Switching to ground....
Old April 11th 04, 10:49 AM
Stefan
Newps wrote:
A taxi instruction is never a clearance to enter a runway,
It routinely is.
I've learnt that it is in the USA. In my litle quarrel with Steven I
just said it was not so where I live. There actually is life outside the
USA.
Stefan
  #42
Old April 11th 04, 10:53 AM
Stefan
Steven P. McNicoll wrote:
What have you against sharing airspace with a safety-minded pilot?
Safety means knowing ad adhering to local rules. When some day I'll fly
in the USA, I'll happily learn ad adhere to the US rules, whether they
please me or not. I expect the same vice versa.
Stefan
  #43
Old April 11th 04, 01:15 PM
Steven P. McNicoll
"Stefan" wrote in message
Safety also means having safe and logical rules. The rules in the US are
logical and safe. The rules in Germany are illogical and unsafe.
  #44
Old April 11th 04, 01:30 PM
Dan Luke
... in the USA, you have permission to cross all runways on the
way to your assigned runway, EXCEPT the active runway.
Then I've committed an awful lot of runway incursions without ever being
told about it.
Dan
C172RG at BFM
(remove pants to reply by email)
  #45
Old April 11th 04, 01:37 PM
Steven P. McNicoll
Almost... in the USA, you have permission to cross all runways on the
That's not quite right either. In the US, you have permission to cross all
runways, on the way to your assigned runway, except the ASSIGNED runway.
  #46
Old April 11th 04, 01:40 PM
Steven P. McNicoll
"Dan Luke" wrote in message
ever being told about it.
Well, you have if you crossed the assigned runway. If you merely crossed
other active runways that were not assigned to you then you're okay.
§ 91.129 Operations in Class D airspace.
(i) Takeoff, landing, taxi clearance. No person may, at any airport with an
operating control tower, operate an aircraft on a runway or taxiway, or take
off or land an aircraft, unless an appropriate clearance is received from
ATC. A clearance to "taxi to" the takeoff runway assigned to the aircraft is
not a clearance to cross that assigned takeoff runway, or to taxi on that
runway at any point, but is a clearance to cross other runways that
intersect the taxi route to that assigned takeoff runway. A clearance to
"taxi to" any point other than an assigned takeoff runway is clearance to
cross all runways that intersect the taxi route to that point.
  #47
Old April 11th 04, 03:02 PM
Andrew Sarangan
I am not clear why 'cross any intersecting runways' is a particuarly safe
thing to do. This may make sense at a familiar airport where you know the
taxiways and intersecting runway. At unfamiliar airports, I get extremely
nervous when crossing an intersecting hold short line. There could be
more than one way to get to the assigned runway, and you may be following
a different route than the one the controller had in mind and
inadvertantly cross an active runway. At unfamiliar airports I stop and
verify clearance to cross. I've had controllers get annoyed at me for
that, but better be safe than sorry. Given the increased rate of runway
incursions, this rule never made any sense to me.
"Steven P. McNicoll" wrote in
ink.net:
crossed other active runways that were not assigned to you then you're
okay.
with an operating control tower, operate an aircraft on a runway or
taxiway, or take off or land an aircraft, unless an appropriate
clearance is received from ATC. A clearance to "taxi to" the takeoff
runway assigned to the aircraft is not a clearance to cross that
assigned takeoff runway, or to taxi on that runway at any point, but
is a clearance to cross other runways that intersect the taxi route to
that assigned takeoff runway. A clearance to "taxi to" any point other
than an assigned takeoff runway is clearance to cross all runways that
  #48
Old April 11th 04, 03:12 PM
Stefan
So be it, if it helps to make you feel better. Just be sure you never
leave the logical and safe USA.
Stefan
  #50
Old April 11th 04, 04:57 PM
Teacherjh
Ok, so you are cleared to runway 21. One taxi route takes you across runway
8-26, another equally direct one does not. You are not given a taxi route.
I take it (in the US) you may choose your route and cross 8-26.
Anybody take it differently?
Jose
Best dogfight gun? Bjørnar Bolsøy Military Aviation 317 January 24th 04 07:24 PM
Tactical Air Control Party Airmen Help Ground Forces Otis Willie Military Aviation 0 January 22nd 04 03:20 AM
Wing in Ground Effect? BllFs6 Home Built 10 December 18th 03 06:11 AM
USAF = US Amphetamine Fools RT Military Aviation 104 September 25th 03 04:17 PM
Antenna Ground Plane Grounding Fastglasair Home Built 1 July 8th 03 06:21 PM
