At 22:30 30 December 2004, Eric Greenwell wrote:
A Google search turned up laser airspeed sensors that, in concept, could be used to measure L/D directly from the glider. Some of them were good for the low speeds we need to measure sink rates. So, have one pointing forward, one pointing down, divide the forward speed by the sink rate, and ta-da! L/D. Would you need an inertial platform to resolve horizontal and vertical accurately enough or would eyeballing it be good enough? Also, the forward looking and downward looking lasers would be observing different air, so it's possible that would cause problems, depending on how far out they look. I think it might work - though at a hefty price I bet. 9B |
Andy Blackburn wrote:
At 22:30 30 December 2004, Eric Greenwell wrote: A Google search turned up laser airspeed sensors that, in concept, could be used to measure L/D directly from the glider. Some of them were good for the low speeds we need to measure sink rates. So, have one pointing forward, one pointing down, divide the forward speed by the sink rate, and ta-da! L/D. Would you need an inertial platform to resolve horizontal and vertical accurately enough or would eyeballing it be good enough? Since the concept is to measure speed through the airmass, I don't think inertial systems would help any, as they are referenced to the aircraft, not the air. I don't know if any of the systems would actually give us the vertical speed accuracy we'd like. A major application seemed to be for helicopters, which can move very slowly (and even back up), so low speed sensing is certainly feasible. Speeds over 20-30 knots seemed to be easy to get with the units I glanced at. Also, the forward looking and downward looking lasers would be observing different air, so it's possible that would cause problems, depending on how far out they look. The distances available varied from a "a few feet" to hundreds of feet, I think. Very application dependent: helicopters couldn't use anything that sensed closer that the outer edge of the rotor downwash, for example. I'm guessing one for gliders could be set for, say, 100 feet to be far enough from the glider's influence on the airmass, and this still have both the forward and downward airmasses close enough to be the "same" airmass. Some of the sensors actually sensed at right angles to the sensor beam to measure crosswinds, and maybe one of these could be also be pointed straight down into the same airmass the vertical speed unit was looking at. I think it might work - though at a hefty price I bet. Yes, all the units I came across seemed to be high end or developmental, and rather large to stick into a glider. A careful search might have better luck. A mitigating factor for cost is gliders already have a pretty good forward airmass speed sensor - the ASI - so perhaps only a downward aimed laser sensor good for measuring 100 to 500 feet per minute at 2% accuracy would be satisfactory. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
![]() "Eric Greenwell" wrote in message ... snip Some of the sensors actually sensed at right angles to the sensor beam to measure crosswinds, and maybe one of these could be also be pointed straight down into the same airmass the vertical speed unit was looking at. I think it might work - though at a hefty price I bet. Yes, all the units I came across seemed to be high end or developmental, and rather large to stick into a glider. A careful search might have better luck. The sensor I posted a link to was small enough to be mounted on a rifle as a sight. http://www.navysbir.brtrc.com/succes...navsea_p3.html That would seem to be a feasible size, weight and ruggedness for a glider I've sent an email with some questions I had, but haven't yet received an answer. Some of the applications they mention on that website -- Automotive, Collision Avoidance, Cruise Control, Parking Aid, would require the cost to be fairly reasonable (though the volume would be a lot more than sailplanes would ever give them.) A mitigating factor for cost is gliders already have a pretty good forward airmass speed sensor - the ASI - so perhaps only a downward aimed laser sensor good for measuring 100 to 500 feet per minute at 2% accuracy would be satisfactory. If the laser and optics can be made to "see" through the canopy, pointing it upward might make for an easier install. I've seen compasses mounted on top of the panel. OTOH, with it pointing downwards, it might give a good input to a gear warning device. If it can detect small particles, I'll bet it can detect a solid surface -- and that the signals are way different. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
Tim Ward wrote:
Yes, all the units I came across seemed to be high end or developmental, and rather large to stick into a glider. A careful search might have better luck. The sensor I posted a link to was small enough to be mounted on a rifle as a sight. http://www.navysbir.brtrc.com/succes...navsea_p3.html I thought it was something telescope sized that sat next to the rifleman.I can see now it's about the size of a flashlite - much smaller than the airspeed units I saw. That would seem to be a feasible size, weight and ruggedness for a glider I've sent an email with some questions I had, but haven't yet received an answer. Let us know what they write. Some of the applications they mention on that website -- Automotive, Collision Avoidance, Cruise Control, Parking Aid, would require the cost to be fairly reasonable (though the volume would be a lot more than sailplanes would ever give them.) A mitigating factor for cost is gliders already have a pretty good forward airmass speed sensor - the ASI - so perhaps only a downward aimed laser sensor good for measuring 100 to 500 feet per minute at 2% accuracy would be satisfactory. If the laser and optics can be made to "see" through the canopy, pointing it upward might make for an easier install. I've seen compasses mounted on top of the panel. Maybe a mirror adapter to peek out the side window. If the beam is small enough, mounting it in the baggage compartment and pointing up through a 1/2" hole in the turtledeck wouldn't bother me. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
At 23:00 31 December 2004, Eric Greenwell wrote:
Since the concept is to measure speed through the airmass, I don't think inertial systems would help any, as they are referenced to the aircraft, not the air. I menat an inertial platform for attitude, not velocity. If you the sensor isn't pointing horizontally/vertically or parallel/perpendicular to the flight path, you will likely get confounded results. 9B |
At 23:00 31 December 2004, Eric Greenwell wrote: Since the concept is to measure speed through the airmass, I don't think inertial systems would help any, as they are referenced to the aircraft, not the air. I menat an inertial platform for attitude, not velocity. If you the sensor isn't pointing horizontally/vertically or parallel/perpendicular to the flight path, you will likely get confounded results. I think the angle of attack range for an unflapped airfoil is about 10 degrees, which would suggest errors of 0 (at high speed, for example) increasing to 1.5% at low speed (or vice versa - depends on where you aim the sensor). This could be easily corrected using using the airfoil's Cl vs AOA chart. For a flapped airfoil, the fuselage AOA range is even smaller, and the errors could likely just be ignored. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
At 07:00 01 January 2005, Eric Greenwell wrote:
I think the angle of attack range for an unflapped airfoil is about 10 degrees, which would suggest errors of 0 (at high speed, for example) increasing to 1.5% at low speed (or vice versa - depends on where you aim the sensor). This could be easily corrected using using the airfoil's Cl vs AOA chart. For a flapped airfoil, the fuselage AOA range is even smaller, and the errors could likely just be ignored. 50:1 is an angle of a degree and a bit so if you have your 'straight ahead' and 'straight down' sensors canted down/aft by just a degree from true horizontal/vertical, you'll get a pretty accurate airspeed, but the 'vertical' speed will likely show zero, I think, since it will be reading off dust particles that have zero velocity towards/away from the glider. 9B |
At 07:00 01 January 2005, Eric Greenwell wrote: I think the angle of attack range for an unflapped airfoil is about 10 degrees, which would suggest errors of 0 (at high speed, for example) increasing to 1.5% at low speed (or vice versa - depends on where you aim the sensor). This could be easily corrected using using the airfoil's Cl vs AOA chart. For a flapped airfoil, the fuselage AOA range is even smaller, and the errors could likely just be ignored. 50:1 is an angle of a degree and a bit so if you have your 'straight ahead' and 'straight down' sensors canted down/aft by just a degree from true horizontal/vertical, you'll get a pretty accurate airspeed, but the 'vertical' speed will likely show zero, I think, since it will be reading off dust particles that have zero velocity towards/away from the glider. Think of the glider flying straight and steady in still air: it is descending (vertical motion) through the air at whatever it's sink rate is. So, at least in concept, a laser airspeed sensor pointed straight down will be able to measure this. Even if the sensor is aimed a few degrees one way or the other from perpendicular, the error would be very small, equal to sine of the angle off of perpendicular. If the airmass is moving, the measurement would be the same, of course, since the speed measured is the air motion relative to the glider - it's just easier to visualize what's happening with still air. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
If the sensor is aiming straight down, at a glide angle of 40/1 the air
is going 40" aft for every 1" that it rises relative to the instrument. If the sensor is aimed slightly aft (1/40, whatever that is in degrees), the air won't be rising at all relative to the sensor. Right? So isn't angle crucial? Also, can the sensors measure speed when the air mostly is going crossways in front of the sensor? |
Greg Arnold wrote:
If the sensor is aiming straight down, at a glide angle of 40/1 the air is going 40" aft for every 1" that it rises relative to the instrument. If the sensor is aimed slightly aft (1/40, whatever that is in degrees), the air won't be rising at all relative to the sensor. Right? So isn't angle crucial? OK, I'm persuaded! It now appears the sensor would need to be aimed up or down rather accurately, or the at least the angle off vertical measured accurately. Dang - that's harder. Perhaps the inertial system would be a reasonable way to achieve this, or maybe differential GPS system with antennas on the nose and tail. Also, can the sensors measure speed when the air mostly is going crossways in front of the sensor? I think it depends on the sensor: some are optimized for speed in line with the beam, some for speed perpendicular to the beam (cross wind measurement, like for bullets). Perhaps there are ones that can read the vector wind? I have no idea how much crossways speed the various sensors can tolerate. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
RAF Blind/Beam Approach Training flights | Geoffrey Sinclair | Military Aviation | 3 | September 4th 09 06:31 PM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 02:26 PM |
new theory of flight released Sept 2004 | Mark Oliver | Aerobatics | 1 | October 5th 04 10:20 PM |
Flight Simulator 2004 pro 4CDs, Eurowings 2004, Sea Plane Adventures, Concorde, HONG KONG 2004, World Airlines, other Addons, Sky Ranch, Jumbo 747, Greece 2000 [include El.Venizelos], Polynesia 2000, Real Airports, Private Wings, FLITESTAR V8.5 - JEP | vvcd | Piloting | 0 | September 22nd 04 07:13 PM |
AmeriFlight Crash | C J Campbell | Piloting | 5 | December 1st 03 02:13 PM |
