Jantars are back :)
Old December 12th 03, 03:16 PM
Well, the relationship of flutter to IAS and TAS is certainly a
puzzle to me.
Somewhere I got the understanding that IAS, in a sense, indicates the
impact rate (pressure) of molecules on the aircraft, and thus in
thinner air an aircraft will "actually" (TAS) be flying faster to
receive the same air molecule impact rate (pressure).
TAS, on the other hand, indicates, in a sense, indicates the speed
at which the air molecules are moving past the aircraft - something
quite independent of just how MANY air molecules are passing by
the aircraft in a given amount of time.
Further, I have had the impression that flutter is a consequence of
the speed of the aircraft through the air (molecules) (TAS) rather
than the number of air molecules that happen to be impacting the
aircraft in a given amount of time (IAS).
So, I have always considered it prudent to view VNE due to FLUTTER
to be a TAS airspeed, not an IAS airspeed.
Have I been wrong about this?
  #42
Old December 12th 03, 05:03 PM
F.L. Whiteley
"Jim" wrote in message
puzzle to me.
True AFAIK, and the effectiveness of controls responds to this pressure.
Control flutter limitations are a function of IAS. Some sailplanes have
been designed with and even retrofitted with dampers. Bear in mind that
age, wear, repair, compromised mass balances, and paint can impact this.
(Not mutually exclusive changes)
Yes, and the center of pressure that generates lift shifts as a result and
may twist (maybe better un-twist) the wing. IIRC, the FL500 Grob had an
extra lamination or two of glass in the wings so it could fly faster than
stall speed at extreme altitude. In my DG-100 at speeds 120kts under
3000m, the amount of downward deflection at the tips was really impressive
and a bit unnerving. I don't recall similar deflection at 8500m at similar
TAS, but, like most everyone else, I have little empirical evidence.
Flutter in an elastic mode and is dependent on wing design. As I understand
it, a Lear Jet's Vne is based on IAS with Mach limits. The wings are quite
short and stiff compared to a sailplane, and have greater torsional
resistence by design. The twist in glider wings is there to provide more
benign handling, however, as in the OSTIV paper I've referenced previously,
sailplane design is a compromise of performance and engineering. The
elastic mode may be the limiting factor and engineering a sailplane to
perform at altitude as a Lear Jet would increase both weight and cost
unacceptably (unless your name is Fossett maybe). Since the sailplane
spends 99% of it's service life 6000m and a Lear Jet spends 90% of its
service life 8000m, each is designed appropriately.
Perfectly safe as a conservative view.
The conjecture in the OSTIV paper was that (IAS+TAS)/2 was safe and that
this envelope might extend to 0.8 * TAS. However, there are a couple of
Nimbus 4 incidents that might suggest adoption of the prudent view. There
are also some 15m designs with little twist and stiff wings that might be
real rocket rides. I have a little time in a Jantar Std 2 and found it
nimble, a bit stiff, and honest in performance. I also found that things
like the aileron hinges wear a bit more quickly than some other gliders, so
pressure effects might be of interest. Too many factors and not enough
evidence to say who's right or wrong or taking unacceptable risks. The
third mode of flutter is pilot induced. Control inputs at high altitude and
speed could potentially induce either of the other two modes, I suppose.
Anyway, that's my take,
Frank Whiteley
Colorado
  #43
Old December 12th 03, 05:16 PM
Eric Greenwell
No, it is prudent, but as several have pointed out, it may be
unnecessarily conservative. That's because the flutter usually occurs
somewhere between IAS and TAS, and not strictly by TAS.
Personally, I'd use TAS on "older" (designed/certified 20+ years ago)
gliders, and the glider's handbook for "newer" (designed/certified
within the last 10 or so years, unless I knew specifically what the
older glider was designed and tested to. My reasoning is the older
certifications were not as stringent in this area as they are now.
change "netto" to "net" to email me directly
Eric Greenwell
Washington State
USA
  #44
Old December 12th 03, 05:34 PM
Jack Harkin
It is a TAS, this is the reason it occurs at a lower IAS as the altitude
increases. Without some sort of sophisticated computations it is very
difficult to determine TAS. IAS is easy to see and use.
  #45
Old December 13th 03, 02:52 AM
Webmaster Patagonia Soaring
H. Miranda World Record technique:
1. Fill wings with water
The Jantar that Horacio flight, DIDN'T HAVE WATER!!!!!
They flew using the 1 and 2 wave of cordillera del viento starting at
5000 meters (16666 ft) climb to 6000 m (20000 ft) and finish at 4400
meters (14666 ft). His maximum ground speed was 413 km/h (223 kts). I
have the IGC file for this record. I can e-mail you if you wish. The
jantar VNE is 275 kph (148 kts) at sea level.
Last year I flew with Horacio in the same triangle in a IS-28B2. Our
maximum ground speed was 330 kph (178kts) flying always at 160 kpn (86
kts) IAS, that is a little less that the IAS VNE for this altitude.
The VNE at sea level for the IS is 220 kph (118 kts)
Best regars,
Luis Briones
Interesting. Life history of John Lear (Bill's son) Big John Piloting 7 September 20th 04 05:24 PM
Interesting Resume (V Long) Bob Chilcoat Piloting 24 September 13th 04 06:44 AM
gliding back to your departure airport Harold Piloting 34 October 24th 03 11:12 PM
Student Pilot Stories Wanted Greg Burkhart Piloting 6 September 18th 03 08:57 PM
The Little Wheel in Back Veeduber Home Built 6 September 8th 03 10:29 AM
