Why no "situational awareness" (collision avoidance) apps for cell phones?
Old May 7th 18, 04:49 PM posted to rec.aviation.soaring
kirk.stant
Default Why no
On Monday, May 7, 2018 at 1:08:58 AM UTC-5, Mike Schumann wrote:
Please share with me exactly what I am saying about PowerFlarm that is factually incorrect?
Your posts continually claim that PF does not see UAT or TIS-B aircraft. Since you HAVE to have a Mode C transponder to put out UAT ADS-B OUT and TIS-B, the PF will detect the presence of that aircraft - AND Mode S ADS-B out, AND plain Mode S transponders, AND other PF gliders.
Back at you - what setup do you have in a glider that gives the equivalent situational awareness as PowerFlarm? Does it display on commong glider displays? How much does it cost?
Kirk
66
  #42
Old May 7th 18, 05:15 PM posted to rec.aviation.soaring
Mike Schumann[_2_]
Default Why no
Kirk
66
1. You do not need to have a Mode C or S transponder to equip an aircraft with UAT ADS-B Out. If you are exclusively flying in an area where transponders are not required, given the price difference, it is not unreasonable to install a UAT ADS-B transceiver if you want to make yourself visible to ATC and trigger the ADS-B ground stations to get TIS-B and ADS-R traffic.
2. I never said that a PowerFlarm equipped pilot would not see a transponder equipped aircraft. What I have said, which is 100% accurate, is that PowerFlarm does not support TIS-B and ADS-R, so that the situational awareness is not nearly as good as with virtually all other ADS-B receivers. The reality is that when PowerFlarm sees a transponder equipped aircraft, all you know is the altitude of the aircraft, and a rough approximation of its range. You have no way to tell if the aircraft is behind you, off to the side, or in front. If PowerFlarm supported TIS-B (and you were ADS-B OUT equipped and within range of a ground station), you would see the exact position of the transponder equipped aircraft with the same accuracy as is visible on ATC radar.
3. I have a Phoenix Motorglider with a Dynon Skyview system that includes a 1090ES transponder with 2020 compliant ADS-B Out support. The system also includes a dual frequency ADS-B IN receiver which supports TIS-B, ADS-R, as well as providing all the weather and TFR data that is transmitted by the ADS-B ground stations. This is certainly not a system you would put in a normal glider. For that, I would recommend a Trig transponder with a GPS position source for ADS-B Out, along with a Scout ADS-B receiver ($199) feeding the Foreflight app running on an iPhone for ADS-B traffic warnings.
  #43
Old May 7th 18, 06:14 PM posted to rec.aviation.soaring
Tango Eight
Default Why no "situational awareness" (collision avoidance) apps forcell phones?
On Monday, May 7, 2018 at 10:03:47 AM UTC-4, wrote:
On Saturday, May 5, 2018 at 9:42:40 AM UTC-4, Jonathan St. Cloud wrote:
What are you using for data to come up with your "conclusion" that "the collision odds with be about the same"? Let me guess, no data, just a feeling?
Geez I didn't research the numbers but I'm pretty certain mid air collision rates in Region 1 haven't changed post Flarm. Thus collision odds are about the same. This ain't the Alps. But I have a question about soaring in the Alps, how do you guys miss the masses of nonbeeping paragliders?
Hmmmmmm.... I don't recall we've ever had a glider mid air in R1. One of the reasons I love it here is that the sky is still big.
However, guys I know personally have been involved in 7 glider midairs I can recall in one minute's reflection. Only a few of those are in the NTSB database. Most of those guys are still flying and (not surprisingly) all of them were early adopters of PowerFlarm.
Paragliders are essentially stationary and easier to see than sailplanes. You can equip a paraglider with flarm too.
T8
  #44
Old May 7th 18, 06:24 PM posted to rec.aviation.soaring
kirk.stant
Default Why no
Strawman argument. Do you actually think someone who doesn't have a transponder is going to install a UAT out system?
Again, Mike, in a glider this is not the issue - the issue is compatible systems and displays. And the incredibly stupid FAA UAT system coupled with the need to have ADS-B out of some sort to see all ADS-B traffic. Otherwise, my PF would right now see all ADS-B traffic, not just all Mode-S traffic.. And sure, ADS-B in display would be nice - but in and LS6 cockpit there is no room for multiple displays - and barely room to get a transponder on the panel!
Exactly - you are flying an airplane, not a glider, with room and electrical power for a nice big display. Your setup has NO relevance to true sailplanes that are much more space limited.
So do us a favor and quit bashing PowerFLARM - we understand that for YOUR application it isn't the best solution, and I agree with you on that - but for a small cockpit racing sailplane, current ADS-B solutions are not yet optimum.
Kirk
66
  #45
Old May 7th 18, 07:27 PM posted to rec.aviation.soaring
Mike Schumann[_2_]
Default Why no
I didn't say anyone was going to do this. You said it wasn't possible. It is. Quit posting stuff that is not correct.
Again, Mike, in a glider this is not the issue - the issue is compatible systems and displays. And the incredibly stupid FAA UAT system coupled with the need to have ADS-B out of some sort to see all ADS-B traffic. Otherwise, my PF would right now see all ADS-B traffic, not just all Mode-S traffic. And sure, ADS-B in display would be nice - but in and LS6 cockpit there is no room for multiple displays - and barely room to get a transponder on the panel!
The FAA's UAT system is NOT stupid. It was essential to provide the bandwidth necessary for the wealth of ADS-B services for which ADS-B was initially designed, such as weather, Flight Restrictions, etc. What was unfortunate was the unwillingness of foreign governments to sign on the UAT standard, resulting in the complexities of a dual frequency system. Not an ideal situation, but one we are going to have to live with.
3. I have a Phoenix Motorglider with a Dynon Skyview system that includes a 1090ES transponder with 2020 compliant ADS-B Out support. The system also includes a dual frequency ADS-B IN receiver which supports TIS-B, ADS-R, as well as providing all the weather and TFR data that is transmitted by the ADS-B ground stations. This is certainly not a system you would put in a normal glider. For that, I would recommend a Trig transponder with a GPS position source for ADS-B Out, along with a Scout ADS-B receiver ($199) feeding the Foreflight app running on an iPhone for ADS-B traffic warnings..
There are ADS-B solutions that are appropriate for racing sailplanes. It is a no-brainer for anyone flying an experimental glider that is already equipped with a Trig transponder to add a TN-72 GPS source and be ADS-B OUT equipped. Add a $199 Scout ADS-B receiver and Foreflight running on an iPhone in your shirt pocket and you have a full blown dual frequency ADS-B collision avoidance system with audio prompts without taking up any panel space.
What is absurd is the half baked Euro Centric engineering in PowerFlarm that makes it such a limited system in the US market. The hardware is all there. They are just too lazy (or share your anti UAT attitude), to take advantage of the existing US ADS-B infrastructure to have a truly effective anti-collision system. So that leaves glider pilots in the quandary of do you want an optimized system to protect against glider-glider collisions, or do you want a general purpose system that protects you from collisions with general aviation aircraft. Rather than rail at me for pointing out the obvious, why don't you spend some of your energy ranting at PowerFlarm on why they don't get their act together and fully support the US ADS-B architecture.
  #46
Old May 7th 18, 08:50 PM posted to rec.aviation.soaring
Paul Agnew
Default Why no
I tested an XGPS170 Dual with the Avare app on my Android phone yesterday and found it helpful, but a little lacking. Avare allows "filtering" of ADS-B traffic at 10,000ft or 100,000ft ranges and I could really use a mid-range option. I didn't look at it until off tow, but it appeared to be receiving the signal well above 2000' - and possibly lower. I was trying to connect with some seabreeze lift and didn't have much time to devote to watching to see when the signal was lost in the descent. (Alas, it was a late afternoon, post-annual inspection sled ride - just missed it by that much.)
The other option I would like to see is a simpler map for just traffic awareness instead of overlaying the sectional. The little blue dot representing an airplane gets lost in the clutter on the Miami sectional.
The biggest improvement they could make would be to add a proximity range and audio alert to Avare. I had a small corporate jet in my vicinity that showed up perfectly, but only after I had already spotted him coming my way. (I had XCSoar up and wasn't staring at the screen.) An audio alert would have been great to improve my awareness of his proximity.
Avare...are you listening? Opportunity knocks...
Paul A
ASW-19
  #47
Old May 7th 18, 09:20 PM posted to rec.aviation.soaring
kirk.stant
Default Why no
Mike, I guess we will just have to agree to disagree. Your pro-UAT bias is noted. Funny how Europe which has denser air traffic does fine without UAT. Wx and TFR data was added, IMO, to satisfy the people who wanted to keep the old Mode C transponders with a UAT ADS-B out setup. Carrot.
Your solution (ADS-B in on my phone) is unacceptable. People don't look out the window as it is, now you want them pulling out their phone and messing with that inflight? No thank you.
Kirk
66
  #48
Old May 7th 18, 10:33 PM posted to rec.aviation.soaring
Default Why no
Not at Kirk....just a way to post through iPad......
Cell info RELIES on a cell connection.
Pretty much PERIOD.
If out of suitable range of a cell tower, ANY cell info is either lost or may be so out of date you get the warning AFTER the midair.
So, what's the point?
You need ship to ship info rather quick.
You want to follow a friend or competitor? Then some lag is sorta OK.
You want to avoid a ship to ship collision, a "RIGHT NOW" may not be enough.. Back to eyeballs, regardless of how imperfect they may be.
Sheesh, I hate "nannies" and I hate some rules (like mandatory helmet laws for motorcycles).
But.......I will like pay attention to nannies and you will likely NEVER catch me on a motorcycle without a helmet. Even if I am "putt putting" in front of my house. Taken from someone that broke their back 35 years ago from a car that didn't yield on a small highway.They were wrong, I broke my back.
You may be right, you may also be dead right.
I prefer, "see and avoid, hope I can testify at the hearing......".
[frikkin Internet has created so many "muscle men" that would likely fold in person.....].....sigh....in general, not at Kirk at this point, or at Gregg, at this point....
  #49
Old May 7th 18, 10:59 PM posted to rec.aviation.soaring
kirk.stant
Default Why no
On Monday, May 7, 2018 at 4:33:26 PM UTC-5, Charlie M. (UH & 002 owner/pilot) wrote:
Pretty much PERIOD.
You want to avoid a ship to ship collision, a "RIGHT NOW" may not be enough. Back to eyeballs, regardless of how imperfect they may be.
Hi Charlie,
With 2 Kirks now it's getting confusing, but a good heated discussion is always fun, as long as it stays civil.
Totally agree about any cell-based solution; it's more for spectating on the ground than real save-your-life stuff.
And I'm totally with you on the Nanny-state thing - I like to make my own researched decision rather than accept whatever some functionary/lawyer decides is best for me!
The really tragic thing about this whole ADS-B debacle is that the FAA managed to take a basically simple idea and make it so complicated that we are all arguing with each other about it! For us VFR flyers it should have been a $500 gizmo that told everybody where you are and would let you see everybody. At that price, they could have GIVEN the darn things to all VFR pilots for less than the cost of one mid-air.
Anyway, I had fun this Saturday flying XC and watching all the ADS-B and transponder traffic on my PF.
Cheers,
Kirk
  #50
Old May 7th 18, 11:40 PM posted to rec.aviation.soaring
Mike Schumann[_2_]
Default Why no
2. I never said that a PowerFlarm equipped pilot would not see a transponder equipped aircraft. What I have said, which is 100% accurate, is that PowerFlarm does not support TIS-B and ADS-R, so that the situational awareness is not nearly as good as with virtually all other ADS-B receivers.. The reality is that when PowerFlarm sees a transponder equipped aircraft, all you know is the altitude of the aircraft, and a rough approximation of its range. You have no way to tell if the aircraft is behind you, off to the side, or in front. If PowerFlarm supported TIS-B (and you were ADS-B OUT equipped and within range of a ground station), you would see the exact position of the transponder equipped aircraft with the same accuracy as is visible on ATC radar.
Kirk
66
Sorry to disappoint you, but I don't have a pro UAT bias. If I was going to put ADS-B OUT in a normal glider, I would go the 1090ES route with a Trig Mode S transponder.
As far as an iPhone based ForeFlight collision warning system, you are once again commenting on something that you know nothing about. You don't need to pull the iPhone out of your pocket. ForeFlight gives you an audio warning of exactly where the collision threat is (i.e. "11 O'Clock, 2 miles, 1,000 ft low"), so you can keep your eyeballs outside the cockpit knowing EXACTLY where to look for the threat traffic.
Traffic Awareness and Collision Avoidance Talks at the SSA Convention Darryl Ramm Soaring 8 February 27th 18 11:49 PM
3rd Party Flarm data for Situational awareness Alex Kemp Soaring 6 March 12th 13 08:20 PM
GET FREE CELL PHONES and CAMERA PHONES! ssgg Home Built 0 February 13th 06 02:34 AM
Fun with Wx on Cell Phones B4RT Rotorcraft 0 October 9th 05 02:45 PM
Cell phones with GPS Roger Halstead Piloting 0 December 24th 03 03:04 AM
