"Aluminum Overcast" damaged by gear collapse
Old May 11th 04, 01:01 AM
Big John
Jay
In military if you hit a prop at idle you coudl put a new prop on and
check tracking, etc and then do an oil change and fly (over field) for
several hours (5 maybe) and land and chck the screens. If nothing in
screens they would release the engine back in service.
Forget the rpm that if you exceeded then it was an engine change
(maybe 1200????).
You of course ran the engine some on ground before flying it to
determine it's condition for test flight..
So on the '17 if the engines were in idle they might get away with
just prop repairs???? and sheet metal.
Long time ago in a land far away.
Big John
On Sun, 09 May 2004 13:49:35 GMT, "Jay Honeck"
Are you really worried about a catastrophic failure when you've got
3 other engines?
Are you saying that they won't have to tear down those engines?
  #43
Old May 11th 04, 01:11 AM
MLenoch
Big John
John, not so far away. This is still done today. Hopefully this will be the
case for this B-17.
VL
  #44
Old May 11th 04, 03:38 AM
Big John
mlenoch
Dollars to donuts they pulled the gear up. Looked like a 'classical'
inadvertent retraction.
Forget which bird, but flaps and gear controls were side by side and
not too different shaped. To prevent inadvertent retraction the rule
was you came to a full stop after clearing R/W and then looked down
and retracted the flaps. This pulling flaps up by feel while moving
was a invitation to disaster.
Big John
Big John
case for this B-17.
VL
  #45
Old May 11th 04, 09:17 AM
Dale
On the Fortress I was flying the gear and flap switches were both simply
toggle switches...with the gear switch being a "guarded" switch.
Procedure was at least two crew had to confirm your finger was on the
flap switch before activating.
Knowing the gear system I can't think of a reason/way for both to fail
together. Sad, but these things do happen.
Luckily they are tough old birds...the only limit to getting her in the
air will be money.
Dale L. Falk
There is nothing - absolutely nothing - half so much worth doing
as simply messing around with airplanes.
http://home.gci.net/~sncdfalk/flying.html
  #46
Old May 11th 04, 02:00 PM
William W. Plummer
"Dale" wrote in message
air will be money.
Are there not "squat" switches that prevent the gear from being raised if
the plan is on the ground?
  #47
Old May 11th 04, 02:37 PM
G.R. Patterson III
Rick Durden wrote:
George,
CAF is already saying the copilot pulled the gear up when he went for
the flaps, despite being told to keep his hands off the flap switch
until off the runway.
It's interesting then that as of this morning, the EAA's position is still "We are
using that new video to help us understand exactly what happened. Our emphasis,
naturally, is on the landing gear and discovering why it malfunctioned".
They seem to be a little slow getting the word.
George Patterson
If you don't tell lies, you never have to remember what you said.
  #48
Old May 11th 04, 02:42 PM
G.R. Patterson III
Kyle Boatright wrote:
1) Isn't the screw jack "sized" for air loads, with some sort of over
center mechanism to handle the ground loads?
Thinking about it some more, you're probably right in a way. Although there isn't any
over-center mechanism, there would normally be little pressure on the screw mechanism
once that knee joint section straightens out. It's probably sized to keep the joint
straight and can't take the load when the joint begins to fold.
George Patterson
  #49
Old May 11th 04, 04:02 PM
Dale
In article t74oc.69315$0H1.6524917@attbi_s54,
Originally no, but on the 909 a squat switch had been added. It sets
low on the left gear leg, soaked in Wright radial oil G and I wouldn't
trust it for a second.
Dale L. Falk
  #50
Old May 11th 04, 08:10 PM
Robert M. Gary
Orval Fairbairn wrote in message .. .
James Robinson wrote:
It is more likely that the screw jacks failed as a result of an
inadvertant throwing of the retraction switch. It isn't the first time
that has happened, and probably not the last!
The 172 drivers may snicker but those of us that drive retracts will
never make comments about gear ups. (knocking on any piece of wood I
can find).
-Robert
EAA's B-17 "Aluminum Overcast" Gear collapse at Van Nuys airport BlakeleyTB Home Built 4 May 8th 04 06:15 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 1 November 24th 03 02:46 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 2 November 24th 03 05:23 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 0 November 24th 03 03:52 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart D. Hull Home Built 0 November 22nd 03 06:24 AM
