#41
Good if that's what makes YOU feel safe !
"Todd Pattist" wrote in message ... "Arnold Pieper" wrote: These reports led you to the wrong conclusion. Overstress is the key here, weahter with or without airbrakes. My load limit is 5 G's brakes closed, 3.5 G's brakes open. If you want to pull the nose up at 5 G's to avoid hitting the ground, you can do it brakes closed, but not brakes open. If your adrenaline kicks in as you pull back, you can pull until you feel 5 G's if you leave the brakes closed, but only to 3.5G's if you open them. Todd Pattist - "WH" Ventus C (Remove DONTSPAMME from address to email reply.) |
#42
Okay - point taken on designs with lots of tip washout
or inbord flaps deployed. But the wing twist discussion was really a secondary point in the dialog about pitch stability overall, and I'm not sure that a twisting at the tip would contribute very much to making the glider unstable overall. I still think it's not reasonable to expect that a glider would be certified where you'd get enough structural twisting to upset the overall stability of the aircraft. More broadly, I doubt that you'll find a certified aircraft that has a pitching moment that becomes more nose down with increasing speed no matter what the reason. The feds are unlikely to smile on a design with static instability at any speed. I remain convinced that if your sailplane exhibits pitch instability you have a c.g. problem, a rigging problem, your aircraft has been modified or you are outside the certified operating limits. At 18:42 02 April 2004, Jj Sinclair wrote: I a bit suspicious of this whole wing twist thing. Take a K-6 up to 100 and look at the tips. Take an ASH-25 up to 80 with landing flaps on and look at the tips. In the case of the K-6, she does have a few degrees of tip wash-out (leading edge down) In the case of the ASH-25 with landing flaps on, Only the inboard flaps go down, the outboard flaps and ailerons go up to produce a negative angle of attack. So why do the wings in both cases bend down? Why does the B-52 use spoilers instead of ailerons? Because at higher airspeeds an aileron input causes the wing to bend and can cause the ship to turn in the opposite direction (wing twist) Even in a *certified* ship, if the wings start to tuck under and you don't catch it right away, you could find yourself in a situation where elevator won't stop the pitch down action. Now, all of this is at or above VNE, so if we are flying our glass slippers within limits, we should be OK. JJ Sinclair |
#43
Well,
Although not directly related to gliders (except really fast ones), look up "mach tuck" and you will find several certified aircraft that tend to nose down as speed increases. Critical mach is a aeronautics term that refers to the speed at which some of the airflow on a wing becomes supersonic. When this occurs the distribution of forces on the wing changes suddenly and dramatically, typically leading to a strong nose-down force on the aircraft. This effect led to a number of accidents in the 1930s and 1940s, when aircraft in a dive would hit critical mach and continue to push over into a steeper and steeper dive. This problem is often lumped in with the catch-all phrase compressibility. Wings generate much of their lift due to the Bernoulli effect; by speeding up the airflow over the top of the wing, the air has less density on top than on the bottom, leading to a net upward force. The relative difference in speed is due largely to the wing's shape, so the difference in speed remains a fairly constant ratio over a wide range of speeds. But if the air speed on the top of the wing is faster than on the bottom, there will be some speed where the air on top reaches the speed of sound. This is the critical mach. When this happens shock waves form on the upper wing at the point where the flow becomes supersonic, typically behind the midline of the chord. Shock waves generate lift of their own, so the lift of the wing suddenly moves rearward, twisting it down. This effect is known as mach tuck. ;0) Allan "Andy Blackburn" wrote in message ... Okay - point taken on designs with lots of tip washout or inbord flaps deployed. But the wing twist discussion was really a secondary point in the dialog about pitch stability overall, and I'm not sure that a twisting at the tip would contribute very much to making the glider unstable overall. I still think it's not reasonable to expect that a glider would be certified where you'd get enough structural twisting to upset the overall stability of the aircraft. More broadly, I doubt that you'll find a certified aircraft that has a pitching moment that becomes more nose down with increasing speed no matter what the reason. The feds are unlikely to smile on a design with static instability at any speed. |
#44
#45
#46
A+ for research initiative, D- for applicability.
Mach tuck affects certain high speed aircraft (high mach numbers, jets only) with swept back wings, when they exceed their Mmo. When flying within their normal certified speed ranges, they do not present this abnormality. As someone already posted, no aircraft would be certified with instability being a part of its normal flight envelope. "ADP" wrote in message ... Well, Although not directly related to gliders (except really fast ones), look up "mach tuck" and you will find several certified aircraft that tend to nose down as speed increases. Critical mach is a aeronautics term that refers to the speed at which some of the airflow on a wing becomes supersonic. When this occurs the distribution of forces on the wing changes suddenly and dramatically, typically leading to a strong nose-down force on the aircraft. This effect led to a number of accidents in the 1930s and 1940s, when aircraft in a dive would hit critical mach and continue to push over into a steeper and steeper dive. This problem is often lumped in with the catch-all phrase compressibility. Wings generate much of their lift due to the Bernoulli effect; by speeding up the airflow over the top of the wing, the air has less density on top than on the bottom, leading to a net upward force. The relative difference in speed is due largely to the wing's shape, so the difference in speed remains a fairly constant ratio over a wide range of speeds. But if the air speed on the top of the wing is faster than on the bottom, there will be some speed where the air on top reaches the speed of sound. This is the critical mach. When this happens shock waves form on the upper wing at the point where the flow becomes supersonic, typically behind the midline of the chord. Shock waves generate lift of their own, so the lift of the wing suddenly moves rearward, twisting it down. This effect is known as mach tuck. ;0) Allan "Andy Blackburn" wrote in message ... Okay - point taken on designs with lots of tip washout or inbord flaps deployed. But the wing twist discussion was really a secondary point in the dialog about pitch stability overall, and I'm not sure that a twisting at the tip would contribute very much to making the glider unstable overall. I still think it's not reasonable to expect that a glider would be certified where you'd get enough structural twisting to upset the overall stability of the aircraft. More broadly, I doubt that you'll find a certified aircraft that has a pitching moment that becomes more nose down with increasing speed no matter what the reason. The feds are unlikely to smile on a design with static instability at any speed. |
#47
Do you include rudder lock as an instability? How about dynamic stability?
What about downsprings, bob weights and other stability enhancement devices? Stability is a really broad subject. In article , "Arnold Pieper" wrote: A+ for research initiative, D- for applicability. Mach tuck affects certain high speed aircraft (high mach numbers, jets only) with swept back wings, when they exceed their Mmo. When flying within their normal certified speed ranges, they do not present this abnormality. As someone already posted, no aircraft would be certified with instability being a part of its normal flight envelope. "ADP" wrote in message ... Well, Although not directly related to gliders (except really fast ones), look up "mach tuck" and you will find several certified aircraft that tend to nose down as speed increases. Critical mach is a aeronautics term that refers to the speed at which some of the airflow on a wing becomes supersonic. When this occurs the distribution of forces on the wing changes suddenly and dramatically, typically leading to a strong nose-down force on the aircraft. This effect led to a number of accidents in the 1930s and 1940s, when aircraft in a dive would hit critical mach and continue to push over into a steeper and steeper dive. This problem is often lumped in with the catch-all phrase compressibility. Wings generate much of their lift due to the Bernoulli effect; by speeding up the airflow over the top of the wing, the air has less density on top than on the bottom, leading to a net upward force. The relative difference in speed is due largely to the wing's shape, so the difference in speed remains a fairly constant ratio over a wide range of speeds. But if the air speed on the top of the wing is faster than on the bottom, there will be some speed where the air on top reaches the speed of sound. This is the critical mach. When this happens shock waves form on the upper wing at the point where the flow becomes supersonic, typically behind the midline of the chord. Shock waves generate lift of their own, so the lift of the wing suddenly moves rearward, twisting it down. This effect is known as mach tuck. ;0) Allan "Andy Blackburn" wrote in message ... Okay - point taken on designs with lots of tip washout or inbord flaps deployed. But the wing twist discussion was really a secondary point in the dialog about pitch stability overall, and I'm not sure that a twisting at the tip would contribute very much to making the glider unstable overall. I still think it's not reasonable to expect that a glider would be certified where you'd get enough structural twisting to upset the overall stability of the aircraft. More broadly, I doubt that you'll find a certified aircraft that has a pitching moment that becomes more nose down with increasing speed no matter what the reason. The feds are unlikely to smile on a design with static instability at any speed. |
#48
Well, Although not directly related to gliders (except really fast ones), look up "mach tuck" and you will find several certified aircraft that tend to nose down as speed increases. Critical mach is a aeronautics term that refers to the speed at which some of the airflow on a wing becomes supersonic. When this occurs the distribution of forces on the wing changes suddenly and dramatically, typically leading to a strong nose-down force on the aircraft. This effect led to a number of accidents in the 1930s and 1940s, when aircraft in a dive would hit critical mach and continue to push over into a steeper and steeper dive. This problem is often lumped in with the catch-all phrase compressibility. Wings generate much of their lift due to the Bernoulli effect; by speeding up the airflow over the top of the wing, the air has less density on top than on the bottom, leading to a net upward force. The relative difference in speed is due largely to the wing's shape, so the difference in speed remains a fairly constant ratio over a wide range of speeds. But if the air speed on the top of the wing is faster than on the bottom, there will be some speed where the air on top reaches the speed of sound. This is the critical mach. When this happens shock waves form on the upper wing at the point where the flow becomes supersonic, typically behind the midline of the chord. Shock waves generate lift of their own, so the lift of the wing suddenly moves rearward, twisting it down. This effect is known as mach tuck. How do you fly inverted using "Bernoulli Effect"? Jan-Olov Newborg |
#49
A for effort, D for accuracy. The DC-8 Could not be flown at altitude with
out it's PTC (Pitch Trim Compensator) being operative. The function of the PTC was to protect against mach tuck. Since the DC-8 was undoubtedly certified, the argument is invalid. Had you read my post you would have noticed the reference to supersonic airflow which presumably does not apply to gliders. On the other hand, a P-38 with a critical mach number of .69 is hardly a jet and has straight wings. Several were lost in early testing because the phenomenon of mach tuck was not well known. In fact, sweepback is a design factor that helps delay critical mach to higher numbers. Not to make too fine a point but any aircraft, if flown fast enough without breaking up, can be subject to mach tuck. Allan "Arnold Pieper" wrote in message m... A+ for research initiative, D- for applicability. Mach tuck affects certain high speed aircraft (high mach numbers, jets only) with swept back wings, when they exceed their Mmo. When flying within their normal certified speed ranges, they do not present this abnormality. As someone already posted, no aircraft would be certified with instability being a part of its normal flight envelope. "ADP" wrote in message ... Well, Although not directly related to gliders (except really fast ones), look up "mach tuck" and you will find several certified aircraft that tend to nose down as speed increases. Critical mach is a aeronautics term that refers to the speed at which some of the airflow on a wing becomes supersonic. When this occurs the distribution of forces on the wing changes suddenly and dramatically, typically leading to a strong nose-down force on the aircraft. This effect led to a number of accidents in the 1930s and 1940s, when aircraft in a dive would hit critical mach and continue to push over into a steeper and steeper dive. This problem is often lumped in with the catch-all phrase compressibility. Wings generate much of their lift due to the Bernoulli effect; by speeding up the airflow over the top of the wing, the air has less density on top than on the bottom, leading to a net upward force. The relative difference in speed is due largely to the wing's shape, so the difference in speed remains a fairly constant ratio over a wide range of speeds. But if the air speed on the top of the wing is faster than on the bottom, there will be some speed where the air on top reaches the speed of sound. This is the critical mach. When this happens shock waves form on the upper wing at the point where the flow becomes supersonic, typically behind the midline of the chord. Shock waves generate lift of their own, so the lift of the wing suddenly moves rearward, twisting it down. This effect is known as mach tuck. ;0) Allan |
#50
It's called angle of attack.
Allan "Jan-Olov Newborg" wrote in message om... "ADP" wrote in message ... Well, How do you fly inverted using "Bernoulli Effect"? Jan-Olov Newborg |
Aircraft Deceleration Devices | SteveM8597 | Military Aviation | 10 | April 13th 04 10:01 AM |
GPS and Night Vision Devices | Steve | Products | 0 | February 12th 04 11:34 AM |
WinPilot-compatible GPS devices | Ted Wagner | Soaring | 21 | January 12th 04 10:27 AM |
PC flight simulators | Bjørnar Bolsøy | Military Aviation | 178 | December 14th 03 12:14 PM |
Airdropped Fusion Devices | Blinky the Shark | Military Aviation | 4 | September 17th 03 05:34 PM |
