#41
![]() It happens by arriving at your destination. If you didn't arrive at your destination a search would be initiated. Because you did arrive nothing needs to be done. By arriving... by when? I ask because until you have arrived, you haven't arrived. Action is triggered by action, not by inaction. So, if inaction (not arriving) is the cause, then the proximate cause must be something like a timer going off. It is this detail I'm looking for. Jose -- (for Email, make the obvious changes in my address) |
#42
![]() "Teacherjh" wrote in message ... It happens by arriving at your destination. If you didn't arrive at your destination a search would be initiated. Because you did arrive nothing needs to be done. By arriving... by when? By the time forwarded to the tower. I ask because until you have arrived, you haven't arrived. That's deep. Action is triggered by action, not by inaction. Not in this case. So, if inaction (not arriving) is the cause, then the proximate cause must be something like a timer going off. Why? It is this detail I'm looking for. There is no more detail. |
#43
![]() By arriving... by when? By the time forwarded to the tower. So, if inaction (not arriving) is the cause, then the proximate cause must be something like a timer going off. Why? To give meaning to the part that says "by the time forwarded to the tower". The tower is sent an "expect arrival at 5:34". At 5:36 the plane arrives. What is different about the two minutes after 5:34 compared to the two minutes before 5:34? Just that at 5:34, 5:34 happened, and that is special because it is an expected arrival time that was not consummated. So, at least in somebody's mind, an alarm went off at 5:34. No? Otherwise there is nothing special about the two minutes afterwards, and no search would be initiated. That is, unless what you mean is that a search begins any time a handoff fails under IFR. This is another reasonable interpretation, when "handoff" is expanded to include "expected position report". But then, each ETA (EPRT) would function as the "alarm" I am talking about... getting reset every time. Is this pretty much the way it happens? Jose -- (for Email, make the obvious changes in my address) |
#44
![]() Teacherjh wrote: The tower is sent an "expect arrival at 5:34". It will be printed on a flight progress strip. At 5:36 the plane arrives. What is different about the two minutes after 5:34 compared to the two minutes before 5:34? None. Make it 20 minutes, still no difference. Just that at 5:34, 5:34 happened, and that is special because it is an expected arrival time that was not consummated. But if you landed at 5:36, where were you at 5:34? Say about 3 miles out? Think the tower might know that? Think the approach controller might know that? So, at least in somebody's mind, an alarm went off at 5:34. No? No, no alarm went off because we knew exactly where you were. Otherwise there is nothing special about the two minutes afterwards, and no search would be initiated. Right. That is, unless what you mean is that a search begins any time a handoff fails under IFR. Handoffs fail for any number of reasons. Like your cheap ass transponder isn't sending a signal right now so I can't take the handoff from the center because my computer won't take handoffs like that. Modem failure. Other telephone line failure. You're too low for my radar coverage. If the you are still in radio contact with ATC then we don't need to go look for you. If all the electrics fail we'll do a manual handoff. And when you land we will do exactly nothing, except file the strip. Because nothing needs to be done. You're here and ATC knows that. This is another reasonable interpretation, when "handoff" is expanded to include "expected position report". That's not a handoff. But then, each ETA (EPRT) would function as the "alarm" I am talking about... getting reset every time. If center has no radar with you they will ask for position reports. When you fail to report he will call you on the radio. If you don't answer he will start a search. |
#45
... So, at least in somebody's mind, an alarm went off at 5:34. No? Otherwise there is nothing special about the two minutes afterwards, and no search would be initiated. AFAIK, the search & rescue aspect is the same for IFR and VFR. ATC has nothing to do with it, except that when an IFR flight arrives at a towered airport, the controller contacts the FSS (who is the entity waiting for the "timer to go off") to close the IFR flight plan on the pilot's behalf. That is, unless what you mean is that a search begins any time a handoff fails under IFR. AFAIK, a failed handoff doesn't *automatically* start a search. ATC may in fact prompt a search to begin if the loss of communications is accompanied by some other evidence that there was an accident. Otherwise, normal lost comm procedures would prevail, which basically just mean ATC clears the route filed and/or cleared. Thirty minutes after the filed arrival time, if the aircraft hasn't shown up and the FSS hasn't been told to close the flight plan, *then* search & rescue would begin. Pete |
#46
![]() "Peter Duniho" wrote in message ... AFAIK, the search & rescue aspect is the same for IFR and VFR. ATC has nothing to do with it, except that when an IFR flight arrives at a towered airport, the controller contacts the FSS (who is the entity waiting for the "timer to go off") to close the IFR flight plan on the pilot's behalf. That's not correct. When an IFR flight arrives at a towered airport, the controller contacts nobody, for there's nobody to contact. FSS is not an entity waiting for any "timer to go off" to close an IFR flight plan. When an IFR flight arrives at a nontowered airport, the pilot either contacts ATC directly or has FSS contact ATC for him. FSS just relays the message, they do not close the flight plan. |
#47
![]() "Teacherjh" wrote in message ... To give meaning to the part that says "by the time forwarded to the tower". Explain. The tower is sent an "expect arrival at 5:34". At 5:36 the plane arrives. What is different about the two minutes after 5:34 compared to the two minutes before 5:34? Just that at 5:34, 5:34 happened, and that is special because it is an expected arrival time that was not consummated. So, at least in somebody's mind, an alarm went off at 5:34. No? No. An airplane that had been estimated to land at 5:34, but didn't actually land until 5:36, would be on tower frequency by 5:34, so the tower would know where it is. If the forwarded estimate was off by more than three minutes the facility providing IFR services would revise the estimate. That is, unless what you mean is that a search begins any time a handoff fails under IFR. This is another reasonable interpretation, when "handoff" is expanded to include "expected position report". I mean what I wrote, a handoff is a radar function and has nothing to do with it. But then, each ETA (EPRT) would function as the "alarm" I am talking about... getting reset every time. Is this pretty much the way it happens? Estimates are revised regularly. Sometimes they just take the form of a time change at a specific fix, sometimes a new strip is generated. |
#48
the tower". Explain. Rather than explain, let me ask how a search is begun for an aircraft that does not land when it is expected to. Say you hand off to the tower, and the aircraft does not contact the tower. The plane is below radar. A few minutes go by, then a few more, and still no contact. Perhaps the airplane has been abudcted by aliens, or has crashed in the forest, or has had an electrical failure, or the nut behind the yoke came off. So, what happens? When? Triggered by what? Why? Same question, nontowered. Jose -- (for Email, make the obvious changes in my address) |
#49
... Rather than explain, let me ask how a search is begun for an aircraft that does not land when it is expected to. IMHO, it was obvious that was your question from the get-go. You should find a controller who is more interested in actually answering your question than in telling you that you're wrong (whatever it happens you said). Steve is not that controller. You should know that by now. Pete |
#50
![]() "Teacherjh" wrote in message ... Rather than explain, let me ask how a search is begun for an aircraft that does not land when it is expected to. Say you hand off to the tower, and the aircraft does not contact the tower. The plane is below radar. There are no handoffs without radar. A few minutes go by, then a few more, and still no contact. Perhaps the airplane has been abudcted by aliens, or has crashed in the forest, or has had an electrical failure, or the nut behind the yoke came off. So, what happens? The tower calls the facility providing IFR services. When? A few minutes after the time that was passed to the tower. Triggered by what? Non-contact with the aircraft. Why? Because there should have been contact by that time. Same question, nontowered. Usually the first step is to call the FBO. |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 02:26 PM |
Canadian IFR/VFR Flight Plan | gwengler | Instrument Flight Rules | 4 | August 11th 04 03:55 AM |
us air force us air force academy us air force bases air force museum us us air force rank us air force reserve adfunk | Jehad Internet | Military Aviation | 0 | February 7th 04 04:24 AM |
WINGS: When do the clocks start ticking? | Andrew Gideon | Piloting | 6 | February 3rd 04 03:01 PM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 01:27 PM |
