeck
Default Forward CG Experience
Recently we flew with a friend who weighs over 320 pounds. With he and I
in the front seat, and just Mary in the back, we were at the very forward
limits of the allowable CG. Thanks to the Pathfinder's 1400 pound useful
load, however, we were still 250 pounds under gross, even with full tanks --
but the teeter-totter was certainly pretty far to the "teeter" side.
I was contemplating this as we came in to land. Departure had felt normal,
but I figured the flare to land would be effected, so I carried a few extra
knots on final. I also figured that the wind -- 12, gusting to 18, but
right down the runway -- would help a little, too. I opted for two notches
of flaps.
As we crossed the numbers, I noticed things just didn't "feel" right.
Pulling back on the yoke was having very little effect as far as changing
the angle of attack, yet the speed was still bleeding off. This was weird,
but -- as it was all happening in the last few seconds, there wasn't much
else to do but add a touch of power and pull back some more.
We arrived firmly, in a flat attitude. The nosewheel and mains hit nearly
simultaneously, and the end result was more like a mush into the ground than
my usual "flare, chirp, chirp, settle...". It was surprisingly smooth, but
I realized that if I hadn't given that extra burst of power, and a firmer
yank on the yoke, we might well have landed on the nose gear, with possibly
expensive consequences.
Later, on the way home, with Mary as PIC and our friend in the back seat,
things were much improved. The added weight in the back actually helped to
balance our normally slightly nose-heavy (thanks to the six-cylinder
Lycoming O-540) plane, and Mary remarked that it landed more like our old
Warrior used to.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old November 14th 03, 03:16 PM
Wallace Berry
In article zR5tb.196731$HS4.1666204@attbi_s01,
Took a heavy friend and his tiny wife for glider flights once. He was
right on 250 lbs. Put him in the front seat of a Grob 103 (a model
famous for being nose heavy anyway). With the stick all the way back,
airspeed was 60 knots. You can bet I carried some extra speed on final.
His wife was 90 lbs. Bolted in the iron ballast plates and put a chute
on her. She was still a little under the front seat minimum. Flew her
that way since I knew the glider was a little forward CG from a repair.
That was the best that glider ever flew for me.
Now I have a little Stits homebuilt. It is somewhat forward CG solo. So,
I will have some bolt-in ballast for the rear. With anybody in the back
seat, it will be aft CG once a gallon or two of fuel burns. I will have
to add some ballast up front. The most useful ballast I can think of is
an electric starter.
Old November 15th 03, 12:39 AM
Paul Sengupta
Hey, if you want a heavy friend to take flying, ballast and all that,
I'm available! :-) In the UK though...
I have 2 seats and 200hp so not much of a problem in my plane.
However I learned on a 172 as when I walked up first time to my
6ft 5" body builder instructor, he took one look at me, looked at
himself and said "We're going to need a bigger aeroplane"!
Grob 103. I can't even fit in the front and move the stick. I'm fine
in the back though...it's about the only glider I can fit in and
waggle the stick.
When I fly a T-tailed Arrow solo I have to a) watch how much fuel
I put in, and b) usually put a sandbag in the baggage compartment.
It still needs full back yoke to the stops on landing.
Paul
"Wallace Berry" wrote in message
Old November 14th 03, 06:27 PM
Corky Scott
On Fri, 14 Nov 2003 14:42:39 GMT, "Jay Honeck"
Jay Honeck
Iowa City, IA
Pathfinder N56993
Jay, with your indulgence, a little military history that is on your
post's topic.
During the dark days following Pearl Harbor and the invasion of the
Phillipine Islands, a highly practical and inveterate ex Navy pilot
scrounger by the name of Paul (later called Pappy) Gunn ran a rough
house airline out of the Phillipines called PAL (Philipine Air Lines).
He his airplanes were requisitioned by the army and Pappy had various
hair raising flights and encounters with Japanese aircraft and anti
aircraft fire from both sides before he wound up in Australia and then
Port Moresby.
Cutting out a lot of his story, he ended up in charge of a provisional
transport squadron and offloaded some A-20's that had been assigned
him. He discovered that they had arrived without any machine guns.
His combat experience to date had convinced him of the need for a LOT
of forward fire power to keep the enemy's heads down on the run in to
the target so he began modifying them.
He plated over the bombardier's position and installed a row of four
50 caliber machine guns in the nose, plus two more in blisters
alongside the cockpit for a total of six forward firing machine guns.
With the machine guns, internal bracing and ammo cans and ammo, the
fully loaded A-20 was seriously nose heavy (you wondered when I'd get
to the subject?) His first takeoff, apparently wasn't. He could not
lift the nose to get airborn.
So he relocated the two machine guns in side blisters, moving them
back behind the cockpit.
At this time Gunn met up with George Kenney, who arrived in the
theater with a notion about low level attacks utilizing some parachute
equipped fragmentation bombs he'd developed, which would slow their
descent to allow the bomber to move out of danger from an explosion
once the bomb was dropped.
He saw what Gunn was doing and immediately liked the concept. He
yanked Pappy from his command in the transport squadron and placed him
in charge of modifying more attack bombers.
The A-20's were immediately extremely effective, but Pappy was unhappy
with their performance, feeling that he needed a bigger bomber with
more capacity. Enter the B-25 strafer.
I've got to stop, I could go on about this for a while longer. ;-)
Corky Scott
Old November 14th 03, 07:22 PM
Jay Honeck
I've seen pictures of those B-25 ground-attack strafers. I imagine they
were the "A-10 Warthogs" of their day...
Thanks, Corky!
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old November 15th 03, 01:46 AM
Bob Chilcoat
It's my understanding that after Pappy Gunn had modified a B-25 for
straffing, with six 50 Cal Brownings in the nose and a 75mm field howitzer
under the floor of the cockpit, and had used it very successfully against
Japanese shipping, North American sent an engineer out to see what this
lunatic was doing. After looking over Gunn's field modification he just
shook his head and asked "Where the hell is the center of gravity?" Gunn
just shrugged and told him "Aw, we threw that out to save weight." The
engineer went home and North American started mass producing a properly
engineered variant of Gunn's cludge, the B-25G.
Bob (Chief Pilot, White Knuckle Airways)
"Corky Scott" wrote in message
I
Jay Honeck
Iowa City, IA
Pathfinder N56993
post's topic.
Port Moresby.
Corky Scott
Old November 16th 03, 03:53 AM
Big John
Bob
NA turned out 406 B-25G models with one 75mm and two 50 cal in the
nose.
Navigator/Cannoneer loaded the single shot canon. Bird carried 15
rounds which weighed 15 lbs each.
NA built cannon birds started arriving Brisbane in 1943.
Gun was a 75 MM CANNON, Army type M4 (not a howitzer). Gun was
descended from the French 75 of WWI fame.
Follow on was the B-25H which had the 75 mm cannon plus eight 50 cals
in nose (all fired by pilot)
The only bird I know of that uses a bigger gun (105 mm) is the C-130,
Spector, Gun Ship.
Not trying to take anything away from Gunn story, just giving
additional data on the NA built Cannon equiped birds.
Big John
On Fri, 14 Nov 2003 20:46:24 -0500, "Bob Chilcoat"
Old November 17th 03, 02:39 PM
Corky Scott
Pappy Gunn did not install any 75mm cannon's if I remember correctly.
He felt that the firepower of the .50 caliber machine guns was
adaquate, but more than that, he felt that it was necessary to
saturate the defenses with a dense volume of bullets to make them keep
their heads down while the bombers made their runs to the target.
The 75mm installation was done at the North American factory. Gunn
never liked it much. The fire rate was slow, it was inaccurate and
the recoil and flash were problematic. Most of the 75mm models had
their cannon removed from the airplane and replaced with more machine
guns once out to the war zone.
The skip bombers and the B-25 strafers actually developed side by
side, but independant of each concept. Initially, the skip bombing
technique was worked up by guys flying four engine bombers, mostly the
B-17. They practiced the run-in on a wreck out in Port Moresby's
harbor. Kenney always felt the bombers were too unwieldy for this
role and about the time a convoy of Japanese ships was detected
heading for New Guinea across the Bizmark Sea, he decided to attack it
using all his air forces.
Several B-17's did make attacks on the transports, but Australian
forces made attacks as well. The main thing though was that the B-25
strafers came into their own during this battle. They proved to be
extremely effective with their withering fire as they bore in at
wavetop height with all their machine guns blazing away. They'd
perfected the skip bombing technique by that time, which involved
dropping the bombs one by one in quick intervals, usually in a salvo
of four. This ensured that at least one would be at the right height
to penetrate the hull and detonate inside.
The Japanese literally had no counter for this tactic, which has got
to be one of the most successful field developed attack techniques of
WWII. So deadly was this technique that even the best destroyer
captains lost sleep pondering how to counter it, as nothing seemed to
work. See "Destroyer Captain" by Hara.
It must have been a truly terrifying situation to be in for the
Japanese as the B-25's normally attacked in pairs which limited the
maneuvering options of the target, no matter how fast and maneuverable
it was. The pilots split up and attacked from either side which split
the target's AA counterfire. But it did not split the attackers fire.
When the B-25's opened up, as many as 8 forward firing heavy machine
guns (ten if the top turret was swiveled to fire forward) poured an
absolute hail of bullets against the ship which caused even the
bravest sailer to flinch or duck for cover.
It wasn't all gravy for the B-25's though. Low level attacks like
this were extremely dangerous as any battle damage put the airplanes
into the ocean or jungle almost immediately. Many were lost.
Corky Scott
Old November 17th 03, 09:21 PM
Big John
Corky
The Skip bombing carried over into the P-51's. The technique taught
was to drop short of the vessel and let the bomb
skip off the water into the side. Fuse was a short delay to let
aircraft clear the explosion. By dropping early if the pilot made a
mistake and actually dropped late, he would drop directly into the
side of the vessel which was a good hit.
One skip was ideal but I've see some dropped at high speed and skipped
several times before hitting. Remember all pilots felt that speed was
a life saver when being shot at in combat.
Big John
On Mon, 17 Nov 2003 14:39:42 GMT,
Corky Scott
Old November 17th 03, 10:49 PM
Pat Thronson
Great story, Thanks Big John and Corky Scott.
Man it must have sucked to be on either side during this attack. To go back
on topic, I guess letting this quantity of lead loose, it surely would
change the Forward CG experience.
Pat Thronson
"Big John" wrote in message
Corky
Big John
howitzer
against
Gunn
Corky Scott
Dennis Fetters Mini 500 EmailMe Home Built 70 June 21st 04 09:36 PM
So Who Has More Military Command Experience, Bush Or Kerry? W. D. Allen Sr. Military Aviation 11 April 22nd 04 01:27 AM
So Who Has More Military Command Experience, Bush Or Kerry? W. D. Allen Sr. Naval Aviation 11 April 19th 04 05:12 PM
Forward Swept Wings Canuck Bob Home Built 16 October 3rd 03 05:50 PM
