New theory of flight released Sept 2004
Old October 5th 04, 03:49 PM
Mark Oliver
Default New theory of flight released Sept 2004
The current theory of flight is based upon the Bernoulli's Principal, the
pressure of a fluid (liquid or gas) decreases at points where the speed of
the fluid increases. The airfoil is designed to increase the velocity of
the airflow above its surface, thereby decreasing pressure above the
airfoil. Simultaneously, the impact of the air on the lower surface of the
airfoil increases the pressure below. This combination of pressure decrease
above and increase below produces lift. Pressure is reduced due to the
smaller space the air has above the wing than below. Air cannot go through
the wing, so it must push around it. The surface air molecules push between
the wing and outer layers of air. Due to the bump of the airfoil, the space
is smaller and the molecules must go faster.
THIS HAS A MAJOR PROBLEM - specifically inverted flight. The current theory
of flight utilizing the Bernoulli's Principal is only applicable to normal
level flight. However, we know and observe that inverted flight is
possible. Thus, the Bernoulli's Principal is no longer applicable to
inverted flight, so there must be another theory that supports flight, be it
level or inverted.
The new theory of flight is based upon the new theory of Gravitational
Vector Force (released Sept 2004). Utilizing Newton's laws that equal
opposite force is generated at right angles, be it applied at once or
successively, and if the angle is oblique (slanted) a new force is
generated. Then inverted flight is possible as force is always generated at
right angles, and this is towards the ground in all cases. The net
difference between the initial velocity and resistance force generated at
the leading edge at right angles (downwards) creates a new force called
Gravitational Vector Force, and it travels in the opposite direction
(upwards) to maintain balance, impacting the bottom of the wing. The wing
becomes less efficient in inverted flight due to the design of the airfoil,
however it is still possible.
This new theory of flight also supports the following;
1) the new force manifests at a faster rate than initial velocity, hence the
wing becomes more efficient at faster speeds
2) As you extend spoilers and flaps at the leading and trailing edges, the
bottom of the wing now becomes "cupped" like a satellite dish, and able to
capture more Gravitational Vector Force, creating more lift
You may read more about this new theory at www.threexd.com
Mark Oliver
Old October 5th 04, 04:06 PM
Larry Dighera
On Tue, 5 Oct 2004 10:49:58 -0400, "Mark Oliver"
wrote in
Was this theory formerly held captive? Who released it?
This subject has been discussed in depth in this newsgroup over the
years:
http://groups.google.com/groups?as_q...ting&lr=&hl=en
Old October 5th 04, 04:14 PM
Dudley Henriques
Well, you're on the right newsgroup anyway. Have fun with this one. I
think I'll just sit back and watch :-))
All the best to you,
Dudley Henriques
International Fighter Pilots Fellowship
Flight Instructor/Aerobatics/Retired
"Mark Oliver" wrote in message
speed of
of
decrease
through
between
space
theory
normal
be it
level or inverted.
generated at
at
called
wing
airfoil,
hence the
able to
Mark Oliver
Old October 5th 04, 04:57 PM
Michael Houghton
Howdy!
Mark Oliver wrote (from another space-time
continuum):
[snip intro that actually passes the smell test]
level or inverted.
That is a fascinating claim -- one that bespeaks access to the good drugs.
You should share them.
[snip exposition of material that shows Mark isn't wearing his tinfoil
beanie]
yours,
Michael
Michael and MJ Houghton | Herveus d'Ormonde and Megan O'Donnelly
| White Wolf and the Phoenix
Bowie, MD, USA | Tablet and Inkle bands, and other stuff
http://www.radix.net/~herveus/wwap/
Old October 5th 04, 05:19 PM
Dan Luke
"Mark Oliver" wrote:
[snip "interesting" lift ideas]
When you get through with this one, how about explaining the effect of
downwind turns to us?
Dan
C-172RG at BFM
Old October 5th 04, 05:22 PM
OtisWinslow
Bernoulli sucks. The wing lifts because air pushes on one side
and not the other.
decrease
between
space
theory
it
level or inverted.
at
airfoil,
Mark Oliver
Old October 6th 04, 11:00 AM
Cub Driver
On Tue, 05 Oct 2004 16:22:30 GMT, "OtisWinslow"
and not the other.
That's what I told my flight instructor, but he did not seem
impressed.
all the best -- Dan Ford
email: (put Cubdriver in subject line)
Warbird's Forum
www.warbirdforum.com
Piper Cub Forum www.pipercubforum.com
Viva Bush! www.vivabush.org
Old October 6th 04, 07:03 PM
Andrew Gideon
impressed.
I think my instructor and I came to the conclusion that my airplane didn't
have lift; it had scare. The way I flew, the Earth just naturally pulled
away from me.
- Andrew
Old October 5th 04, 05:44 PM
Hartwig Flamm
No it's not!
Do not stress old Bernoulli. His findings are restricted to the flowing
media only. You can use the _some_ of his laws to find the forces caused by
the air on the structure of the airplane.
In fact the "real" cause for an airplane to stay up is inertia and friction
of the air.
Please see some new publications on aerodynamics (past 1980') to get an idea
on how that works. (You might want to dust of Your knowledge about
differential equations.)
theory of flight utilizing the Bernoulli's Principal is only applicable to
normal
Once again if You want to find what the moving air is doing Bernoulli is
fine. And if You do some experimenting, like I did, You will find there is
no dependence from the direction.
What Newton was that? Can You cite any document from Mister Newton?
The paragraph above says that a prop can not produce any thrust when heading
straight down? I haven't ever done that but I guess some of the Aerobatics
guys around here can prove You wrong on this point.
And one last statement: There is no "Universal Balance" anywhere (like there
is no "Earth in the Balance"). There is either Stability or Transformation.
Prove me wrong on _that_ if You can!
I keep flying with my old friend Bernoulli and his brother until then....
Remove the cork to Reply by e-Mail.
Old October 5th 04, 09:35 PM
Blanche
Hartwig Flamm wrote:
No it's not!
of the air.
Gee, I always thought it was money and magic...
Is there any way we can introduce Dark Energy and Dark Matter into
this?
(*snorfle*)
new theory of flight released Sept 2004 Mark Oliver Aerobatics 1 October 5th 04 10:20 PM
ramifications of new TSA rules on all non-US and US citizen pilots paul k. sanchez Piloting 19 September 27th 04 11:49 PM
Flight Simulator 2004 pro 4CDs, Eurowings 2004, Sea Plane Adventures, Concorde, HONG KONG 2004, World Airlines, other Addons, Sky Ranch, Jumbo 747, Greece 2000 [include El.Venizelos], Polynesia 2000, Real Airports, Private Wings, FLITESTAR V8.5 - JEP vvcd Home Built 0 September 22nd 04 07:16 PM
Looking for Cessna Caravan pilots [email protected] Owning 9 April 1st 04 02:54 AM
