#41
"Barnyard BOb --" wrote in message ... I'd put forth the idea that the worst case environment for an aircraft is always better than the worst case for an automobile. Does anyone disagree on this point? Yeah, I do. Many cars typically don't operate at 80% of rated power for long periods. Worst case environment for an automobile is sitting in stop and go traffic on hot sunny day for long periods of time. Nope. Popular misconception at best. Most cars have absolutely no trouble staying cool while screaming down the highway at full throttle. Wrong again.... Most cars screaming down the highway get tickets or crash long before they sustain 80% for long periods. Lots of variables, but... speeds at 80% power could readily be exceeding 100 mph. Barnyard BOb -- Right. The worst possible overheating, IMHO, is with a vehicle with an automatic transmission, pulling a trailer up a grade that requires the driver to keep WOT for an extended period of time. Add to that, a hot summer day, running the AC. You have engine load, additional transmission waste heat, lower road speed, hot air, and even warmer air going across the radiator because of the AC unit. Most any vehicle will overheat after an extended time, without additional cooling, such as a transmission cooler. -- Jim in NC |
#42
"Jay" wrote in message om... I'm not sure its fair to compare a 10" 1/4 HP electric fan to a 150HP propeller. That 150HP propeller is developing some useful thrust as well. For efficiency the last thing you want is a large amount of it impinging on some flat plate. That 1/4HP fan is shrouded and delivers almost all of it's flow directly to the cooling fins of the radiator. |
#43
Wrong again.... Most cars screaming down the highway get tickets or crash long before they sustain 80% for long periods. Lots of variables, but... speeds at 80% power could readily be exceeding 100 mph. Barnyard BOb -- Yeah, my car screams down the road at 70+ with the engine turning a whole 2800 rpm. Hardly more than about 40% power in most cases. Bob Reed www.kisbuild.r-a-reed-assoc.com (KIS Builders Site) KIS Cruiser in progress...Slow but steady progress.... "Ladies and Gentlemen, take my advice, pull down your pants and Slide on the Ice!" (M.A.S.H. Sidney Freedman) |
#44
(Jay) writes: I'm not sure its fair to compare a 10" 1/4 HP electric fan to a 150HP propeller. Depends on how much of the output from each actually has contact with the cooling surface. That 10" 1/4 hp fan is placed directly next to the radiator and the output is forced through and past the cooling surfaces at a constant and predictable velocity. The vast majority of the output from that 150 hp propeller will not even be close to the cooling surface and its velocity will varry considerably. Bob Reed www.kisbuild.r-a-reed-assoc.com (KIS Builders Site) KIS Cruiser in progress...Slow but steady progress.... "Ladies and Gentlemen, take my advice, pull down your pants and Slide on the Ice!" (M.A.S.H. Sidney Freedman) |
#45
Barnyard BOb -- wrote in message
Most cars have absolutely no trouble staying cool while screaming down the highway at full throttle. Wrong again.... Most cars screaming down the highway get tickets or crash long before they sustain 80% for long periods. Lots of variables, but... speeds at 80% power could readily be exceeding 100 mph. Barnyard BOb -- Driving up a long grade in an automobile or a climb out after takeoff in an aircraft are doing pretty much the same work with the same range engine. Difference is the airspeed past the cowl/hood is WAY higher and more turbulent in the aircraft. But I'd have to agree with you BOb that 80% rated power in a car is easily over 100MPH on level ground in many of the sportier cars. No doubt an aircraft engine lives more of its life at higher power levels. But this is more a case of reliability, not cooling system sizing as the worst case cooling scenario is worse in the car environment. |
#46
#47
Its true that the larger proportion of the air from the propeller
never goes onto the cowl, but it's still a lot. A surface radiator isn't necessarily a flat plane, what shape is the cowl on the airplane you fly? And the air stream is directed onto the cowl at an angle as is necessary to flair around the engine/cowling. The cowl would look similar to the current cowls except it would be more stream lined and have no large holes to duct in air. And of course in big red letters "HOT SURFACE- DO NOT TOUCH" "Ron Natalie" wrote in message om... "Jay" wrote in message om... I'm not sure its fair to compare a 10" 1/4 HP electric fan to a 150HP propeller. That 150HP propeller is developing some useful thrust as well. For efficiency the last thing you want is a large amount of it impinging on some flat plate. That 1/4HP fan is shrouded and delivers almost all of it's flow directly to the cooling fins of the radiator. |
#48
You're going to have drag anyway as the air goes around the cowl,
might as well use it to do something useful. So in this case, the cooling causes no ADDITIONAL drag, right? I'm NOT saying to use a blow through radiator like a car has, these are only efficient (defined as heat transfer per unit drag) at low air speeds. At the airspeeds a couple feet behind the propeller on climb out, most of those fins are down at ambient, transfering no heat, doing nothin' but causing drag. I'm thinking that the bottom surface of the cowl area would be an idea location: 1) Its out of the way during normal engine service. 2) Doesn't complicate removal of the top of the cowl 3) Periods of high load tend to be coincident with periods of high AOA, so this puts more air over the surface when you need it. 4) Looks like a lot of common cowls have a relatively flat spot down there maybe 2'x2'. You might argue that the heat transfer for that area isn't sufficient, and I think the analysis needs to be done, but not by a direct comparison of area from an automobile finned type radiator. The conditions are just too different to make that meaningful. A bottom up calculation that includes heat transfer effects of turbulent air, heat transfer properties of materials (likely Aluminum), waste heat from engine, etc. Regards "Ron Natalie" wrote in message om... "Jay" wrote in message om... Every amount of air that you want to use to cool is effectively drag. Are you claiming your design is going to work without changing the shape of the cowling? I don't think you're going to get anywhere near the heat transfer you need. You were talking about car radiators. I can tell you that plastering a car radiator horizontal on top of the cowl is not going to cool very well. |
#49
Jay wrote:
You might argue that the heat transfer for that area isn't sufficient, and I think the analysis needs to be done, but not by a direct comparison of area from an automobile finned type radiator. The conditions are just too different to make that meaningful. A bottom up calculation that includes heat transfer effects of turbulent air, heat transfer properties of materials (likely Aluminum), waste heat from engine, etc. So do it. Take a couple of 2'x2' sheat of .035 aluminum and a few strips of 3/8" flat aluminum. Lay the flat strips on one piece of sheet so that it forms sides and an interior maze that the water will have to flow through. Drill, caulk and rivet it together. Add a spout for the water to go in and come out with temp probes at each one. Add a couple of T joints to the plumbing of your wife's car (don't let her catch you at it) and bolt the thing to the hood in a way that will shield one side (the one that will be inside the cowl) and also simulate the AOA of the cowl bottom on climbout. Drive around a while at 60 to 70mph and then report back here with what you find out. -- ----Because I can---- http://www.ernest.isa-geek.org/ ------------------------ |
| Thread Tools | |
| Display Modes | |
