#41
#42
Kirk Stant wrote:
They do look nicely retro, though. And the Fouga Magister proves that the V tail can work beautifully in a relatively high performance fully aerobatic jet trainer. And I'm told the Salto does quite well as a Vee tailed aerobatic glider. -- ----- Replace "SPAM" with "charter" to email me directly Eric Greenwell Washington State USA |
#44
#45
Thanks Wallace ! I love my RHJ-8, though its flaps aren't quite as
effective as the HP-14 I once owned. Note that the HP's (later ones anyway) are *much* easier to land than some other flapped ships, as the flaps can produce much more drag. The 1-35 (especially the models with less flap) requires much more precise speed control to avoid floating across the aerodrome. Required speed precision varies quite a lot between sailplanes (different models of 1-35, PIK, HPs with different flap/aileron lengths, Monerai, C-70), so be careful of generalizing too much ! Also, forked-tailed-devils vary a lot (and many HPs have been modified - tail lengths and angles), so again don't generalize too much... Best Regards, Dave "YO" "Wallace Berry" wrote in message ... Hi all, I'm here to report that I cheated death and survived a flight in a glider with the dreaded "Landing Flaps and V-Tails of Death". Jim Harper graciously allowed me to fly his beautiful HP-16. What's an HP-16 you say? Well, looks to be just like the HP-18 (or I should say the HP-18 is just like the -16) except that the -16 has a large and comfortable all metal cockpit instead of the narrow composite cockpit of the -18. Jim's -16 is equipped with winglets and, as far as I know, the ailerons are standard (not with the J.D. Colling mod, correct me if I'm wrong Jim). Center stick. Tow was behind our 180hp Cessna 175 on a 275 foot long rope. Started out in -2 flap position, went to + 5 at 40 knots. Had no trouble keeping the wings level. The bird lifted off level and was easy to fly on tow. Released and tried slow flight (no stalls), flight up to 90 knots. Steep turns, etc. Well sealed and quiet. Good rudder response and easy to coordinate compared to my 301 Libelle. More stable in a thermal than my Libelle. Aileron response was a little slower than my Libelle at thermaling speeds, but was positive and more than adequate for centering thermals. Climbed a few hundred feet in a very week thermal. Very nice thermalling glider. Landing was the best part. I stayed high and close in the pattern. I rolled on some flap on downwind, maybe 30 degrees or so. I was way high on final so I started rolling in more flaps. I never quite got to the full 90 degrees mark as I had the nose down at a truly obscene angle just to maintain 50 knots. Steeper than my 301 with the tailchute and full divebrakes. Steeper than a Mosquito with everything hanging out. This was more like parachuting than flying. Nothing but dirt out the front of the canopy. The horizon was visible more towards the top of the canopy. I aimed at a target and just kept the nose pointed there. I pulled back on the stick when I ran out of nerve. The bird settled on with a slight bump of the tailwheel and a little bounce as the main dropped on (I flared just a bit too much). I have no doubt that I could easily put this bird in a tiny field much easier than I could my Libelle (and that is not difficult at all). So, I'd have to say that all the bad things I've been told about landing flaps on gliders and V-tails are definitely untrue with respect to the HP-16. It is a comfortable and easy to fly glider and compares very well to my Libelle and also to other glass birds, including my favorites for handling, the Mosquito and LS-4. |
#46
Robert Ehrlich wrote
This will work on approach, when you have the nose down attitude corresponding to the flaps setting but not in the situation of my initial question, i.e. just after a botched flare, a few feet above the runnway and no nose down attitude. In this case retracting the flaps will cause a loss of drag, but no so huge, i.e. the drag will much more than in zero flaps or zero spoilers configuration I do not concur. Imagine, for example, a similar situation involving a glider with approach flaps and spoilers, such as the Blanik L-13. It is normally landed with full flaps, and spoilers are used for glideslope control. It is also a common primary trainer, so the situation you cite comes up with some regularity. The solution is to retract the spoilers - but you still have flaps hanging out. How is this any different from retracting Schreder-type flaps to 30 degrees? and there is no gain in lift and no change in the stall speed, you don't have the altitude that you can convert into speed, so I think that you are going to fall on the ground, with a slighly increased delay compared to what would happen if you didn't retract some flaps. Actually, you will fly onto the ground, and if you're not careful you will float. With the flaps retracted to 30 degrees, the HP-11 certainly had a tendency to float even when brought in at very low airspeed. In fact, after some experimentation I came to the conclusion that if my flap mechanicsm were to ever fail with the flaps at less than 30 degrees, I would need about 2 miles of runway to stop. Michael |
#47
Michael wrote:
Robert Ehrlich wrote This will work on approach, when you have the nose down attitude corresponding to the flaps setting but not in the situation of my initial question, i.e. just after a botched flare, a few feet above the runnway and no nose down attitude. In this case retracting the flaps will cause a loss of drag, but no so huge, i.e. the drag will much more than in zero flaps or zero spoilers configuration I do not concur. Imagine, for example, a similar situation involving a glider with approach flaps and spoilers, such as the Blanik L-13. It is normally landed with full flaps, and spoilers are used for glideslope control. It is also a common primary trainer, so the situation you cite comes up with some regularity. The solution is to retract the spoilers - but you still have flaps hanging out. How is this any different from retracting Schreder-type flaps to 30 degrees? and there is no gain in lift and no change in the stall speed, you don't have the altitude that you can convert into speed, so I think that you are going to fall on the ground, with a slighly increased delay compared to what would happen if you didn't retract some flaps. Actually, you will fly onto the ground, and if you're not careful you will float. With the flaps retracted to 30 degrees, the HP-11 certainly had a tendency to float even when brought in at very low airspeed. In fact, after some experimentation I came to the conclusion that if my flap mechanicsm were to ever fail with the flaps at less than 30 degrees, I would need about 2 miles of runway to stop. OK, I have no experience on this kind of ship, I was just trying to figure how to handle this situation. What you are saying is that in the range 30-90 degrees on this ship, flaps work like spoilers on usual (from my point of view) gliders, i.e. retracting them to 30 degrees brings the drag at a level similar to that of a non-flapped ship with spoilers closed, without change in lift. So the important thing in order to be able to recover from the 3 most common mistakes is to have the flaps at more than 30 degrees when you begin the flare. |
#48
![]() Someone mentioned that landing with T or V tail is better than conventional tail in tall crop. I'd like to know of someone who has landed in crop with a conventional tail. Any stories out there? It strikes me that the yaw of crop hitting a wing is the real problem. A conventional tail, if it grabs the crop BEFORE the wing does, might actually keep the glider straighter, kind of a keel effect? Maybe in 2-3 foot crop this means the conventional tail is damaged but T-tail isn't, but in very tall crop, the conventional tail is damaged and the glider pancakes in straight in vs. yawing and rolling T-tail (since a wing hits first). Any opinions about this? Anyone have anecdotes? I've wondered the same thing about high-wing vs. low-wing water landings in power aircraft... |
#49
#50
Don't know about conventional tails. But I have been helping rebuild a
DG202 (T-tail) that landing in a tall wheat feild. It caught a wing tip and turned sideways breaking nearly every part in the fuselage. (Major Damage) Don't know if a conventional tail would have helped. Brian |
f-84G Flaps question | Frederico Afonso | Military Aviation | 0 | September 8th 04 05:58 PM |
757 flaps miss-aligned in cruise | AnyBody43 | General Aviation | 1 | April 2nd 04 01:01 AM |
Cessna 182S flaps | EDR | Piloting | 7 | January 16th 04 02:37 AM |
Slats and Fowler Flaps On Light Plane | Brock | Home Built | 28 | July 31st 03 10:12 PM |
automatic flaps problem in Beechcraft KAF90 | deeknow | Simulators | 0 | July 24th 03 02:45 AM |
