Is FLARM helpful?
Old November 26th 15, 10:36 PM posted to rec.aviation.soaring
James Metcalfe
Default Is FLARM helpful?
At 21:29 25 November 2015, jfitch wrote:
I am curious about your experience with the interface. Did you just have
the BF display, or was the Flarm also displaying targets on a moving
map?
I have not had any Flarm warnings that would have saved a midair (3
years
with it now). But I have always had Flarm targets displayed on the glide
computer moving map, and so nearly always see them long before they
could be
considered a threat. Two times in those three years I have gotten an
unexpected warning, though not close enough to require action to avoid
collision.
I use those events as a learning experience to see how I need to change
my
scans and operations, so that they do not happen again.
From this I conclude that the situational awareness, far away from an
potential conflict, is more valuable for preventing potential conflicts in
first place than the actual warning facility.=20
Countless times that Flarm has identified and displayed glider within a
km
of me that I had not seen and might never have seen.
I have used only the 'butterfly' display. To be clear, of course I am
seeing target alerts all the time. That is not a problem, and even
occasionally interesting (such as when someone starts following).
The problem is with false collision warnings. Many pilots appear to (and
some of my pupils certainly do) find it almost impossible to resist turning
away from the Flarm direction of the 'threat', before they have seen the
target. That is dangerous, as I wrote in a post yesterday. And note that
the Flarm direction is often significantly different from the true
direction
(occasionally diametrically opposite), as it is track-based, not heading-
based.
I can see that my experience of Flarm in a very busy environment (the
French Alps) will be very different from that of those flying largely in
isolation (such as flatlands, particularly with what I would regard as high
cloudbases (I'm a Brit!))
J.
  #42
Old November 26th 15, 11:14 PM posted to rec.aviation.soaring
Tim Taylor
UH,
I should have been clearer, these were contests I was personally flying in.
We had three years in a row at contests where I was flying. Uvalde, Parowan, and then Uvalde again. I was beginning to wonder if this was becoming the norm or I was just really bad luck and should stop going to contests.
I flew at Mifflin in 2012, which was the first US nationals where PowerFlarm was available for many contestants. We were installing them during the rain days as you remember. Every contest after that has seen an increase in the number of pilots with PowerFlarm and I have not had to personally listen to the radio calls of the aftermath of a midair. After the last one at Uvalde I never want to hear it again.
I hope that PowerFlarm is mandatory at all Nationals in the future.
Tim (TT)
  #43
Old November 27th 15, 12:43 AM posted to rec.aviation.soaring
Steve Koerner
On Thursday, November 26, 2015 at 4:14:08 PM UTC-7, Tim Taylor wrote:
UH,
I was at all three of those contests that Tim mentions. Listening to the radio traffic was nothing compared to listening to the wail of the wife being informed at Uvalde. I went home straight away on the determination that I would never fly another contest day.
The adoption of PowerFlarm allowed me to change that determination.
Someone here just said that they're tired of listening to people oversell PowerFlarm. I say that's not possible.
I find myself quite irritated when there are still typically one or two folks that will show up at a given contest without a PowerFlarm and that they are permitted to fly.
  #44
Old November 27th 15, 03:22 AM posted to rec.aviation.soaring
jfitch
map?
years
could be
collision.
my
km
direction
based.
J.
James, if you are plagued by false alarms coming even from the wrong heading, I am all the more curious. I have not had any false alarms, perhaps some false negatives (probably should had been an alarm). Never from the wrong direction. Do you have the IGC files from a flight in which you remember that happening? It would be interesting to put it into SeeYou or other software (or even look at it in a text editor) to see what the accuracy of fix was. I have noticed that the Flarm GPS is typically reporting a larger error, and in some cases quite large. I'm not sure what the algorithms do with the precision of fix, but it seems like that is the most likely source of the errors you describe. For example the Flarm IGC file from my glider will show a typical precision of fix of around 3 - 4 meters, but sometimes it will go up to 30-40 for unknown reasons. The Air Avionics gps will show a precision of 1 - 2 meters on the same flight and might also go up in the same areas but not as much. Ridge flying in the Alps you might have the antenna shaded on one or more sides, which will increase the HDOP. The precision is the normally the last three digits of the B record in the IGC file. All of my flying is high altitude and with a clear view of the sky.
  #45
Old November 27th 15, 06:34 AM posted to rec.aviation.soaring
Jonathan St. Cloud
I thought there were two posts worth repeating below and hope everyone takes an honest look. Steve's post was poignant. I did hear the contest committee will require Flarm in stealth mode at contests, if you have one.
Shouldn't preserving life be our highest goal, even more important than winning a contest or being annoyed by the theoretical possibility of someone leaching for a few thermals?
For the price of a parachute you can save two lives.
Richard from craggyaero wrote:
I have also observed this situation many times in the Nephi OLC camps and contests. High closure rates and Configuring your PowerFlarm in the Stealth mode would make this situation a safety concern. It would limit the time to respond to a conflict situation. With the Stealth mode off these situation are visible for many miles and evasive action is easy.
Stealth mode on this situation is much more immediate and dangerous with little time to identify, find and respond to the threat.
  #46
Old November 27th 15, 08:40 AM posted to rec.aviation.soaring
Re "alarms coming from the wrong direction". Flarm uses true tracks not headings. On ridges with a high crosswind component and low airspeed an alert being indicated as being straight ahead may be from 30 degrees or more offset with respect to one's own glider heading. This was highlighted in 2007 in our Scottish Gliding Centre trial and should be understood and allowed for by users. There is no practical technical way to avoid that - not until we all have electronic compasses out on our wingtips anyway.
  #47
Old November 27th 15, 12:31 PM posted to rec.aviation.soaring
David Salmon[_3_]
What James may be referring to is the fact that Flarm indications are in
relation to your ground track not heading. The extreme example is if
flying in very strong winds, say in wave, and actually going backwards.
Another glider coming from your 6 o'clock will actually show as head on.
This effect is still there in any cross wind.
This is a fundamental flaw in Flarm, which surely could be much improved by
building in a wind algorithm to correct the indication nearer to heading.
All navigation programs have them.
Dave
have
moving=20
map?
I have not had any Flarm warnings that would have saved a midair (3=20
years
glide
computer moving map, and so nearly always see them long before they=20
could be
avoid=
=20
collision.
change=
=20
my
conflicts
in
=20
first place than the actual warning facility.=3D20
a=
=20
km
=20
am=20
seeing target alerts all the time. That is not a problem, and even=20
(and=
=20
turni=
ng
=20
the=
=20
that=
=20
direction=20
heading-
based.
=20
(the=20
in=
=20
hi=
gh
=20
J.
headin=
some=
wrong
th=
softw=
w=
error=
t=
th=
s=
wil=
prec=
a=
s=
is
of
  #48
Old November 27th 15, 01:30 PM posted to rec.aviation.soaring
"This is a fundamental flaw in Flarm, which surely could be much improved by
All navigation programs have them."
As another poster mentioned, you really need a heading input to achieve this. Whilst PNA's use drift while circling amongst other methods to determine the wind, they require frequent & sustained 'circles' to achieve this - not so good for wave & ridge. LX quote 3 circles from memory and all the operating notes warn of the associated unreliability. An attempt to use an algorithm to achieve this in Flarm would result in large variations in accuracy. Sometimes the relative bearings provided would be correct and sometimes, they wouldn't. Though currently an imperfect system, at least it's consistent.
CJ
  #49
Old November 27th 15, 03:37 PM posted to rec.aviation.soaring
David Salmon[_3_]
Dave
have
moving=20
map?
years
glide
could be
avoid=
=20
collision.
change=
=20
my
conflicts
in
=20
a=
=20
km
=20
am=20
(and=
=20
turni=
ng
=20
the=
=20
that=
=20
direction=20
heading-
based.
=20
(the=20
in=
=20
hi=
gh
=20
J.
headin=
some=
wrong
th=
softw=
w=
error=
t=
th=
s=
wil=
prec=
a=
s=
is
of
  #50
Old November 27th 15, 03:38 PM posted to rec.aviation.soaring
David Salmon[_3_]
Dave
have
moving=20
map?
years
glide
could be
avoid=
=20
collision.
change=
=20
my
conflicts
in
=20
a=
=20
km
=20
am=20
(and=
=20
turni=
ng
=20
the=
=20
that=
=20
direction=20
heading-
based.
=20
(the=20
in=
=20
hi=
gh
=20
J.
headin=
some=
wrong
th=
softw=
w=
error=
t=
th=
s=
wil=
prec=
a=
s=
is
of
FAA Actually being helpful! Steve Leonard[_2_] Soaring 3 September 15th 12 02:57 PM
Helpful controller Ridge Piloting 3 July 12th 07 11:57 PM
Ode to the Helpful Homebuilder [email protected] Home Built 13 November 10th 06 08:37 AM
Helpful Aviation DVD's Kobra Piloting 0 October 27th 05 02:10 AM
Which rating would be more helpful? Jeffrey LLoyd Piloting 2 July 17th 03 07:02 PM
