Alternative magnetic compass
Old October 28th 15, 02:32 PM posted to rec.aviation.soaring
Default Alternative magnetic compass
A sailplane's Flight Manual usually requires a magnetic compass (or an aviation compass)as minimum equipment. Well, panel space has become less available and you are seeing fewer sailplanes with panel or glare-shield mounted 2.25 Airpath C2xxx or PAI-700 aircraft specific compasses.
Anyone have a "point" to an off panel compass that might meet FAA scrunity? Unfortunately the Cook compass manufactured by COBB-SLATER Instruments Co. Ltd is no longer available. http://compassmuseum.com/aero/aero.htm#COOK
Probably, a magnetic compass is the last instrument used by a competition pilot. Most competition sailplanes have 3 or more separate GPS engines and it is very simple to have them on independent battery sources. What would be the "penalty" if your sailplane failed a FAA "courtesy" ramp inspection because it lacked a magnetic compass?
Does a F-35 Lighting II joint strike fighter has a magnetic compass?
Need help! Magnetic Compass Errors! kha0z Piloting 14 January 3rd 09 03:20 AM
Why are headings still magnetic? Mxsmanic Piloting 87 September 11th 06 05:34 PM
compass turns with high mounted compass (Cessna 152) Ray Instrument Flight Rules 22 April 7th 05 07:39 AM
Aircraft Magnetic Compass Quilljar Simulators 5 July 11th 04 03:08 PM
Do you use your magnetic compass? Roger Long Piloting 42 May 25th 04 12:08 PM
