Ads-b and sailplanes
Old April 7th 15, 09:37 PM posted to rec.aviation.soaring
Darryl Ramm
Default Ads-b and sailplanes
On Tuesday, April 7, 2015 at 10:00:36 AM UTC-7, Andy Blackburn wrote:
On Tuesday, April 7, 2015 at 9:43:26 AM UTC-7, wrote:
Problem: The rest of the world isn't concerned about frequency congestion and airlines are less than enthusiastic about having to have both mod existing 1090 transponders and ALSO install a UAT ADS-B box onboard. Solution: Keep 1090 for aircraft that fly above 18,000 since they are the ones that will encounter the overseas environment.
Isn't it true that most of the RF congestion comes from the bandwidth-intensive interaction of TCAS with Mode C (and earlier) transponders? I've been told that the reason Europe didn't have to go down the UAT (or equivalent) path was because they mandated Mode S. It's possible the US could have done the same, but apparently the FAA didn't want to force a transponder upgrade (which seems silly given all the other mandated equipment and duplicate antennae). And so we get the mess we have that, as you pointed out, the FAA isn't so concerned about because our concerns have little to do with the problems they were solving for.
I remain somewhat skeptical that GA will go en masse to UAT. If Trig comes out with a Mode S/1090ES Out single box that hooks up to an existing Mode C antenna I think it could be quite popular.
Andy
That would be my summary of much of this (and BTW TCAS only interrogates Mode C or S, it won't ever interrogate Mode A and just won't see a Mode A transponder at all). I think a significant part of the issue was the FAA was under pressure from lobbyists like AOPA who wanted to keep Mode C transponders in use. Doing that can cause significant radio frequency congestion issues because of TCAS interrogation of those Mode C transponders, and also makes SSR a little less wonderful than it could be in a pure Mode-S environment. I was never impressed by the technical depth of the arguments used that dual-link was required because of 1090MHz/1030MHz congestion. This at least in part relied on some Monte-Carlo simulation of RF congestion in the LA Basin, but there just never really seemed to be as much academic research and debate as I would have hoped with this. I would have preferred to see wider research, with more broad assumptions/scenarios allowed, all the other mitigation options really well explored, and more academically peer-reviewed studies made before all the cost of a complex dual-link ADS-B system was inflicted on owner/pilots and the US taxpayer.
But anyhow layering complexity on complexity the FAA went dual-link over 109ES and UAT. Then you fold in other agendas like trying to sell UAT to GA aircraft by providing FIS-B data over UAT. Although you only need a cheap UAT-receiver to use FIS-B so it does not really encourage adoption of ADS-Out on either UAT or 1090ES link-layer. And a cynical view was some folks in the FAA just wanted to resurrect the failed FAA FIS (airborne VHF weather data) service. Did we get dual-link becasue of FIS-B or did we get FIS-B because of dual-link? The reality is maybe parts of both. And WX Satellite weather is a better product with better features and wider coverage, especially on the ground pre-flight). But WX Weather requires a paid subscription unlike FIS-B (although you may see paid parts of FIS-B in future from ITT/Excelis). Possible revenue from commercial use of FIS-B is maybe another decision factor in the whole dual-link mess.
The FAA's reasoning about inducements and expectations around using UAT for GA aircraft never made sense to me. Newer aircraft have Mode-S transponders that can be upgraded to 1090ES Out, older aircraft with transponders may be due a transponder upgrade anyhow. So maybe that leaves some in the middle, but that just never seemed like a reason to prioritize "we must keep Mode C" like AOPA pushed for. And the FAA tried to make UAT more widely used by initially allowing use up to FL 240, but that just seemed long-term crazy for things like direct link compatibility with all the big guys flying around in Class A. Once it was clear you were going to needed 1090ES in Class A airspace, then the high-performance singles/light turboprops etc. were all going to go that way, and those owners were more likely to be ADS-B early adopters in the GA space. And once you have some of those folks with 1090ES Out, more of the GA community will follow, both becasue they have GA oriented product available and for direct compatibility with 1090ES Out used by those early adopters.
What the GA lobby should have been pushing for IMNSHO was a usable 1090ES-Only system that would support a usable GA-oriented traffic awareness system.. Or at a minimum some more extensive academic research to validate the claims for need of a dual-link system. End-of-life of Mode-C could have been done over a decade+ time frame. Relying on ground infrastructure to provide ADS-R link-layer translation makes the current ADS-B system a mess for GA traffic awareness. There are too many places of interest to GA where there is not ADS-R coverage, including close to many GA airports and gliderport traffic patterns. And the system is just too complex, still many pilot's don't see to understand they need ADS-B Out to receive ADS-R or TIS-B traffic service.
ADS-B is one of those things that is trying to serve many masters, and as well described in the earlier post, it's really a aircraft surveillance system for the FAA Nextgen project, everything else is really a secondary add-on to try to make it more appealing to other constituents. Hoping I expect from the FAA's view point that those other constituents will then support the adoption of ADS-B, but the only real significant reason the FAA want it is for NextGen surveillance. The poor FAA is stretched thin between powerful constituents and masters, that is largely the US Congress, Airlines, and the occasional whack of a stick from the NTSB. GA gets a small mention every now and again, but the lobbying from various owner/pilot organizations for things related to ADS-B seems to have been pretty confused and/or ineffective. And some of the folks lobbying for those organizations I've spoken to clearly did not understand the technology at a useful level. And its arguable that the FAA was in a tough situation, with NextGen very underfunded, but either way, that is certainly what is really driving ADS-B.
Meanwhile Europe looked at the 1090MHz/1030MHz congestion issue, they have airspace like over Paris where this was a concern (but yes still less ongestion than some US locations). Europe went Mode-S only, which largely solved the TCAS bandwidth problem as TCAS can do selective interrogation of one transponder at a time. And TCAS-II can also save bandwidth by reducing interrogation of a target aircraft if it can be tracked via 1090ES.... but it still hammers away at it with transponder interrogations if it thinks it is a real threat... (oh the irony that that 1090/1030MHz bandwidth saving trick does not work against a target with Mode C/UAT-Out). And their are other options for future like tweaking TCAS power levels to trade off range/congestion. I certainly don't think it is absolutely clear that the FAA *had* to go dual-link with ADS-B becasue of bandwidth.
Heck, if lots of folks don't go Mode-S/1090ES out and stick instead with Mode-C and TCAS use increases it might even be possible that at some point in the future the FAA has to come back and end of life Mode C anyhow. But maybe that possibility is so long off that natural aircraft and Mode C transponder attrition/replacement will prevent that happening.
Head hurting yet? Go crack a beer and dream about your next glider flight.....
  #42
Old April 8th 15, 03:05 AM posted to rec.aviation.soaring
Mike Schumann[_2_]
Andy
What the GA lobby should have been pushing for IMNSHO was a usable 1090ES-Only system that would support a usable GA-oriented traffic awareness system. Or at a minimum some more extensive academic research to validate the claims for need of a dual-link system. End-of-life of Mode-C could have been done over a decade+ time frame. Relying on ground infrastructure to provide ADS-R link-layer translation makes the current ADS-B system a mess for GA traffic awareness. There are too many places of interest to GA where there is not ADS-R coverage, including close to many GA airports and gliderport traffic patterns. And the system is just too complex, still many pilot's don't see to understand they need ADS-B Out to receive ADS-R or TIS-B traffic service.
A little bit of history is important to understand how we got into this mess. ADS-B was originally developed by MITRE to improve situational awareness for General Aviation and to provide an economical alternative to traditional radar coverage in remote areas, like Alaska.
MITRE made the decision to start with a clean sheet design to address two basic issues: 1. To come up with a low power low cost hardware platform, and 2. To provide the bandwidth to support a wide variety of services as the system evolved.
This resulted in the UAT design, which was extensively tested in Alaska as part of the multi-year Capstone project. The FAA paid for equipping about 100 aircraft with ADS-B IN and OUT hardware and moving map displays. The initial product roll-out included Weather and TIS-B. During the test period, there was a dramatic drop in the frequency of fatal GA accidents in the test area, which got the attention of the FAA bureaucrats.
Instead of rolling out this low cost technology as a way to improve situational awareness for the GA fleet, someone came up with the bright idea that this would be a great way to provide high resolution position reporting for IFR aircraft, which would permit the dismantling of a very expensive conventional radar system, while simultaneously providing the accuracy necessary to support simultaneous parallel approaches at major airports in minimal visibility conditions.
That's when the whole program got perverted. The FAA insisted that all ADS-B OUT systems need to have GPS position sources that were FAA certified and provided integrity signals that are not part of any commercial GPS chip sets. As a result, instead of having a $10 GPS receiver, ADS-B OUT systems were required to incorporate $1,500 certified position sources.
The FAA's idiocy is clearly demonstrated by their unwillingness to relax the specs for VFR aircraft who have no desire to enter Class B airspace. The rules for gliders are even more bizarre. Under the rules, we don't need anything to makes us visible (transponders or ADS-B OUT). However, if we voluntarily equip with ADS-B we have to meet the gold plated IFR specs. The bottom line, is that the FAA would rather have a glider flying around invisible, than permit the installation of a low cost non-certified piece of hardware that might not meet their big iron standards.
  #43
Old April 8th 15, 08:55 PM posted to rec.aviation.soaring
Darryl Ramm
Andy
Mitre was involved with lots of ADS-B work but they did not "invent ADS-B".
Maybe you meant UAT. Which they did more drive. And ADS-B was not primarily
developed as a GA collision avoidance technology--maybe some engineers felt
it was but the FAA was paying for this development and back in the early
1990s they were clearly already pushing it primarily as a future
surveillance technology. And that is how the FAA sold it to Congress and it
got funded.
ADS-B is a broad industry wide technology development with by far the
largest interest in it being for ATC surveillance.
You and Bernald Smith seem to be the US Soaring sales reps for Mitre and
their UAT technology. All that has resulted from all the talk over many
years is... exactly nothing. Not one single useful thing. Except time
wasted, potential users confused and in some cases a decrease in safety as
some people put off adopting other technology.
The Capstone project heavily involved ATC ADS-B based surveillance in an
area that had no SSR coverage, it was funded and managed by the FAA as a
*surveillance project*. the FAA attributed the increase in safety due to
improved *surveillance* and used that to justify ADS-B and NextGen funding.
Good luck finding much mention of cockpit traffic systems buried well below
the FAAs focus on Capstone surveillance. e.g.
http://www.faa.gov/news/fact_sheets/....cfm?newsIdy57
UAT was a mistake that should have been shot through the head by the FAA.
And the glaring problems of lack of TCAS compatibility should have made it
a non-starter for any use in gliders. Instead the US Soaring community has
had years of folks hyping this crap, and making people think there is
likely to be some new UAT box around the corner. And in some locations that
may have had an impact on safety by discouraging glider owners to install
transponders. We had some pilots who put off installing transponders in the
Reno area thinking UAT technology was coming and would be very low-cost.
Now maybe they were never actually going to install anything and UAT
futureware was just a convenient excuse. Luckily many more pilots in that
area behaved more responsibly.
Your constant labeling of UAT as "crap" is pretty insulting to a lot of
very bright people in MITRE and to our fellow glider pilot Bernald Smith,
who had the vision to try to introduce a state of the art technology to
replace the antiquated World War II vintage architecture that provides
the basis for current Mode C and Mode S transponders.
It is unfortunate that these folks couldn't get the FAA to see the long
term advantages of this approach and provide a clear migration plan to
incorporate ADS-B into the TCAS architecture, so that conventional
transponders could eventually be retired. Because the FAA couldn't get
their act together on a long term migration plan, we are now stuck with
an overly complicated dual frequency system which will still require
aircraft to be transponder equipped into the indefinite future.
Your assertion that the development of UAT has resulted in "not one
single useful thing" is complete BS. There are thousands of pilots who
are currently buying low cost UAT based ADS-B receivers. While the
traffic data provided by these receivers is only useful if the A/C is
ADS-B OUT equipped, these units provide free weather and notam data. I
would be willing to wager that Sporty's has sold at least 10x as many
Stratus ADS-B receivers over the last couple of years than the number of
POWERFLARM systems sold in the US.
The frustrations that you espouse have their roots, not in misinformation
that I and others are providing to the pilot community, but rather the
result of people recognizing POWERFLARM's limitations on displaying
non-glider traffic. There are a lot of people who don't want to waste
their money on a product that has a half baked ADS-B IN implementation
that is not going to be able to identify ADS-B UAT equipped aircraft.
If the POWERFLARM folks want to stay in the game, they need to
incorporate a dual frequency ADS-B receiver and/or support TIS-B. If
that happens, people like me will shut up, and maybe even buy the product.
What I said was all the Mitre salesmanship and pro UAT-hype from folks like
Bernald and you have not resulted in anything at all of use/benefit to the
soaring community. Is that clear enough? And yes I know, the reasons why
that is will be entirely somebody else's fault...
And I am certainly not pushing FLARM, for the apparently serious glider-GA
traffic midair collision risks like you have described with the Minnesota
Soaring Club operating under a Mode C veil it might be that transponder
carriage would be more useful, maybe in collaboration with FAA ATC
procedures/awareness. Maybe PCAS and 1090 ES in in PowerFLARM would help. I
would hope that if safety issues there are as serious as you make out that
pragmatic people would have long since been looking at what is actually
usable/doable to minimize mid-air collision risks, wether that is
awareness, training, procedures, reaching out to the FAA or GA community,
use of practical technology etc. So what has the club done?
All I think we ever hear about is you raising concerns, over many years
about the mid-air collision risk there, and how there is apparently nothing
technically available that would be a practical help with these safety
concerns--although lots of other owners, clubs etc. seem to somehow find
that Zaon and other PCAS, PowerFLARM and/or transponders were very
effective practical aids for their environments. Hopefully the Minnesota
Soaring Club has not just spent years waiting and hoping for some mythical
low cost UAT based solution and/or used that as an excuse not to adopt
*any* technology to help with as you describe it a serious glider-GA
mid-air collision risk.
  #44
Old April 8th 15, 10:52 PM posted to rec.aviation.soaring
Mike Schumann[_2_]
  #45
Old April 8th 15, 11:39 PM posted to rec.aviation.soaring
Darryl, there was a lot of interesting discussion going on in ancient times (you know, before PowerFlarm, 8 or 9 years ago). As I remember it, Bernald was pushing UAT back then because there was a lot of concern about the possibility of glider vs. airliner collisions, and at the time, UAT seemed like it was going to be a good way of getting gliders, ultralights, balloons, etc., integrated into the air traffic system at low cost and with minimal power consumption. The icing on the cake was the Mitre UAT ADS-B out prototypes, that were basically built using $100 or so worth of cellphone chipsets and COTS GPS modules, and could run all day on a few AA cells. I know Mike was involved in the successful testing of these units in gliders and powered aircraft in the Virginia area (if I remember correctly). This was a promising technology with a lot of support even from groups within the FAA, with the end goal being pervasive use of UAT-based ADS-B technology in UAVs, general aviation, and gliders. The general understanding at the time was that these units would eliminate the need for transponders for general aviation. But, one should never underestimate the capability of the FAA to create a steaming pile out of a nice clean solution.
I also remember that it was Bernald who introduced Urs to various parties in the US soaring community (myself included), with the explicit intent of bring Flarm into this country. In particular I was present at a number of informal discussions that took place around the '08 SSA convention that were set up by Bernald, which (again, if I remember correctly) led to the notion of PowerFlarm, the Flarm loaner/rental program, and other such things. It's funny how you've now decided that he is nothing more than a misguided salesman.
Marc
  #46
Old April 9th 15, 01:05 AM posted to rec.aviation.soaring
Andrzej Kobus
Here is a good one. I bet sooner or later FAA will give up and allow the lower cost units.
http://www.flyingmag.com/avionics-ge...-its-true-sort
My next glider coming out of factory will have Trig T22 with FreeFlight 1201 installed (experimental) as well as ADSB-in (both bands).
I have PowerFlarm in my current glider and I am not certain I want one again due to huge number of nuisance alarms coming from my own Trig T22 transponder. I might give it a try again, but ... if it behaves the same way as the current unit it will be out of my glider faster than it came in. I did contact support without any resolution. In fact I had my PowerFlarm unit in two gliders both equipped with Mod S transponders and I had tons of nuisance alarms in both gliders. Transponder output was tested and PowerFlram antennas were mounted properly.
I also hear from folks in Europe about ADS-B out and PowerFlarm installed in the same aircraft not working properly.
I admit at some point in the past I wanted PowerFlarm to be mandatory for contests. I am not sure about that anymore.
Yes, in contest environment I benefited from PowerFlarm, but I also acknowledge there were many false positives in thermals that caused me to interrupt my scanning procedure to check on potentially conflicting traffic.
I remember busy thermals when the thing would not shut up at all. I have been using PowerFlarm since it showed up in the US.
Sometimes a simple thing like a strobe light on a glider can be very effective in making a glider visible.
At the end it is only important to know there are people around me before they get to close after that is your head on you neck that matters. If everyone had a UAT for $699 it would work for us too. I just need to know there is someone coming. Then add a transponder for the heavy machines and you are all set.
I really don't care for PowerFlarm algorithm speed as speed only matters when the traffic is very close. At that point I should have it already visible. You don't want to react when you have a second. You want to know the traffic is coming and react much earlier. You should never need the fast reaction time.
I don't think ADS-B vs. PowerFlarm is such a clear cut. I bet sales of Flarm units in Europe will fall as a result of easy ADS-B out and $200 ADS-B in hardware available.
  #47
Old April 9th 15, 01:11 AM posted to rec.aviation.soaring
Darryl Ramm
Marc
Marc
And pushing UAT-Out futures for use in areas where airliners were a concern, like the Reno area, seemed to ignore the issue of lack of TCAS compatibility. And promised folks the hope of low-cost and easy to install UAT-Out devices when many should have been considering installing transpodners. it always just scared the hell out of me, to see this promoted as a goal at all, especially for areas like the Reno area, where TCAS II equipped traffic is such an issue.
I sat through at least one PASCO seminar from Bernald and another given by you where some folks who attended took away that they won't be installing transponders but waiting for these UAT devices. I certainly remember one-post UAT presentation discussion with glider owners from the Reno area who were absolutely in love with this soon to be coming $500 portable box and totally opposed to istalling a $3,000 "power hungry" transponder. Many folks clearly took away far more than they shoudl have about the actual state of play of any of this stuff, and few if any really understood the limitations. Bernald has done may great things for he soaring community and soaring saftey, ultra impressive, but all that effort pushing UAT technology was just a bad idea. And you also have done a huge amount for soaring and soaring saftey, include your work in the Reno area, all fantastic stuff.
And I think it was probalby you, indirectly through Benrald, that introduced me to Urs. Maybe after a seminar I had given on transponders, ADS-B and FLARM, ... partially with the goal of discouraging folks trying to import and use overseas-FLARM units, which was a bit of an underground idea going around at the time (including a few physical units kicking around). I've been happy to help the Flarm guys on some stuff when asked, but have done far far less there than many others in the USA who wanted to see this technology available for the Soaring Community.
After that UAT promotion that was happening in the PASCO seminars I started giving presentations about glider batteries etc. if folks were worried about battery issues with transponders I certainly wanted them to know enough to have a cogent discussion. And I started to speak up in PASCO seminars etc. about the TCAS compatibility issue, I don't recall that was ever mentioned before, I could be wrong on that, but I never heard it raised. UAT-Out only adoption in the Reno area would gave been a very bad move, getting anything to happen with high tech/aviation/avionics is damn hard, but starting off trying to get something to happen that if it did succeed would be bad, is not a good idea.
The final straw for me with all the UAT hype came the day I was flying out of Minden and the Hawker 800 collided with an ASG-29. I was at the other end of the Pinenut ranges when that happened. And one bizarre response to that was some folks talking up yet again the hope/need to UAT-Out devices. Jesus, TCAS-II equipped business jet, colliding with a glider with it's transponder turned off... what could people *not* get about that? Luckily most folks took that as a need to keep focusing on transponder use in that area.
I doubt the establishment of PowerFLARM rental programs in the USA had any practical help from Bernald, what made that happen was Williams Soaring and generous donors actually stepping up and making that happen.
I don't care if anybody use any particular traffic-awareness technology, but I hope that people at least evaluate what might help them. I'd hate for example to see say the glider exemption for transponders or ADS-B Out to be lost in future, that would be just a horrible waste for many gliders in many locations. In other locations where there are traffic concerns I hope owners/pilots/clubs/FBOs are looking at all the things that it is possible to do to reduce mid-air collision risks. And I care when others keep presenting misinformation/spurious arguments about might prevent some folks adopting what technology aids are practically available today.
  #48
Old April 9th 15, 02:17 AM posted to rec.aviation.soaring
Andrew[_13_]
At 02:01 26 March 2015, Darryl Ramm wrote:
Maybe next time try searching r.a.s. before asking a question. You
would
have found this has been covered in depth here recently...
is there a way to search r.a.s for keywords?
  #49
Old April 9th 15, 02:27 AM posted to rec.aviation.soaring
Bob Pasker
On Monday, April 6, 2015 at 7:19:19 PM UTC-4, kirk.stant wrote:
Now, what we figured happened is: 1. Our transponder was stuck putting out a bad altitude (2400ft) instead of the actual pressure alt (about 9400ft)
did the transponder in that plane display pressure altitude, like my KTX-76? if so, did it show the wrong altitude? the right altitude? and when you realized what happened, did you call approach or center and ask for an altimeter readout?
http://www.bendixking.com/Products/N...ponders/KT-76C
  #50
Old April 9th 15, 03:18 AM posted to rec.aviation.soaring
Darryl Ramm
would
Remember that r.a.s is a USENET forum which means a distributed network of servers carrying all this stuff, and what you can or can't do with messages is largely dependent on the client you are using to access that USENET newsgroup. It looks like are posting from the Glider Pilot Network, I'm not sure what is provided there. Maybe others can help you.
Most USENET NNTP clients (like Mozilla Thunderbird) provide good local search capabilities, which means you can search on just about anything in the messages that are downloaded to your client. It can also search on things based on header fields on the server. And you can also do some pretty complex filtering based on fields, which may be useful for finding posts.
Google Groups also provides good Web based search. Go to the "Search for topics" field and pull down the small down-arrow. There is more search capabilities hidden there... make sure you scroll all the way down in the search window that appears, you can search for keywords in the whole article using the "Has the words" field, that is not just searching the Subject field as the UI might seem to suggest.
Really advanced search is available to folks who have direct access to a USENET server. and want to custom write code :-) But that type of search is rarely needed.
Sailplanes currently in production?? [email protected] Soaring 0 November 10th 11 02:02 AM
LS-1 sailplanes in the USA Burt Compton - Marfa Soaring 2 November 2nd 10 01:08 AM
Please ID 3 sailplanes Every time Soaring 4 August 20th 08 10:34 PM
Cheap sailplanes tango4 Soaring 100 December 21st 04 09:21 PM
50+:1 15m sailplanes Paul T Soaring 92 January 19th 04 02:59 AM
