#41
It occurs to me that compared to a piston engine, the turbine is 1) more
expensive, and 2) more reliable. But, why are those things true? Looking at it another way, is there some inherent reason why piston engines are cheaper to produce? Is there also some inherent reason why they're less reliable? If I were to give you the $/HP budget a turbine designer has to work with, would you be able to design a piston engine that was as reliable as a turbine? |
#42
![]() Roy Smith wrote: Looking at it another way, is there some inherent reason why piston engines are cheaper to produce? The materials are cheaper and the tolerances (especially balancing) much looser. Is there also some inherent reason why they're less reliable? The internal pressures are higher and the moving parts are constantly and rapidly reversing direction. George Patterson If a man gets into a fight 3,000 miles away from home, he *had* to have been looking for it. |
#43
On Sat, 18 Sep 2004 11:50:43 -0400, Roy Smith wrote:
The biggest problem I can see with a diesel is cold-weather operation. I used to have a diesel car (1980's era VW Rabbit). It was a bitch to ^^^^^^^^^^^^^^^^^^^ start in really cold weather. forget *everything* you know about those antiques regarding diesel engines. #m -- The more one is absorbed in fighting Evil, the less one is tempted to place the Good in question. (J.P. Sartre) |
#44
"Roy Smith" wrote in message
... It occurs to me that compared to a piston engine, the turbine is 1) more expensive, and 2) more reliable. But, why are those things true? Looking at it another way, is there some inherent reason why piston engines are cheaper to produce? Is there also some inherent reason why they're less reliable? I believe that there are at least two factors: A turbine needs to be constructed out of more expensive materials, because of higher temperatures involved in the operation of the engine, and it needs to be constructed to higher tolerances, because it's very sensitive to imbalances. These contribute to cost. On the other hand, a turbine has no parts that reverse direction, while a piston engine has many such parts. So the turbine suffers less stress, when constructed correctly, than a piston engine does. It's also "simpler", in the sense that the engine doesn't need as many moving parts to accomplish the same thing. These contribute to reliability. The above ignores higher maintenance costs, which are probably related to several factors, including cost of parts, cost of training for a mechanic, and stricter maintenance guidelines (meaning maintenance happens more often and is more thorough). If I were to give you the $/HP budget a turbine designer has to work with, would you be able to design a piston engine that was as reliable as a turbine? Well, one problem is that the assertion that turbines are more reliable is, in my opinion, unproved. A well-maintained piston engine can be VERY reliable, while a poorly maintained turbine might not last very long at all. It's hard to know for sure, because most turbines are operated in an environment where there are strict maintenance standards. Those standards applied to piston engines might well result equally reliable piston engines. I think one interesting way to address your question is to look at what causes engine failures. In piston engines, it's usually some secondary component, such as fuel delivery or oil circulation. When it's a primary component, often it's something that's either suffered from poor operation techniques (valves and pistons, for example) or a manufacturing defect (crankshafts). Turbines do suffer from manufacturing defects (if I recall, there was an uncontained failure in the 90's on some rear-engine jet -- 727, DC-9 or something like that -- where the blade failure was due to some metallurgical problem). But they have stricter maintenance regimes (which more often will catch problems with secondary components), and perhaps more importantly, they have stricter operating standards and instrumentation to monitor operation (for example, overtemp operation is strictly monitored and limits specified, and if those limits are exceeded, the engine is automatically up for inspection and/or repair). Which is a long way of saying that I think it's entirely possible that if you spent as much on a piston engine as you might spend on a turbine, and followed similar practices with respect to operation and maintenance, you could achieve similar reliability rates. Pete |
#45
![]() Peter Duniho wrote: Well, one problem is that the assertion that turbines are more reliable is, in my opinion, unproved. A well-maintained piston engine can be VERY reliable, while a poorly maintained turbine might not last very long at all. It's hard to know for sure, because most turbines are operated in an environment where there are strict maintenance standards. Those standards applied to piston engines might well result equally reliable piston engines. Perhaps a study of the durability of engines used for things like APUs, rather than aircraft powerplants would be informative. Such engines, both piston and turbine, are likely to be only moderately well maintained. George Patterson If a man gets into a fight 3,000 miles away from home, he *had* to have been looking for it. |
#46
#47
![]() Well, the Rabbit I had was built with exactly the same block, pistons, crank, etc, as the gas version. The basicly just slapped a shallower head on the thing to increase the compression ratio. I could have sworn the Rabbit Diesel had a way different engine, but I could be wrong. The debacle I'm talking about was Chevey's (?) attempt to power pickups with a gas engine converted to diesel by basically the same method. Not pickups AFAIK; station wagons and maybe sedans. This was Roger Smith at his finest. A friend bought one with a dead@55000 mile engine. It was an stock gas block; no where NEAR beefy enough. The blowby was so bad, the engine soiled itself at every seal; he'd get 250 miles to the quart; all leakage. At least it didn't rust! It had a one-of-kind starter and flywheel. The distributor was replaced with a vacuum pump to drive the HVAC door flaps. It had dual batteries, designed wrong. The brakes were run off the PS pump, so when the engine stalled, stop NOW. He put in a gas 350 and drove it for 10 years more. -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
#48
In rec.aviation.owning David Lesher wrote:
Well, the Rabbit I had was built with exactly the same block, pistons, crank, etc, as the gas version. The basicly just slapped a shallower head on the thing to increase the compression ratio. I could have sworn the Rabbit Diesel had a way different engine, but I could be wrong. The debacle I'm talking about was Chevey's (?) attempt to power pickups with a gas engine converted to diesel by basically the same method. Not pickups AFAIK; station wagons and maybe sedans. This was Roger Smith at his finest. A friend bought one with a dead@55000 mile engine. It was an stock gas block; no where NEAR beefy enough. The blowby was so bad, the engine soiled itself at every seal; he'd get 250 miles to the quart; all leakage. At least it didn't rust! It had a one-of-kind starter and flywheel. The distributor was replaced with a vacuum pump to drive the HVAC door flaps. It had dual batteries, designed wrong. The brakes were run off the PS pump, so when the engine stalled, stop NOW. He put in a gas 350 and drove it for 10 years more. -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 There were pickups. A friend bought one new and had the engine blow at about 40k miles. Thanks to California smog laws, he found his choices were replace it with another new diesel (big bucks) or get an old gas engine and convert it to propane and try to recover some of the investment. This was way before 50k warranties. -- Jim Pennino Remove -spam-sux to reply. |
#49
#50
