Implausible Time Records
Old May 20th 19, 04:45 PM posted to rec.aviation.soaring
Default Implausible Time Records
Ref .
I notice your Oct 2 2018 flight on OLC had that peculiar highly
compressed altitude graph, but without the gps altitude dropouts. Maybe
that's just some unrelated OLC display issue.
Good observation, I didn’t notice that.
The one on 10/4 has the same compressed altitude issue, while the one on 10/3 looks ok, as does the flight on 5/1/19.
I have been posting to OLC from that particular 9070 for about 4 years and haven’t had a problem before now.
MS
  #42
Old May 20th 19, 08:05 PM posted to rec.aviation.soaring
kinsell
On 5/20/19 9:45 AM, wrote:
Ref .
MS
Also I notice your Oct 2 log had a 2 second backwards jump in the time
stamp, nicely pointed out by a CLOCKJUMP message.
B1836063309906N08617890WA0079300914008999092601063 91370014102310100
B1836073309895N08617877WA0079700918008999099341052 61320019502310100
B1836083309885N08617862WA0080100922008999096891031 41260027202310100
B1836093309877N08617847WA0080400926008999097381021 11210032602300100
LLXVCLOCKJUMP
B1836073309869N08617831WA0080900931008999091120999 41150032402300110
B1836083309863N08617815WA0081500936008999087500984 01100029902300090
B1836093309859N08617798WA0081800940008999092360980 91040030802290090
B1836103309856N08617781WA0082200942008999096080987 51000036802290080
So these problems have been around for quite a while, maybe OLC just
started flagging them as fatal errors?
  #43
Old May 20th 19, 08:28 PM posted to rec.aviation.soaring
kinsell
Ref .
compressed altitude graph, but without the gps altitude dropouts.Â* Maybe
MS
LLXVCLOCKJUMP
Looking at your Aug 2 2017 flight, it shows the same compressed altitude
graph, and another 2 second backwards jump in a time stamp. Wow.
  #44
Old May 20th 19, 08:41 PM posted to rec.aviation.soaring
Maybe he is exceeding VNE by a lot and going back in time? I wonder what Doc Brown would say.....LOL...
  #45
Old May 20th 19, 09:42 PM posted to rec.aviation.soaring
I’ve not heard back from Lxnav yet, but I had a private email from a very smart person that pointed out that both the October 2 and October 4 flights had the clock jump after takeoff but before soaring began. The flight this week had the clock jump a minute or so after soaring began, and thus is likely why OLC flagged this one and not the other two. It appears that the clock jump is 7 to 8 minutes after the unit is turned on. Since I generally do not turn the system on until just before takeoff, it is believed that the system is using an internal clock until it syncs with the gps satellites and then resets the clock which may be different by a couple of seconds. My plan is to turn the 9070 on a few minutes before launch to allow it to sync clocks to see if that helps. It is not clear to me if Dan’s issue is similar to mine or different.
MS
  #46
Old May 20th 19, 10:05 PM posted to rec.aviation.soaring
Dan Marotta
That's certainly worth a try.Â* My normal method is to saddle up, start
the engine, and turn on the CN2, the CN vario, and the PowerFlarm
portable (which does not have an ENL license).Â* Then I run checklists
and taxi out and, as soon as the temperatures are in the green, take
off.Â* I'll try turning on the computers first and take my time with
getting started and to the hold short line.Â* I'll shoot for 10 minutes
and see how that goes.
MS
Dan, 5J
  #47
Old May 20th 19, 10:06 PM posted to rec.aviation.soaring
MS
We've established in another thread some months ago that the display of altitudes of a flight within the OLC web page is all messed up if OLC thinks that the flight "started" later, at some higher logged altitude, rather than at the altitude of the declared takeoff airport. (Typically due to the flight recorder not getting a GPS fix - or not being turned on at all - until after takeoff.) I am still of the opinion that this should be considered a bug in OLC, since it can "see" that the start location (lat/lon as well as altitude) is not at the airport. The altitudes inside the flight log file, even as downloaded from OLC, are still OK. Perhaps the time jump, too, makes OLC think it's a new "takeoff", and thus has similar consequences in its display (plus its "implausible" warning).
But I don't quite understand the conjecture that "the system is using an internal clock until it syncs with the gps satellites", because prior to getting a GPS fix the flight recorder shouldn't be recording locations into the flight log either, no?
  #48
Old May 20th 19, 10:27 PM posted to rec.aviation.soaring
kinsell
MS
They do have clocks to help achieve lock on the satellites, but I've
seen the reported time jump immediately after lock was achieved. Don't
know why the 9070 would wait minutes after achieving lock before
correcting the time. Maybe an issue of 2D vs 3D lock. If you're
turning on the logger immediately before takeoff, you're risking losing
the early part of the flight entirely, not just having time problems.
Dan was having lots of gps altitude dropouts during flights, that might
just be jamming. He did have a time jump just at liftoff, so that fits
in with switching the clocks.
  #49
Old May 20th 19, 11:03 PM posted to rec.aviation.soaring
Yes, the system seems to have a fix on the satellites and the Lat/Lon/Alt seems to be consistent from one record to another. It certainly doesn’t take several minutes for the system to get a gps fix. The question is why does it record an incremental time for a few minutes and then resets the time by a couple of seconds. It would seem the system should record the time stamp directly from the gps. If it did that, how could sequential time records change? Is it possible the gps starts with an internal clock number initially and then after a few minutes makes a comparison check with the clock from the gps? It gets back to Kensell’s point about how the gps system is handling the data and or the firmware is using the info inside the computers. These seem like good questions for vendors which I hope to get soon.
  #50
Old May 20th 19, 11:09 PM posted to rec.aviation.soaring
Tim Newport-Peace[_6_]
and
appears
I
couple
to
MS
I've looked at Dan's trace, and the dropouts are in the latter part of the
flight,
nowhere near the time when the clock problem occurs, so probably not
jamming. Micheal's flight shows no GPs dropouts at all, but still
experienced
the problem.
All US Records are Now Motor Glider Records Tango Eight Soaring 99 March 23rd 17 12:07 PM
OT 4 airport round robin - time lapsed / real time with ATC COMS -video A Lieberma[_2_] Owning 0 August 30th 09 12:26 AM
OT 4 airport round robin - time lapsed / real time with ATC COMS -video [email protected] Instrument Flight Rules 0 August 30th 09 12:26 AM
4 airport round robin - time lapsed / real time with ATC COMS - video [email protected] Piloting 0 August 30th 09 12:25 AM
they took me back in time and the nsa or japan wired my head and now they know the idea came from me so if your back in time and wounder what happen they change tim liverance history for good. I work at rts wright industries and it a time travel trap tim liverance Military Aviation 0 August 18th 03 12:18 AM
