How did you install your FLARM brick and/or ADS-B Out?
Old November 29th 19, 01:01 PM posted to rec.aviation.soaring
Dave Nadler
Default How did you install your FLARM brick and/or ADS-B Out?
On Friday, November 29, 2019 at 2:43:10 AM UTC-5, Delta8 wrote:
I do have a question if it will pick up Power Flarm /Flarm equipped
aircraft? I do want to add a Flarm system in the future . Does Power
Flarm/Flarm need to be integrated with the Stratux system ? Would I get
collision warnings from my own Flarm system?
You might want to read the material here to get a better understanding
of the different systems you are asking about:
http://www.nadler.com/GliderPilotUSA...FlarmHome.html
  #42
Old November 30th 19, 12:52 AM
Delta8 Delta8 is offline
Member
First recorded activity by AviationBanter: Apr 2019
Great article thanks . Answered my question ...different frequency .
  #43
Old November 30th 19, 05:18 AM posted to rec.aviation.soaring
On Thursday, November 28, 2019 at 7:53:53 AM UTC-8, Eric Greenwell wrote:
wrote on 11/27/2019 6:08 PM:
On Wednesday, November 27, 2019 at 9:15:31 AM UTC-8, Dan Marotta wrote:
On 11/26/2019 2:23 PM,
My comment was based on my frustration in that I can buy a Scout adsb-in receiver for $200, but have no sunlight-readable display to use with it.. My iphone is not bright enough.
You could try a hood initially made of light cardboard to shade your
phone.Â* I use an iPad in my C-180 and it works just fine given the shade
from the high wing.Â* It's practically useless in direct sunlight.
Dan, 5J
Thanks Dan, but an phone is just not bright enough in my bright glider cockpit. The traffic displays sold for Flarm would do fine, but they only accept flarm data, which means I'd have to buy a flarm system. I suspect this to be a marketing decision to drive flarm sales. Because I think this, I will definitely not buy any flarm product.
I use an iPhone 6 Plus in my glider to run iGlide. Brightness is adequate to good,
ditto when using Foreflight or similar (I can switch between the applications
while flying). You can buy an iPhone newer iPhone 6, some of which are even
brighter, especially the newest ones.
Instead of being angry with Flarm for displays that work only with Flarm, be angry
at the Scout provider for making it Foreflight/OS only, and not compatible with
some other display.
Hi Eric,
I agree that screen brightness is a personal opinion. My opinion is that iphones are inadequate as flight instruments. But it's true I can see my iphone screen in bright sunlight, by holding it at just the right angle. I do this for non time-critical information, like looking up airport information. But I want traffic information to be immediate.
I am presently angry at Flarm, for my suspicions of their harmful business practice that I mentioned. I might redirect my anger at Scout later.
  #44
Old November 30th 19, 05:14 PM posted to rec.aviation.soaring
Dan Marotta
I installed a cheapo Flarmview display.Â* It cost about $200, is daylight
readable, and displays Flarm, ADS-B, and Mode 3/A and Mode S transponder
equipped aircraft.Â* If I had to complain it would be that it's small,
but it works extremely well.Â* Oh, and it was plug and play.
My comment was based on my frustration in that I can buy a Scout adsb-in receiver for $200, but have no sunlight-readable display to use with it. My iphone is not bright enough.
Dan, 5J
some other display.
Hi Eric,
Dan, 5J
Boeing 737 Flies Through Brick Wall, Smashes Tower on Takeoff, Keeps On Flying - 737 brick wall.JPG ... Miloch Aviation Photos 1 October 17th 18 05:34 PM
Flarm Brick for sale [email protected] Soaring 0 March 19th 17 11:12 AM
trying to work out how you connect the flarm view 57 to mini box flarm running a V7 and Oudie Michael Marshall[_2_] Soaring 0 April 8th 16 08:57 PM
Information for all users of Flarm, OEM FLARM supplier and Flarm PowerFlarm [email protected] Soaring 28 March 12th 16 04:31 AM
Ugh. Flight trace didn't download off FLARM brick Kurt Thams Soaring 9 June 10th 15 12:37 PM
