Backup for dropping the gear
Old February 28th 04, 04:56 PM
Julian Scarfe
"d b" wrote in message
ink.net...
You should know all the systems, and the what-if scenarios that go with
them. This includes the mechanical systems. Like how the cables and
pushrods are run through the plane.
Reminds me of a story about the Aztec, on which I did my inital MEP
training.
The procedures go something like this:
To extend the gear, you move the gear selector lever to "down".
In case of failure of the engine-driven hydraulic pump:
1. move the gear selector lever to "down"
2. Extend handle of manual backup pump
3. Pump mumble times to extend gear
4. Stow handle
In case of failure of the hydraulic system
2. actuate the emergency gear extension system
(AFAIR that releases something and the gear drops under gravity)
Not just one backup, but two! But I've only heard of one undercarriage
incident with the aircraft: As the pilot retracted the gear, the gear
selector lever came off in his hand, detaching at a point behind the
panel...
Julian Scarfe
  #42
Old February 28th 04, 07:11 PM
Kyler Laird
"Julian Scarfe" writes:
"actuate" here means "reach under the left seat, flip up the door, and
yank the ring(?)". It causes CO2 to be released from a small tank into
the hydraulic system, making a mess and eliminating further worries
about what to do with the gear or flaps. Gravity plays a minor role.
Realize also that the Aztec is somewhat unique in that it can land and
roll out on retracted gear. Sure, you'll be replacing lots of stuff as
a result but at least it'll roll instead of skid.
--kyler
  #43
Old February 29th 04, 10:22 AM
Julian Scarfe
"Kyler Laird" wrote in message
That's the one. It did sound like a desperation measure.
Julian
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 1 November 24th 03 02:46 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 2 November 24th 03 05:23 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 0 November 24th 03 03:52 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart D. Hull Home Built 0 November 22nd 03 06:24 AM
Wanted clever PA32 engineer's thoughts - Gear extention problem on Piper Lance [email protected] Owning 5 July 22nd 03 12:35 AM
