#41
On Wed, 18 Aug 2004 08:07:16 -0400, Cub Driver
wrote: On Wed, 18 Aug 2004 01:00:01 GMT, Roger Halstead wrote: The old Hershey Bar winged Cherokee 180s also used the Johnson bar. It was the only plane where I could raise the flaps and actually shorten the landing roll. The electric ones are just too slow. I took Damien Del -- well, I took the Andover NJ "bush flying" course last year. He taught this technique in the Aviat Husky. (Also flying in ground effect over the corn stubble short of the threshold, then dumping the flaps just as you reach the grass. Voila! 250-foot landing!) Couple years ago I took part in a spot landing contest. It was pretty much a no rules type rather than you and only reduce throttle and add flaps type of thing. I thought I was doing pretty good touching down on the mains with something like 21 or 22 inches to go. The a couple pilots flying a 172 both made 11 inches. Then the FBO, Terry Blodgett got out his old V-35. He set the mains on the tape and cut it in two. At any rate, where I was headed was Cherokees, Johnson bars, and short fields. There was a Cherokee that came in with all seats full. I think it was a Cherokee 6, but it's been a while. At any rate (think I already said that), he was dragging it in and then dumped the flaps. Thing is, he was a tad higher than he though. It sounded like someone dropped a trash can on the runway. A big trash can:-)) All that and he didn't come close to the 4 closest landings. Those Cherokees are rugged! I've seen proofsnicker I had a bleeding knuckle after a couple hours of this. Just one? Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com all the best -- Dan Ford email: (put Cubdriver in subject line) The Warbird's Forum www.warbirdforum.com Expedition sailboat charters www.expeditionsail.com |
#42
![]() Roy Smith wrote: Now I fly mostly Pipers. I really like the manual flaps instead of Cessna's electric ones, and curse the electric trim Piper uses instead of Cessna's manual trim system. Maule gives you manual systems for both! George Patterson If you want to know God's opinion of money, just look at the people he gives it to. |
#44
On Wed, 18 Aug 2004 17:21:19 GMT, "G.R. Patterson III"
wrote: If you want to know God's opinion of money, just look at the people he gives it to. This has stuck in my mind..... hehe. |
#45
"Roy Smith" wrote in message
... Now I fly mostly Pipers. I really like the manual flaps instead of Cessna's electric ones, and curse the electric trim Piper uses instead of Cessna's manual trim system. Is there not a manual trim wheel then? Paul |
#46
"Paul Sengupta" wrote: "Roy Smith" wrote in message ... Now I fly mostly Pipers. I really like the manual flaps instead of Cessna's electric ones, and curse the electric trim Piper uses instead of Cessna's manual trim system. Is there not a manual trim wheel then? Paul There is, but it's not in a very convenient place (stuffed between the front seats). The Piper electric trim is very convenient when it works, the problem is that it so often doesn't work :-( |
#47
I've never flown a Piper with electric trim, but I find the manual trim
wheel between the seats very convenient. You don't have to lean forward to work it like the manual trim in a Skyhawk (the only Cessna I've flown), and it falls easily to hand without looking. The only problem I've had was when I weighed 60 lb more and I had a similar-sized passenger in the right seat. Then I found that it was a bit of a squeeze (that might have been misunderstood) getting to it between our hips :-). -- Bob (Chief Pilot, White Knuckle Airways) I don't have to like Bush and Cheney (Or Kerry, for that matter) to love America "Roy Smith" wrote in message ... In article , "Paul Sengupta" wrote: "Roy Smith" wrote in message ... Now I fly mostly Pipers. I really like the manual flaps instead of Cessna's electric ones, and curse the electric trim Piper uses instead of Cessna's manual trim system. Is there not a manual trim wheel then? Paul There is, but it's not in a very convenient place (stuffed between the front seats). The Piper electric trim is very convenient when it works, the problem is that it so often doesn't work :-( |
#48
On Thu, 19 Aug 2004 15:00:08 +0100, "Paul Sengupta"
wrote: "Roy Smith" wrote in message ... Now I fly mostly Pipers. I really like the manual flaps instead of Cessna's electric ones, and curse the electric trim Piper uses instead That electric trim is one of the greatest things since sliced bread. of Cessna's manual trim system. Is there not a manual trim wheel then? Yup Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com Paul |
#49
In article , Bob Chilcoat
wrote: I've never flown a Piper with electric trim, but I find the manual trim wheel between the seats very convenient. You don't have to lean forward to work it like the manual trim in a Skyhawk (the only Cessna I've flown), and it falls easily to hand without looking. The only problem I've had was when I weighed 60 lb more and I had a similar-sized passenger in the right seat. Then I found that it was a bit of a squeeze (that might have been misunderstood) getting to it between our hips :-). To quote my wife: "You do tell your other passengers what you're doing wehen you reach down there, right??!!" |
#50
On Thu, 19 Aug 2004 10:42:17 -0400, Roy Smith wrote:
In article , "Paul Sengupta" wrote: "Roy Smith" wrote in message ... Now I fly mostly Pipers. I really like the manual flaps instead of Cessna's electric ones, and curse the electric trim Piper uses instead of Cessna's manual trim system. Is there not a manual trim wheel then? Paul There is, but it's not in a very convenient place (stuffed between the front seats). The Piper electric trim is very convenient when it works, the problem is that it so often doesn't work :-( I was a partner in a Cherokee 180 (N6360J). It had electric trim which never failed in the 375 hours I put on it. I've never heard of the current partners complain. The trim wheel is between the seats in a natural position to just put your hand on it. For all 5 of us and the partners since, it has worked just fine. I think they've worn out two engines in that plane, but the trim has not been a problem. BTW I'd love to have an electric trim in the Deb that worked like the one in old sixty Juliet. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
Flap Hinge Moment Calc | Bo | Home Built | 2 | February 2nd 05 10:26 AM |
Flap Hinge Moment Calc | Bo | Home Built | 0 | February 2nd 05 06:01 AM |
Flap angles | DeltaDeltaDelta | Piloting | 34 | May 18th 04 12:09 AM |
McFarlane flap rollers - PIREP please | Roger Long | Owning | 3 | November 3rd 03 10:04 PM |
Flap design question | Chris W | Home Built | 1 | August 4th 03 02:50 PM |
