Hi Guys,
I'm curious if any of you guys have ever tried to self launch with no wing man on a cg hook only glider. I have skids on my wingtips as well. Would you put the wing that's on the ground further forward at start? What's the technique!! I think this is why having a cg hook is a disadvantage. Regards, Jerz |
Jerz Rossignol wrote:
Hi Guys, I'm curious if any of you guys have ever tried to self launch with no wing man on a cg hook only glider. I've done it in my LS6 when I was aerotowed from a spasely populated airport following a landout. It was really a no brainer. I have skids on my wingtips as well. Would you put the wing that's on the ground further forward at start? What's the technique!! With a CG hook, the glider has to point in the desired direction of travel, IMHO. With a nose hook, you can angle the nose into the cross wind (if any) and lower the upwind wing. The theory being that when the tow plane starts, the nose hook will swing the nose straight, accelerating the upwind (low wing) allowing it to lift level almost immediately. I think this is why having a cg hook is a disadvantage. I would prefer a nose hook in this situation. Tony V. http://home.comcast.net/~verhulst/SOARING |
"Jerz Rossignol" wrote in message m... Hi Guys, I'm curious if any of you guys have ever tried to self launch with no wing man on a cg hook only glider. I have skids on my wingtips as well. Would you put the wing that's on the ground further forward at start? What's the technique!! I think this is why having a cg hook is a disadvantage. Regards, Jerz Yes, from remote fields. It's no problem, but the dust cloud from the tow plane is sometimes pretty wild, especially if it's the first time you've encountered it. Frank Whiteley |
A CG hook is a disadvantage only if you never plan to winch launch.
I was shown at rig made with PVC plumbing pipe for just such a situation. it worked like a saw horse with a carpeted top and could be broken down for storage in the glider trailer. Starting with the wings close to level is a big help. I don't think I would try a CG hook, wing-on-the-ground start with my Nimbus Bill Daniels "Jerz Rossignol" wrote in message m... Hi Guys, I'm curious if any of you guys have ever tried to self launch with no wing man on a cg hook only glider. I have skids on my wingtips as well. Would you put the wing that's on the ground further forward at start? What's the technique!! I think this is why having a cg hook is a disadvantage. Regards, Jerz |
"Bill Daniels" wrote in message news:sbPid.368503$D%.307763@attbi_s51...
A CG hook is a disadvantage only if you never plan to winch launch. I was shown at rig made with PVC plumbing pipe for just such a situation. it worked like a saw horse with a carpeted top and could be broken down for storage in the glider trailer. Starting with the wings close to level is a big help. I don't think I would try a CG hook, wing-on-the-ground start with my Nimbus Bill Daniels Have done it in my Nimbus 3 and many times in my Pegasus, both CG hooks. |
I too have done it in an LS6 - We just lined it up and went - powerful
towplane helps. But we used to practice it in a 2-22. There was a very specific technique and it was not self-evident. As I recall, the upwind wing was down but the nose pointed downwind (!). This allowed for weathervaning which would effect the a/c before the controls became effective. It worked pretty well. Of course, the 2-22 sits on it's nose rather than it's tail. So why would you point an unguided rocket downwind in order to have it reach apogee directly over the launcher? "Jerz Rossignol" wrote in message m... Hi Guys, I'm curious if any of you guys have ever tried to self launch with no wing man on a cg hook only glider. I have skids on my wingtips as well. Would you put the wing that's on the ground further forward at start? What's the technique!! I think this is why having a cg hook is a disadvantage. Regards, Jerz |
Aerotow no problem. Don't try it with a winch though!
Ian "Jerz Rossignol" wrote in message m... Hi Guys, I'm curious if any of you guys have ever tried to self launch with no wing man on a cg hook only glider. I have skids on my wingtips as well. Would you put the wing that's on the ground further forward at start? What's the technique!! I think this is why having a cg hook is a disadvantage. Regards, Jerz |
"tango4" wrote: Aerotow no problem. Don't try it with a winch though! Why not? Winch is easier than aerotow: The rapid acceleration means you have instant roll-axis control. (done it several times, easy as pie) - mark |
"Mark Newton" wrote in message ... In article , "tango4" wrote: Aerotow no problem. Don't try it with a winch though! Why not? Winch is easier than aerotow: The rapid acceleration means you have instant roll-axis control. (done it several times, easy as pie) - mark Instant roll control and no prop wash to deal with. There was a 'lone ranger' who built a remote controlled winch 20 or 30 years ago. He could launch himself with no help at all. I'd like to know more about that winch. Bill Daniels |
Bill Daniels wrote:
Instant roll control and no prop wash to deal with. Actually, the prop wash will help, by providing some airflow over the wings and control surfaces, giving you a certain degree of control, even before the speed builds up. CV |
| Thread Tools | |
| Display Modes | |
| spaceship one | Pianome | Home Built | 169 | June 30th 04 06:47 AM |
| Vandenberg Launch, April 17 | Piloting | 5 | April 9th 04 03:21 AM | |
| Ground launch and the incremental vanishing of soaring | Mark James Boyd | Soaring | 24 | March 8th 04 11:50 PM |
| Pegasus/TRACE Launch Photos Posted | Brian Webb | Military Aviation | 0 | February 21st 04 04:50 PM |
| Friendly fire pilot may testify against wingman | Otis Willie | Military Aviation | 0 | October 11th 03 10:32 PM |
