The answer to questions such as this can be found in the POH from the
manufacturer who supposedly knows more than the average flight instructor or public thought about what is right. For the Cessna Model 152 Section 4 Normal Procedures under "Takeoff" "Power Check" says "It is important to check full-throttle engine operation early in the takeoff run. Any sign of rough engine operation or sluggish engine acceleration is good cause for discontinuing the takeoff. IF THIS OCCURS, YOU ARE JUSTIFIED IN MAKING A THOROUGH FULL-THROTTLE STATIC RUNUP BEFORE ANOTHER TAKEOFF IS ATTEMPTED. The engine should run smoothly and turn approximately 2280 to 2380 RPM with carburetor heat off and mixture leaned to maximum RPM." (Emphasis added.) You will not harm the engine therefore if you use 2000 RPM and lean to clean the plugs. I suggest if you are serious about this you discuss the matter with a mechanic. |
On Sat, 09 Oct 2004 10:54:44 GMT, "Roger Long"
wrote in :: Any thoughts? http://www.sacskyranch.com/faq_spark_plug/index.html http://www.sacskyranch.com/faq_spark_plug/FAQ00007.htm |
"Roger Long" wrote
I can't remember where I "learned" it but I always thought 1800 RPM was the limit for ground running leaned to clear plugs. I had a really bad one yesterday with 250 RPM drop. I taxied back to the shop and they said to try full throttle before pulling the plugs. It worked but running the engine full power (near sea level) while leaned for best power and peak EGT with minimum airflow for the minute it took seems pretty abusive to me. Maybe you can get away with it because the CHT's have not yet risen to max. Any thoughts? What were you taught? I was tought the full-power tactic. But what I found out empirically was that leaning like crazy for all ground ops (to the point the engine will barely run) has so far prevented the mag drop problem from occurring again. I posted about this within the past few months and found that others use similar procedures. Jim Rosinski |
For the engine, the higher the RPM the better. However, 1800 is used
because its a high RPM but doesn't suck as many rocks into the prop as full RPM. If you run up to full RPM everytime you'll send up replacing your prop every annual. -Robert "Roger Long" wrote in message ... I can't remember where I "learned" it but I always thought 1800 RPM was the limit for ground running leaned to clear plugs. I had a really bad one yesterday with 250 RPM drop. I taxied back to the shop and they said to try full throttle before pulling the plugs. It worked but running the engine full power (near sea level) while leaned for best power and peak EGT with minimum airflow for the minute it took seems pretty abusive to me. Maybe you can get away with it because the CHT's have not yet risen to max. Any thoughts? What were you taught? |
On Sat, 09 Oct 2004 10:54:44 GMT, "Roger Long" wrote:
Any thoughts? What were you taught? However you monitor engine temperature, oil temp or CHT, just avoid overheating the engine. I was taught to try a lower RPM for a set period, and if that did not work go to full power for a set period while closely tracking engine temp. By set period, I was taught 30 or 60 seconds timed by a watch, not by feel or guessimate. Demonick |
I can't remember where I "learned" it but I always thought 1800 RPM was the limit for ground running leaned to clear plugs. I had a really bad one yesterday with 250 RPM drop. I taxied back to the shop and they said to try full throttle before pulling the plugs. It worked but running the engine full power (near sea level) while leaned for best power and peak EGT with minimum airflow for the minute it took seems pretty abusive to me. Maybe you can get away with it because the CHT's have not yet risen to max. Any thoughts? What were you taught? The standard technique taught in many airplanes for the short-field takeoff is brakes locked, full power, lean for best RPM, and go. This can take some time for a student, and I try to get the instructors to limit it to 15 seconds or so, no more. We use the same technique to clear fouled plugs. If they don't clear in a few seconds at full power, they aren't going to clear adequately for flight. If it's just a bit of oil that's fouled the bottom plugs during an extended idle, they'll clear. If it's lead fouling, they won't clear well and need to come out and get serviced. Dan |
Clearing a fouled plug | Roger Long | Piloting | 3 | July 6th 04 05:53 AM |
