Airspeed of military planes
Old January 25th 04, 05:59 AM
Jim Baker
Bingo, the first fully explained and correct answer. Thanks Darrell.
I'm surprised the Hustler flew so slow low level. I just always assumed
since it was such a hotass machine that it flew faster. We planned/flew the
Bone at 560 KTAS/.8Mach.
For the original poster, the B-1B, for example, flies downwind in the
pattern at 270 KIAS. That's the top of the range (IIRC) given in the "Dash
One" and is what we always flew while I was flying from '86-'97.
Cheers,
JB
"Darrell" wrote in message
news:5vBQb.65145$XD5.52941@fed1read06...
If the "Dash One" manual for the military airplane specifies a speed
higher
than 250 below 10,000' it's OK to fly that fast. In the B-58 Hustler,
after
takeoff we came out of afterburners at 350 KIAS and climbed at 425 KIAS
until reaching Mach .90 for climb speed. That's why other aircraft try
to
stay clear of military climb corridors. We flew low level routes at 435
KIAS except for the high speed portion where we flew at 600 KIAS. (and
that's back in the 1960s)
B-58 Hustler History: http://members.cox.net/dschmidt1/
"Tetsuji Rai" wrote in message
s.com...
Airspeed limitation below 10000ft is usually 250kts unless you have been
authorized by the Administrator. However I guess it's a bit slow for
military fighters. So I am curious how fast military fighters fly in
real world. I guess it's very dangerous military aircraft fly much
fast
among civilian planes.
  #42
Old January 25th 04, 06:00 AM
Jim Baker
"Darkwing Duck" wrote in message
s.com...
fast
So how fast is short final in a F-14 or whatever? Always wanted to know.
B-1B final is approx 155 +/- depending on weight.
JB
  #43
Old January 25th 04, 08:55 AM
MLenoch
"BTIZ"
wrote:where is Iron Mountain.. I'm thinking the Upper Peninsula of Michigan?
Yes. It wasn't near any AFBs.
Coulda been above him......we don't know anymore today.
Thx,
VL
  #44
Old January 25th 04, 12:22 PM
Patrick Kormann
Peter Hovorka wrote:
Also in germany. 250kt below FL 100 except for planes which need to be
flown faster.
Probably the same in most ICAO-States? At least it's the same in
Switzerland as well.
  #45
Old January 25th 04, 01:53 PM
Frijoles
Nozzles aft, Harrier approach speed will be in the 155kt +/-range. At 20
nozzles and auto flaps(normal for IFR final), you're somewhat slower but to
be honest I don't recall the airspeed because my primary reference was
always AoA. Depending on the type of landing you intend to make, once
you're in the visual environment, you transition to a higher nozzle angle
(60-75 depending...), and in some instances, STOL flaps where the flaps
program automatically as a function of nozzle angle. "On speed" for a
fixed-nozzle slow landing is around 110kts. The *very* slow rolling
landings you occasionaly see are called rolling vertical landings -- 60 kts
ground speed is the target but the transition to that speed will usually be
over the runway, not on approach final.
s.com...
fast
  #46
Old January 25th 04, 03:53 PM
Steven P. McNicoll
"IBM" wrote in message
Back in 1968 my dad took us to Disneyland.
We flew in to LAX and had some time before the bus left for our
hotel.
I wandered along outside the terminal and was watching the aircraft.
Saw a 747 in action for the first time. I figured it was taxiing into
position ... then it rotated.
I think your family trip was a bit later than that. First flight of the
B747 was February 9, 1969, it entered service in January 1970.
  #47
Old January 25th 04, 03:57 PM
Steven P. McNicoll
"MLenoch" wrote in message
Michigan?
I suppose that depends on when this happened and how you define "near".
Iron Mountain is about 44 miles southwest of the former K.I. Sawyer AFB.
  #48
Old January 25th 04, 04:10 PM
Jim Baker
You're right Frijoles, in the Bone the correct answer for "What airspeed do
you fly on final" is "I don't know/care. I'm flying 7 AoA as required by
the Dash One". There is however, a chart of airspeed and gross weights that
every pilot has and, IAW the Landing Checklist, every final must have an
airspeed computed.
JB
"Frijoles" wrote in message
ink.net...
to
kts
be
s.com...
been
fast
  #49
Old January 25th 04, 04:48 PM
BTIZ
That sounds "near enough" to me..
BT
link.net...
Michigan?
  #50
Old January 25th 04, 05:00 PM
S. Sampson
the Dash One".
Is the AOA indicator a piece of string like Wilbur and Orville had?
airspeed computed.
That's in case the AOA indicator goes T.U. :-)
Updated List of Military Information-Exchange Forums Otis Willie Naval Aviation 0 November 29th 04 02:16 AM
22 Aug 2004 - Today’s Military, Veteran, War and National Security News Otis Willie Naval Aviation 0 August 24th 04 06:47 AM
22 Aug 2004 - Today’s Military, Veteran, War and National Security News Otis Willie Military Aviation 0 August 24th 04 06:46 AM
bush rules! Be Kind Military Aviation 53 February 14th 04 04:26 PM
12 Dec 2003 - Today’s Military, Veteran, War and National Security News Otis Willie Naval Aviation 0 December 12th 03 11:01 PM
