#41
Wow!Â* Imagine what would happen if the rubber band was over wound...Â*
And another occurrence of fly-by-wire(less) control. :-D On 1/24/2020 2:24 PM, Martin Gregorie wrote: On Fri, 24 Jan 2020 10:57:53 -0800, Colten Coughlin wrote: On Monday, January 20, 2020 at 9:16:52 AM UTC-6, wrote: On Monday, January 20, 2020 at 9:34:30 AM UTC-5, wrote: "Is it time to design the sailplane towing version of the Dragonfly for when we run out of Pawnees? Be interesting to see what the soaring brain trust could come up with." If only there was a way to get gliders in the air that didn't require dangerous and expensive rare airplanes... if only there was a "brain trust" elsewhere in the world we could look to for answers. Sigh... well it looks like we're alone with this mystery. Giant rubber bands? Better yet a giant rubber band powered towplane. Yes! I think you have come up with a new idea! One of these was built 10-20 years ago (in California IIRC), but never flown AFAIK. It wasd pretty much just a giant version of an old-fashioned rubber powered beginners free flight model, except the rubber motor was inside a tubular fuselage rather than strung under a wooden beam. There was a huge (20 ft diameter?) two-blade prop on the front, a long, stalky two-wheel undercarriage with a single axle across between the undercarriage legs and a wheel on each end. The 90kg rubber motor was inside a narrow, tubular wooden (balsa?) fuselage. The pilot sat in a small open nacelle mounted on the centre of the undercarriage axle. He held an ordinary RC transmitter that controlled two large servos connected to the rudder and elevators. No ailerons, flaps or airbrakes were fitted. The wings had plenty of dihedral for roll stability, which also meant that simply feeding in rudder would roll it into a turn. They wound it up using the power take-off on a tractor. It got as far as taxiing trials with the wings removed. Not long after that, the website vanished. I don't know why it all went silent and have never heard anything more about it since then. -- Dan, 5J |
#42
On Sat, 25 Jan 2020 08:00:32 -0700, Dan Marotta wrote:
Wow!Â* Imagine what would happen if the rubber band was over wound... And another occurrence of fly-by-wire(less) control. :-D Yes, doesn't bear thinking about! It turns out it was only 90 pounds of best quality 1/4" aero strip as used to power competition models - an unstretched length of 17,500 feet, 5350m, 3.5 miles. It was made up into a 400 strand motor 25 feet (7.7m) long and expected to take 700-800 turns when fully wound. The airframe weighed 220 lbs without the rubber. Here's the most complete version of the story that I've found, complete with a picture of the Rubber Bandit rigged ready to fly: http://sustainableskies.org/a-chance-to-unwind/ .... but it doesn't say why the Rubber Bandit never flew. Elsewhere I found an estimate that the 90lb rubber band cost $US 180,000 and hinted that this had a bearing on it not flying. But that can't be right, because even at today's prices that 90 lb motor would only cost $US 3500, and the article didn't say they needed a new rubber band before they could go and fly. BTW, this wasn't the first rubber powered manned aeroplane: in around 1988 an EAA chapter built and flew the first one. They modified a Lazair ultralite by installing a vastly extended centre boom containing a more modestly sized bundle of aero strip and with a big prop on the front. This only had 23 lbs of rubber in it, but did manage to fly 1000 ft: http://www.lightsportaircraftpilot.com/ rubberband_powered_ultralightaircraft/index.html Maybe its my model flying background, but I think the Rubber Bandit looks a lot more elegant than the RB-1. -- Martin | martin at Gregorie | gregorie dot org |
#43
Wow! This is all very interesting!
Absolute lowest altitude you can fly (legally) | Mxsmanic | Piloting | 138 | January 8th 07 04:53 PM |
EFIS D100 the lowest price | [email protected] | Home Built | 2 | September 5th 06 01:56 AM |
Lowest Cost GPS IFR system? | tom pettit | Instrument Flight Rules | 26 | November 21st 05 09:26 PM |
Lowest Cost GPS Tracking System on the Market | Johann Blake | Soaring | 1 | November 19th 03 04:50 PM |
Lowest Cost GPS Tracking System on the Market | Johann Blake | Piloting | 0 | November 19th 03 04:06 PM |
