Trailer license problem
Old May 31st 18, 05:13 PM posted to rec.aviation.soaring
Paul Agnew
Default Trailer license problem
FWIW - you can order trailer ID tags, engraved or blank, from Ebay or Amazon. Putting one on the trailer might help some of you with your local requirements.
Paul A.
  #43
Old May 31st 18, 06:01 PM posted to rec.aviation.soaring
JS[_5_]
Paul A.
Why do so many US glider pilots not have clean title to trailers?
My estimate is 20%.
  #44
Old May 31st 18, 06:39 PM posted to rec.aviation.soaring
John Carlyle
I've had 3 glider trailers, only one of which had a clean title. The other 2 came to me from owners in states where trailers have license plates, but no titles. I think that is the major issue we're seeing.
-John, Q3
My estimate is 20%.
  #45
Old May 31st 18, 06:44 PM posted to rec.aviation.soaring
Papa3[_2_]
Yup. NJ for example does not require a title for trailers under 2500# (i.e. pretty much every glider trailer ever made).
  #46
Old May 31st 18, 07:19 PM posted to rec.aviation.soaring
OHM Ω http://aviation.derosaweb.net
Paul A.
My estimate is 20%.
My Michigan purchased homebuilt came without a title. My Illinois home state DOT had no problem with creating one.
What I am picking up here is that each state (from and/or to) has its own nuances/hurdles/insanity on getting the trailer properly licensed/titled.
My bottom line is that I believe I can move the trailer across any state line without either a plate, or a title, as long as I have a valid bill of sale (with phone numbers!). Is that a flawed assumption?
- John OHM Ω
  #47
Old May 31st 18, 07:59 PM posted to rec.aviation.soaring
John Carlyle
You're correct - each state has its own hoops for you to get OK with a trailer. Some don't require title or plates, some require plates and registration but give no title, some require a title to get registration and plates.
I can tell you for sure that if you have a PA plate (we only use one) on your tow vehicle and you pull a trailer without a license plate, you will have trouble with the police even if you have a valid BoS (happened to a friend). Might get away with it with non-PA plate(s) on the tow vehicle, but it all depends on the officer you get...
-John, Q3
On Thursday, May 31, 2018 at 2:19:58 PM UTC-4, OHM Ω My Michigan purchased homebuilt came without a title. My Illinois home state DOT had no problem with creating one.
- John OHM Ω
  #48
Old June 1st 18, 09:19 AM posted to rec.aviation.soaring
Its incedibly ironic that a country that cant manage the most obvious need for gun laws, where an AR15 can be purchased readily, makes it so Byzantine to buy a trailer.
Only in ‘Murica.
  #49
Old June 1st 18, 12:55 PM posted to rec.aviation.soaring
Well, maybe there needs to be the "NTA", National Trailer Association, to push for trailer reforms. Then, almost anyone can buy and register a trailer whether they need one or not.
;-) LOL......
/sarcasm.....
Valid point though.
  #50
Old June 1st 18, 02:11 PM posted to rec.aviation.soaring
On Friday, June 1, 2018 at 6:55:43 AM UTC-5, Charlie M. (UH & 002 owner/pilot) wrote:
;-) LOL......
/sarcasm.....
Valid point though.
"Only a good guy with a trailer can stop a bad guy with a trailer". "I'll give you my trailer if you pry is from my cold dead hands".
Cannot get temporary PAMVD license tag for Sailplane Trailer deliveryfrom Pennsylvania to New Mexico! blackcat Soaring 11 September 12th 10 03:45 PM
cobra trailer brake lever gas strut problem - solved Frank[_1_] Soaring 1 April 3rd 09 06:08 AM
Harry's trailer problem: SOLVED! wright1902glider Home Built 1 April 1st 09 06:40 PM
Cobra trailer latching problem JJ Sinclair Soaring 5 September 23rd 04 10:21 PM
Should the USA have a soaring license, not a glider license? Mark James Boyd Soaring 0 August 6th 04 07:16 PM
