#41
All probably true.
"C Kingsbury" wrote in message .net... "Mike Rapoport" wrote in message ink.net... "C Kingsbury" wrote in message over 100HP, assuming of course they allow us to fly at all. Look at Europe- I don't want that to be the future of GA. Nobody does, what is your proposed solution?. Over the next five years? Mogas. We've gotta get off the 100LL before it kills us. Many engines can run it already and higher-performance ones ought to be able to with things like the PRISM ignition systems. Next decade? Diesel/Jet-A engines. Higher efficiency and longer life, and with increased production volume costs ought to come down. I don't know that I'd buy a new plane right now that relies on a fuel whose supply is unclear. Beyond that, hydrogen may become practical- checkout www.safehydrogen.com for one of a thousand little companies trying to turn it into a practical power source for vehicles. Weight being a much bigger issue for airplanes than for cars, we may see anti-gravity vehicles before we see non-Fossil Fuel burning aircraft. Of course, if we can stop using FF everywhere they're not absolutely needed, we may be able to make do with what we have, or even switch to biodiesel. It is of course likely still that costs will go up. At least we won't be as regulated as in Europe, and we will on average have higher incomes to afford it. But much like the dying days of the Old West, it seems like the glory days of GA lie behind us, and our best hope of keeping flying accessible to a maximum number of people will in fact be LSAs, in other words, the European solution. Best, -cwk. |
#42
All probably true.
#43
Hi kontiki,
They have always done this. Gasoline in MN needs to be different from that in AZ. and WHY? This is NOT necessary, it is pure politics and costs us all money and wasted time and overhead. Thank you again Mr. Negative. It IS neccessary. Just to name an example, evaporation proporties need to be adjusted to climatic conditions. Try and fill your car in AZ, preferably at a high altitude location, then drive it to one of the northern states without refueling (probably won't work with the mileage you get on current US cars..:-)) and try to start it in the morning at below freezing temperatures. You will be surprised. regards, Friedrich -- for personal email please remove "entfernen" from my adress |
#44
Hi kontiki,
#45
But Friedrich!
The reasons here in the States that the gas is different has nothing to do with the reasons you put forth. The reasons here is because a group of politicians pass laws for the tree huggers, to make more anti-pollution standards that the gas industry in this country is not equipped to handle. And before the tree huggers get offended, AHHH go get in YOUR car and drive to work just like everybody else..earth murderer!!!!HAHA But anyways , hard starting in altitude and extreme cold has nothing to do with the political agenda of our gas problems. It should be those reasons you put forth, but sadly it is our government over legislating..as it tends to do! Patrick "Friedrich Ostertag" wrote in message ... Hi kontiki, They have always done this. Gasoline in MN needs to be different from that in AZ. and WHY? This is NOT necessary, it is pure politics and costs us all money and wasted time and overhead. Thank you again Mr. Negative. It IS neccessary. Just to name an example, evaporation proporties need to be adjusted to climatic conditions. Try and fill your car in AZ, preferably at a high altitude location, then drive it to one of the northern states without refueling (probably won't work with the mileage you get on current US cars..:-)) and try to start it in the morning at below freezing temperatures. You will be surprised. regards, Friedrich -- for personal email please remove "entfernen" from my adress |
#46
But Friedrich!
#47
![]() I've been keeping an eye out looking for types of businesses that would benefit from climate change of the sort that the tree-huggers are always talking about. The way I see it, you make a bunch of small speculative investments now, and if it ever comes to pass, you only need one of them to hit in order to make a killing. Biggest problem is no one knows when it might start to hit or what the real effects would be, so you'd probably need to place an awful lot of bets, and the return is unclear. Perhaps I should just start a fund and go ringing up rich individuals... Best, -cwk. "Mike Rapoport" wrote in message k.net... I think that you are seeing the future clearly. Mike MU-2 |
#48
#49
![]() "W P Dixon" wrote in message ... But Friedrich! The reasons here in the States that the gas is different has nothing to do with the reasons you put forth. The reasons here is because a group of There was a Wall Street Journal piece about a year ago that said there were something like 30-50 (may have been a lot more) different gas blends sold in the US, with neighboring states (with equivalent geography/climate) often mandating slightly different blends. This isn't as bad as the specialized handling 100LL requires, but it does have the effect of adding a layer of signifcant complexity to the refining and transport of autogas. It also means that frequently only one refinery produces a given blend, meaning any shutdowns or such can cause prices to spike. This is why oil refiners love the idea of blends: it turns what looks like the ultimate commodity into a more specialized product, allowing them to maintain higher margins. I am not normally a fan of federal overruling of state authority, but there is really no reason why we should have more than 4-5 blends sold across the US. Still, none of this has anything to do with long-term supply and demand. While tar sands and deep offshore drilling almost certainly ensure we won't simply run out of the stuff in our lifetime, prices will almost certainly rise significantly. -cwk. |
#50
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 02:26 PM |
General Aviation Legal Defense Fund | Dr. Guenther Eichhorn | Aerobatics | 0 | May 11th 04 10:43 PM |
General Aviation Legal Defense Fund | Dr. Guenther Eichhorn | Owning | 0 | May 11th 04 10:43 PM |
Associate Publisher Wanted - Aviation & Business Journals | Mergatroide | Aviation Marketplace | 1 | January 13th 04 08:26 PM |
Fuel dump switch in homebuilt | Jay | Home Built | 36 | December 5th 03 02:21 AM |
