Best performing Vario?
Old September 28th 12, 07:21 PM posted to rec.aviation.soaring
Ron Gleason
Default Best performing Vario?
On Friday, 28 September 2012 11:29:51 UTC-6, wrote:
On Tuesday, September 25, 2012 8:34:11 AM UTC-6, Tim Mara wrote:
Unfortunately, this question will not be fairly answered as to "which vario
is best" in this forum. What you are going to get is a lot of opinions based
only on what variometers the responders have actually used and possibly what
variometer they used that "they" liked better of the few systems they may
have actually had a chance to use. Few is anyone here will have had an
opportunity to realistically flown with or more over tested in any side by
side comparison all of the most common types, also most will have used
variometers in conjunction with other systems connected to or compared with
what was in place at the time they may have flown with that system.
Clearly variometer technology has changed over the years from the first
pellet variometers to modern pressure transducer and GPS coupled systems.
Many manufacturers today can produce good variometers with very common
electronic parts and devices, added features and connectability to extended
devices will normally be the determining factors in what systems the user
chooses along with a proven history of reliability and support.
tim
Please visit the Wings & Wheels website at www.wingsandwheels.com
"Craig R." wrote in message
In your opinion, what was the best performing vario you have ever used?
Specifically, the one that got you centered in and to the top of the
thermal in the least amount of time.
Let's ignore products because they have the latest "bells and whistles"
add ons, latest technology, sexy appearances, or best computer processor.
Basic performance is the only criteria.
I've heard some say the legacy Cambridge units and some say the Sage
mechanical.
Which unit did it for you?
I have used the V7 this season and have really liked it and love the user interface. I am halfway done installing the Butterfly Vario right next to the V7 so we can all see the differences. I plan on doing a video of the two units in action as soon as I can finish the install. Due to limited time to get out and fly this may take another month or two but it will happen this year.
Bruno - B4
Priorities are needed; fishing to feed the family or creating videos to feed the RAS'ers? Come on Bruno
  #42
Old September 28th 12, 11:18 PM posted to rec.aviation.soaring
Andrzej Kobus
On Sep 28, 12:08*pm, Tobias Bieniek
you can see the current implementation of XCSoar athttp://bugs.xcsoar.org/raw-attachment/ticket/2301/552152_459984440688...
if you look close, you notice a blue line originating from the center of the thermal assistant. the other end of the line marks the point of the proposed thermal core and shows you the direction in which you would need to recenter. from what you've mentioned in the previous posting I understand that this indicator needs to be larger and possibly in an arrow-like form, correct?!
there is also an alternative implementation proposed that looks like this:http://bugs.xcsoar.org/raw-attachmen...iedthermalassi...
feel free to comment on that one too. we are always open to suggestions and constructive criticism.
I think the current solution is better. Just make the arrow like in
WinPilot and the aircraft somewhat bigger or replace with the triangle
like in the proposed solution. The new solution is not as good as the
current one, gives less granular information.
  #43
Old September 29th 12, 02:25 AM posted to rec.aviation.soaring
Wheaton
What happened to a good pair of eyes, a sensitive butt and any of the above varios?
  #44
Old September 29th 12, 02:30 AM posted to rec.aviation.soaring
6PK
They are still needed. But what is wrong with progress?!
  #45
Old September 29th 12, 02:40 AM posted to rec.aviation.soaring
jfitch
On Friday, September 28, 2012 9:36:01 AM UTC-7, Eric Greenwell wrote:
On 9/28/2012 2:22 AM, Tobias Bieniek wrote:
we are talking about http://www.winpilot.com/images4/PRO_1.gif
right?
actually the xcsoar representation is quite similar, only that the
climb values are not drawn in a 3D way, but using a polar diagram.
The arrow that WinPilot shows is also available in XCSoar, just not
as emphasized and it will get larger once the suggestion to recenter
gets stronger. could you elaborate on what exactly you think is
better in the WinPilot representation?
SeeYou Mobile uses circles of differing size and color around the
thermal circle to show the thermal strength. It also has an arrow
suggesting the direction to move, and an audio alert when you should
level your wings to move the circle. The circles and arrow can be
assessed in a glance, or the audio alone can be used to avoid even the
need for a glance, all of which seem at least as useful as Winpilot's
depiction.
Mobile doesn't have the chart of lift versus time. How is this useful?
email me)
The circles used by SYM are very coarse and do not convey much information, nor are they as easily interpreted at a glance. The arrow on SYM does not change length in any meaningful way. In contrast, the Winplot arrow will go from a dot (centered) to a huge thing all across the screen (you are WAY off!), conveying much more instantly. The graph of thermal strength is not useful for centering the thermal, but is useful in deciding when to leave.
On XCSoar, I think the current polar chart is much better than the proposed solutions. The polar chart gives about the same info as the Winpilot cylinder graph, though perhaps not quite as intuitive (up should after all be up, not out....). The arrow though is key, the computer is much fairer at integrating the climb around the circle than your butt or your eyes on a needle. Especially true of a whacky thermal or when your TE is messed up from prop wash. Just make sure the arrow changes length very obviously with lift asymmetry.
  #46
Old September 29th 12, 02:46 AM posted to rec.aviation.soaring
Tony[_5_]
On Wednesday, September 26, 2012 4:48:33 PM UTC-5, Tim Mara wrote:
some settings may not function unless the unit is restarted after making the
changes to specific settings
make sure after changing any settings that when you shut down you check the
box to "save new profile"
tim
i always have the save profile box selected when i close see you mobile. this change won't "stick" when i leave the thermal assistant setup box.
  #47
Old September 29th 12, 02:51 AM posted to rec.aviation.soaring
Tim Taylor
Eric,
I have flown with with both SYM and WinPilot. The 3D graphic, auto start and sound are much better in WP than SYM. I wish SYM would offer a near duplicate of WP climb maximizer. Right now SYM takes two turns to start where WP starts after about 90 degrees. WP's graphic is much better in weak conditions. I have tried both of SYM option, both work OK, but why make so so software when there is better examples out there?
The history graph is extremely helpful. It provides a quick glance at the history to tell if the thermal is maintaining strength or slowly getting weaker. In thermals that are hard to really core you get a sinusoidal curve that helps to decide if you can adjust to find the core or leave the thermal. Again, SYM should add this as an option.
  #48
Old September 29th 12, 04:25 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
One good reason is fiberglass construction, modern airfoils, and heavy
gliders. Fly slowly at 1-26 or K-6 speeds, and even a pellet vario can
work well. Blast through the thermal at 90-100 knots, full of water ...
email me)
  #49
Old September 29th 12, 05:28 PM posted to rec.aviation.soaring
AGL
So, the question becomes, what software is best for what conditions? This post assumes that the varios input to the software shows true lift without gusts etc.
The PC SeeYou stats showed that on 200 km of distance yesterday, with overdeveloped cloudbases as low as 2500 ft AGL, average climbs were as low as 1 knot or zero, getting blown home on wind. Most "circles" showed lift and 4 knot gusts at opposite sides of the circle, and sink everywhere else. Moving to one direction to the other resulted in the same thing with a different set of short term lift bubbles. That's trying both slow 45 degree banks, or back and forth sniffing in the bubbly area that had more lift than sink. When you're that low you have to do what you have to do.
Other people's flights on the OLC that day showed pretty mush the same conditions/results, but I didn't see anyone doing the "sniff around" method.
Sometimes you just have to fly around a bubbly area that has more lift than sink, and a 1 minute average lift option on a very weak bubble day would help. That's about the size of a "sniff around" area, which isn't a thermal at all even if there is more lift than sink. "Last thermal" stats on software I've used/seen so far stops working as soon as you go straight for any length of time.
So, what I'm saying is that the software development and discussion seems to be optimized for classic Texas lift silos on nice days, not for overdeveloped low weak days when you'r relying on the circulation from latent heat of liquidization just under cloudbase.
The suggested XCSOAR thermal assistant screen http://bugs.xcsoar.org/raw-attachmen...lassistant.png would work well for these conditions if it would show a one mile sniffing area with bubble clusters, even if you're flying back and forth rather than circling. The outer ring would still work for the classic thermal situation.
So, I would suggest that Tobias' proposal works for more situations than Andrzej's objection, since not all of us can assume classic thermal silos of lift on non-classic lift days.
  #50
Old September 29th 12, 09:08 PM posted to rec.aviation.soaring
Steve Koerner
I sure hope that the ClearNav folks are gathering input here about the benefit of a good climb maximizer feature. I am in agreement with the posters here who think that only WinPilot has gotten it right so far. I do wish that the ClearNav software would include an emulation of the WinPilot climb maximizer so that I can finally ditch the damn PDA from my panel. The zoom-in feature that the ClearNav offers now is nowhere nears as good. As Tim has noted, the maximizer should come on automatically and quickly, then quickly go off when you leave the thermal. The WinPilot continuous graph is way more effective than lift dots.
One characteristic that is also important and not yet mentioned here is the matter of time delay. WinPilot has no discernable delay; whereas other systems, including ClearNav, have a time delay in the display that makes it very difficult to interpret what's really going on when trying to reposition in a thermal.
WTB: 57mm Cambridge Vario/FS: 80mm Cambridge Vario ufmechanic Soaring 0 March 24th 09 05:31 PM
Martin Mars, Performing Live In Downtown Vancouver! Zomby Woof Aviation Photos 3 January 20th 08 03:10 PM
Martin Mars, Performing Live In Downtown Vancouver! Zomby Woof Naval Aviation 2 January 11th 08 06:10 PM
Navy Performing Well, Keeps Eye on Future Force Otis Willie Naval Aviation 0 February 14th 05 10:06 PM
AN-2 performing a loop Maro_SK Aerobatics 1 March 25th 04 08:18 PM
